#4033 | |
Drives: 2014 Red Subaru BRZ
#4034 |
| The Following User Says Thank You to Helios For This Useful Post: | pgranberg11 (02-07-2017) |
#4035 | |
Drives: 2013 FR-S Argento
[ame="https://www.youtube.com/watch?v=AeyqWWKE7b8"]Kraftwerks. Priming Oil System - YouTube[/ame] |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | pgranberg11 (02-07-2017) |
#4036 | |
BoostedBRZ
Drives: Turbo BRZ
#4037 |
Is this system gravity fed? Just wondering as if it's mounted too low it might cause flow issues?
#4038 | |
BoostedBRZ
Drives: Turbo BRZ
"The oil lines and the oil system components (filter, canister and cooler) must be placed below or level with the supercharger shaft" and "To prevent oil leaks it is of utmost importance that the oil cooler, oil filter and the oil canister with its cap are placed below or level with the supercharger shaft."
#4039 | |
#4040 |
Stuck In a Sandbox
Drives: FRS RS1.0
is there any kind of guide for regular maintenance for this kit?? Like how often belts should be changed, fluid intervals, etc?
#4041 | |
https://www.yourmechanic.com/article...rger-belt-last The Rotrex manual states to change the supercharger oil every 50k miles or 2 years, whichever comes first. Rotrex oil is $100/ litre. What I will most likely do is replace the belt, filter, and oil every 50k miles or 2 years. It'll be a couple hundred dollars, but that's cheap insurance to ensure many happy miles from the kit. |
#4042 | |
Stuck In a Sandbox
Drives: FRS RS1.0
Thank you for replying. Thats actually a whole lot less than i was expecting! |
#4043 |
#4044 |
Stuck In a Sandbox
Drives: FRS RS1.0
#4045 |
BoostedBRZ
Drives: Turbo BRZ
For both people who posted videos, does the abnormal noise speed up with the revs? If they do then you most likely have a bad bearing in one of the pulleys.
Sent from my Nexus 6 using Tapatalk
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Freeman (03-05-2017) |
#4046 | |
Stuck In a Sandbox
Drives: FRS RS1.0
Honestly its somewhat difficult to hear while im driving. But from what I can hear yes it speeds up with revs. I know it only really happens once the car warms up. We had tightened the belt at one point and it definitely got louder. Once we loosened the belt up it went away for a bit and is now back but not as loud. I also sprayed a little belt spray on the cogged supercharger belt and the noise got quite a bit louder. At this point im hoping that means its not the blower its self and rather a bearing. |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
