#3949 | |
| The Following User Says Thank You to FirestormFRS For This Useful Post: | pgranberg11 (08-06-2016) |
#3950 |
BoostedBRZ
Drives: Turbo BRZ
I'll have to try that. But wouldn't you think that the oring should be the right size to begin with..? It just seems kinda odd that we'd have to go through all of it.
#3951 | |
Drives: 2013 Ultramarine FR-S
Mine leaked like crazy. So did the oil cooler itself. I eventually took it off and I'm building my own. |
#3952 | |
BoostedBRZ
Drives: Turbo BRZ
you mentioned you're building one yourself, what sandwich plate will you be using? I ended up going with a 19 row mishimoto oil cooler and their lines and following the DIY homebrew oil cooler tutorial on here (mounting it in front of my intercooler) the thing worked great but it leaked a shit load. after it was installed I had temps of about 260 if that at the very highest.. |
#3953 |
I had a custom spacer and plate made by RacerX Fabrication. Thermostatically controlled and they offer banjo fittings so there's less interference with the oil fill cap. You can email them, great company to work with.
I've got a 19row Setrab core coming in and a local industrial hose place doing the lines. I never found a solution. I took it off and my plans to track the car were put on hold. |
| The Following User Says Thank You to Freeman For This Useful Post: | pgranberg11 (08-06-2016) |
#3954 |
BoostedBRZ
Drives: Turbo BRZ
I just pmed you freeman I had a few questions. thanks man
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Freeman (08-06-2016) |
#3955 |
Drives: Raven FR-S 6M
I am on my second belt and have been checking tension to make sure this one lasts longer than my first. I am finding that my belt tension changes a lot just from outside temp. I had started by tensioning to 60hz when cold but I am finding this to be too tight once everything warms up. I think the nightly temps drop to around 50 f and the whole drive system expands a fair bit once I am up to operating temp and outside temps are 80 f. I started hear a bit more whining noise from the SC once it was hot and was not sure if I should back the tension down a bit. To add to this the BPV seems to make more noise when hot also. Anyone else experience these with Kraftwerks?
“The World is Flat”
[||•]=(86)=[•||] |
#3956 | |
Drives: frs
| The Following User Says Thank You to vgi For This Useful Post: | Apoc (08-10-2016) |
#3957 |
BoostedBRZ
Drives: Turbo BRZ
anyone know the clearance between the top of the oil filter and the bottom of the hood? with or without the kraftwerks oil cooler adapter? Only reason why I was asking because I was thinking about doing this, but just not functionally using the forester oil cooler part.
![]() any one have a reason why this shouldn't work? I would be using the forester oil cooler sandwich plate mainly as a spacer or adapter... i wouldn't connect it up at all to my coolant system. Then I would use the mishimoto adapter and twist it so it faces over the oil filler cap... seems like it should work unless someone else says otherwise? Only reason why I'm trying to think outside the box is because I have a funny feeling the replacement sandwich plate from kraftwerks is still going to leak.... Last edited by pgranberg11; 08-26-2016 at 07:01 PM. |
#3958 |
I am now in the same boat.
“The World is Flat”
[||•]=(86)=[•||] |
#3959 |
BoostedBRZ
Drives: Turbo BRZ
Well, that looks like that's a total of 4 now... Freeman, myself, Apoc, and someone in the kraftwerks facebook group...
I made a separate thread and wanted to get more visibility and put it in here so every one can see it: http://www.ft86club.com/forums/showthread.php?t=110105 EDIT: btw, the above solution does not work. the oil cooler from the forester sits too close and when the mishimoto adapter is placed on top it will indeed hit the pulley. only questionable solutions are trd sandwich plate + mocal tstat/non tstat adapter. OR This is the newest one I thought of... it would go perrin spacer, perrin oil sandwich plate, and then mocal tstat adapter on top. and the the oil filter. Who knows if this would even work.. just trying to brainstorm solutions. here's my crude mockup...
#3960 |
I'm kind of in a bind. I purchased a kraftwerks kit C30-95 with Carb Tune. Everything is installed, but when I went to flash the ECU with ECUTek and Kraftwerks Carb Tune I realized that there are 3 files that are on the USB Drive that Kraftwerks provided.
1.Kraftwerks Rom ZA1JA01D CARB TUNE 6B 82 2Denc 2.Kraftwerks Rom ZA1JD00C CARB TUNE -enc 6B 82 2D 3.ZA1JB01C CARB TUNE 6B 82 2D-enc They are all .bin files. Which one is the right tune. My car is completely stock except for the Kraftwerks kit. Can anyone help me out? I'm just kind of sitting here kicking myself for not looking into this before I started the install. BTW @KraftWerks you should really put some type of instructions in the install manual regarding the tune files and just say refer to ECUtek instructions. |
#3961 |
Never mind. Figured it out. The files are for the different ECU versions of the BRZ/FRS.
#3962 |
Drives: 2015 BRZ Limited MT
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
