86WORX
Old 04-04-2014, 02:54 PM   #687
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
but of course if you're opting for high horsepower (400 whp) that's a whole different story
I wonder if it's attainable with this kind of kit and/or TC might be a better alternative at that point
glamcem is offline   Reply With Quote
Old 04-04-2014, 03:43 PM   #688
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Originally Posted by mit_peid View Post
I saw somebody installing a catch can on the JRSC owner's thread. Has anybody done the same thing on this kit? Since I'm new to FI I'm still not really sure what a catch can actually does - protect the intake manifold from residual oil (?).
Update: I guess a little Googling helped answer some of my questions (http://www.radiumauto.com/Catch-Can-...Z-86-P374.aspx), but has anybody installed one with this kit?
I've installed but haven't drove the car yet.
digital_assassin is offline   Reply With Quote
The Following 3 Users Say Thank You to digital_assassin For This Useful Post:
glamcem (04-10-2014), mit_peid (04-04-2014), PRORICAN (04-04-2014)
Old 04-04-2014, 04:04 PM   #689
Model Citizen
Lacking brains
Drives: frz
I threw on a diy can last night.
It passed the drive around for 20 minutes and have nothing go wrong test.
Model Citizen is offline   Reply With Quote
The Following 2 Users Say Thank You to Model Citizen For This Useful Post:
CSG Mike (04-04-2014), mit_peid (04-04-2014)
Old 04-04-2014, 07:25 PM   #690
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I've been running my cans for the past 2000 miles... Made my own brackets.
Crappy photo I found on someone's fb of my engine bay. If you look on the top left part of the manifold you'll see one(used all black hose), and top right close to the firewall you'll see the other. Used clear hose on the outlet side, to see if I catch any residue and so far nothing noticeable. Working extremely well, catching quite a bit esp on the pcv to manifold side.
Actual cans are ADD W1's
Easy drain access, have dip sticks, baffled well(also added small scrubbers into the baffles for extra peace of mind), and are really nicely made in billet aluminum.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
glamcem (04-10-2014), mit_peid (04-04-2014), Model Citizen (04-04-2014)
Old 04-04-2014, 10:04 PM   #691
Model Citizen
Lacking brains
Drives: frz
Wow, those add w1 cans are really nice for the price.
[ame="http://www.amazon.com/ADD-W1-Universal-Aluminum-Reservoir/dp/B00EGIKL9W/ref=pd_sim_sbs_auto_6?ie=UTF8&refRID=1K9WBPTXQZQDB RSAXJRN"]Amazon.com: ADD W1 Red Baffled Universal Aluminum Oil Catch Tank Can Reservoir Tank Red Ver.1: Automotive[/ame]
Old 04-07-2014, 04:55 PM   #692
glamcem
glamcem's Avatar
@digital_assassin I've ordered my kit today so you can add me to that list too
I will keep you guys posted with the updates
The Following 3 Users Say Thank You to glamcem For This Useful Post:
captain_jack (04-07-2014), digital_assassin (04-07-2014), mit_peid (04-07-2014)
Old 04-09-2014, 03:19 AM   #693
glamcem
glamcem's Avatar
for those who have the drop/choppiness in power after 6500 rpm, Has anyone of you changed your spark plugs with a 1 step colder iridium ones and tuned for it?
This is what I am referring to
@gmsii has mentioned this in the "KW discussion thread" and it's also recommended in the installation manual (page 2, bullet point 5)
generally the high rpm choppiness is from the spark plug...these were stock plugs, we will try a step colder...should smooth it out
My kit is in the mail and I am wondering if I should go ahead and order my plugs too..How hard was the install? I know it's somewhat hard to reach on Subaru engines but never had to change it with my previous Subarus
Old 04-09-2014, 08:17 AM   #694
Model Citizen
Lacking brains
Drives: frz
I haven't tried on this car yet. But you may find it easier to undo the motor mount nuts and raise the engine, even if just one side at a time.
My forester originally had the plug holes between the frame rails as well, basically you figure out a sequence of adaptor sand sockets to make it work if not raising the engine
The Following User Says Thank You to Model Citizen For This Useful Post:
glamcem (04-09-2014)
Old 04-09-2014, 07:18 PM   #695
glamcem
glamcem's Avatar
I think someone on the forums was able to install the plugs without jacking the motor .. with the correct tools it should be possible since plug change is pretty easy job as long as you have enough clearance..
If I ever change my plugs I will provide a DIY for that
Old 04-09-2014, 07:50 PM   #696
Model Citizen
Lacking brains
Drives: frz
on my forester doing it without jacking meant inserting one tool at a time, removing one at a time, etc, once you had the sequence and the proper tools it wasn't terrible considering how often you mess with plugs,
still may actually be easier just to loosen the mounts and jack it up a bit.
Old 04-09-2014, 09:14 PM   #697
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
This has been covered. I plan to do this by jacking the motor one side at a time. It's clearly the faster, easier way to go.
btw... also covered... I don't think you need a colder plug, but I do think there's point to reducing the gap for FI.
Ralph Spoilsport is offline   Reply With Quote
The Following User Says Thank You to Ralph Spoilsport For This Useful Post:
Old 04-10-2014, 12:35 AM   #698
glamcem
glamcem's Avatar
I've learned that the OEM plugs are good up to 14 psi so I won't change it until I need to do it
Old 04-10-2014, 12:47 PM   #699
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
Does anyone know if Kraft Werks has released there oil cooler yet ? if so can someone point me in the right direction since it seems that KW does not like replying to emails after that have taken your cash
Ocho Seis is offline   Reply With Quote
Old 04-10-2014, 01:12 PM   #700
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
We post updates on the Kraftwerks Facebook page daily, and we like to maintain our website as best as possible. Our site is also searchable. We also would have made it a point to update everyone here on FT86club to avoid statements about us "taking your cash". Customer service has searched through the emails and we can not find anything regarding an oil cooler order that is pending. Can you pm us your name, email and phone number please?
KraftWerks is offline   Reply With Quote
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
