Old 03-04-2014, 01:17 AM   #421
wrohdejr
Drives: 2013 subaru limited wrb brz
So i put all my engine carbon fiber back on with the supercharger!!
Portland 86ers
wrohdejr is offline   Reply With Quote
The Following User Says Thank You to wrohdejr For This Useful Post:
PRORICAN (03-04-2014)
Old 03-04-2014, 01:33 AM   #422
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Looking good Wally!
digital_assassin is offline   Reply With Quote
The Following User Says Thank You to digital_assassin For This Useful Post:
wrohdejr (03-04-2014)
Old 03-04-2014, 02:56 AM   #423
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Kraftwerks Supercharger Owners Thread
So I finally put on the bumper and drove the car for the first time with the SC installed. Did anybody have any bumper fitment issues? It seems like the FRS grill (not the two air duct things on the side which I removed) is right up against the IC and I'm as much as 1/4 inch off a good number of fasteners underneath the car. Kind of annoying.
Anyway, for the drive. First thing I noticed was the whine. It is quite loud and while cool sounding I'm pretty sure I'll be looking into the clogged idler, smooth belt, or whatever it would be that makes that noise a little less obtrusive. Not sure if it is the factory KW tune that is to be blamed or is it that I just need to relearn how to drive with a SC installed, but it isn't very smooth on initial take off in 1st. I've played around with different amounts of throttle but still it is rather hurky-jerky. Feels like the bog feel with a giant air conditioner on full blast in a small displacement engine but about a magnitude worse. But once it is past about 3000 RPM up to redline WOW is it fun. Not sure how many HP my buttdyno is registering but here is a significant amount of power there and it just keeps climbing. The bypass sound is also very cool sounding yet subtle. Didn't want to push it too hard since it was my first drive.
So is anybody else still on the KW factory tune?
mit_peid is offline   Reply With Quote
Old 03-04-2014, 03:08 AM   #424
digital_assassin
If you get a custom tune your tuner should be able to make it much more smooth in the lower range. Mine feels great all the way through the gears.
Drift-Office (03-04-2014)
Old 03-04-2014, 05:39 AM   #425
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Can you guys elaborate the benefits of the front pipe, over pipe with KW kit and catback exhaust if any?
I've searched but couldn't find the exact answers. From my previous experience with other boosted cars (2 Stis and Evo X) as well as the Corvettes ..catbacks never really made a big difference in terms of power..and IIRC, someone was mentioned that the headers don't make big difference either (until 6500 rpm)..
I was hoping to be able to use the Forester oem oil cooler when I get this kit but it seems like the clearance might be an issue also.. hopefully the new KW oil cooler kit solves this problem since I have no intent to spend $600 for a simple oil cooler
glamcem is offline   Reply With Quote
Old 03-04-2014, 10:10 AM   #426
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by mit_peid View Post
Is there anyway you can take a photo of the Forester oil cooler with a tape measure in the background 1.) first measuring the height of the unit and then 2) another photo measuring the diameter (is it larger than the base of the stock seat?).
http://www.ft86club.com/forums/showp...&postcount=194
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
mit_peid (03-04-2014)
Old 03-04-2014, 10:18 AM   #427
utekineir
blowhard
Drives: frs, project forester
I'm on it.
Absolutely doesn't have oem smoothness. But it doesn't surge a ton, most of the time it's smooth, just not 100% of the time.
Noticed a bit of bogging at first. Didn't take long to get used to.
utekineir is offline   Reply With Quote
Old 03-04-2014, 10:18 AM   #428
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
mit_peid's photo of the KW install suggests to me Forester oil cooler will fit. Looks like KW pulley mounting bolt is a little lower than the oil filler cap and won't interfere with the cup at the top of the oil cooler.
Ralph Spoilsport is offline   Reply With Quote
Old 03-04-2014, 11:11 AM   #429
Ralph Spoilsport
@gmsii, @KraftWerks
Is this known issue? BRZ any different?
Old 03-04-2014, 12:57 PM   #430
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I have bumper fitment issues, hoping to fix that soon :P Too lazy to track down the source for now
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-04-2014, 01:50 PM   #431
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by Ralph Spoilsport View Post
@gmsii, @KraftWerks
The FRS does need some trimming of the grill, we are making revisions to the instructions to add more detail, torque specs, revised oil hose routing etc based on the feedback received here on FT86club. We hear you guys loud and clear and we're working on it!
KraftWerks is offline   Reply With Quote
The Following 3 Users Say Thank You to KraftWerks For This Useful Post:
Freeman (03-04-2014), MidnightRunner (03-04-2014), Ralph Spoilsport (03-04-2014)
Old 03-04-2014, 02:22 PM   #432
captain_jack
captain_jack's Avatar
I had fitment issues as well,I had planned on doing a good right up for them, as I have already been talking to then about fitment. Mine for the most part settled in after I removed the bumper the second time. I had really bad gaps at the bottom of the headlights. I have planned to remove the mesh and install some extruded steel in its place. I believe that would give the needed clearance. I will have to cut the mesh though to retain the solid part at top to cover the bumper underneath. We will see what can be done.
may the schwartz be with you....
Old 03-04-2014, 06:07 PM   #433
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Should be installing the KW/S2 engine oil cooler this weekend if everything lines up. I'll take detailed pics when I get it. However, keep in mind it is not going to be the full production kit. It'll likely be near exact though.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
captain_jack (03-04-2014), TrogDor the Burninator (03-04-2014)
Old 03-04-2014, 07:22 PM   #434
MidnightRunner
MidnightRunner's Avatar
You mentioned the frs specifically, so does it mean that the brz does not require said trimming?
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
