#4061 | |
BoostedBRZ
Drives: Turbo BRZ
#4062 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
yes here kits are normally around 11-12.5psi (780-850 grams) with stock pulley and open exhaust.
remember kraftwerks state to limit engine rpm to 7400 in your tune to not overspeed the SC. Last edited by ST-A; 04-14-2017 at 02:19 AM. Reason: added |
#4063 |
BoostedBRZ
Drives: Turbo BRZ
30MM Belt
#4064 |
Drives: 2013 FR-S Argento
#4065 |
BoostedBRZ
Drives: Turbo BRZ
Sorry I guess I can see where the confusion comes in. The picture is actually from Kraftwerks Instagram account.. I already emailed them asking for info.. still waiting for a reply though. They are basically using the same exact pulley diameter so no re-tune is required. The pulleys and the belt are actually wider. The original belt being 20mm wide, and the new one being 30mm. 30mm ~ .39 inches. It's definitely wider too just looking at the picture. I'm just curious as to how this work since one of the pulleys are a few mm away from the oil filter... My only thing I can think of is that they pushed out the adapter plate further with long brackets attaching the adapter plate to the block... But then that would push the intake further into the bumper, unless there's enough room for the extra 10mm to be pushed out towards the front of the car.
#4066 |
BoostedBRZ
Drives: Turbo BRZ
So I found the part number for the new belt after doing my own research:
TP1280-8MGT-30 instead of TP1280-8MGT-20... the new belt has an increase in cost of about 20-30 dollars more or less. I'll have to see and keep digging for pulleys.
| The Following User Says Thank You to pgranberg11 For This Useful Post: | bfrank1972 (04-19-2017) |
#4067 |
BoostedBRZ
Drives: Turbo BRZ
No new info on pulleys. Kraftwerks got back to me and this is what they stated:
"I believe we finally have these available for actual sale. $399 is the retail price that I see within the system… so original owners (with proof) would receive the upgrade for $279.99 + Shipping." I replied asking for a parts list, as in what exactly is included. Just the pulleys and the belt wouldn't cut it since there's barely enough room to begin with. So I'm guessing they have modified the brackets or added spacers to the original ones to push the adapter plate out further to accommodate the wider design. Then pushing the adapter plate out, the intake is also pushed out as well, so I'm curious how they have that worked out.
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Freeman (04-19-2017) |
#4068 |
Drives: 2013 Ultramarine FR-S
Hopefully someone upgrades and tracks the crap out of it. I want to see if the new design is worth the upgrade.
Any news on an autotensioner for the belt? |
#4069 | |
BoostedBRZ
Drives: Turbo BRZ
"While the same attention should be paid towards monitoring the belt tension, the added surface area and overall strength of the belt allow for a little extra leeway in that regards so you can get away with missing a check or two, etc. and still not have the belt just snap for the sake of snapping."
#4070 |
Drives: Crystal Black BRZ(Sophia)
So is this their fix for the belt snapping problem?
#4071 |
#4072 |
BoostedBRZ
Drives: Turbo BRZ
I don't necessarily think this will be a "set it and forget it" sort of fix. Any supercharger belt in general needs to be paid attention to. But with what kraftwerks was implying in their email is that because of the wider belt it is more forgiving in case you do forget to check it as often as you should. In my opinion, now that I look back on it, their belt snapping problem was the lack of communication, not the design/drive system itself. The instructions that they had were very poor in describing how tight the belt should be as the 21mm rule would change every time the belt would stretch. I've used the half a belt twist method now, and I'm almost on a year with my replaced belt with multiple track events last year, with more coming this year. I still recommend keeping a spare belt or two just in case anything does happen. I've been in the edelbrock thread and even jackson racing's thread (not trying to start which one is better etc, etc), but just to show that any supercharger a belt will get shredded or snapped their too, but not as often due to us having the lack of an auto tensioner.
| The Following 2 Users Say Thank You to pgranberg11 For This Useful Post: | bfrank1972 (05-01-2017), Freeman (04-19-2017) |
#4073 | |
Drives: B8 A4
The boost measurement was seen while my tuner was tuning the kit |
#4074 | |
BoostedBRZ
Drives: Turbo BRZ
90mm = high boost pulley 85mm = higher boost pulley each pulley swap should be around 2-3lbs of boost in jump according to a conversation I had with moto-east since I was debating on upgrading my pulley. Decided to stick normal though. Maybe you are actually running the 90mm pulley. Hard to say though unless you actually look at it, but there's not much room to look once it's mounted. Actually... I just re-read your original post. You have a cat in your system. I remember the first year I was on track with my stock front pipe with my cat I was getting about 14psi. standard boost pulley c38. fast forward to last track season, I was only reading 11-12psi. Fast forward to a few months ago, I replaced my whole exhaust when I looked at my downpipe, no cat was there. The reason why boost is showing higher is because there is more pressure caused by the cat. Really nothing you should worry about other than your cat eventually melting/blowing out.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
