#3711 |
Drives: 2013 scion frs
#3712 |
Drives: Scion FR-S
Anyone have a leaking oil problem from the oil bottle?? Filled oil, check it and the cap of the bottle is somehow not tight enough to and now oil leaking from the cap.
#3713 | |
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Is it possibly over filled? Could the fittings be leaking? Maybe the filter is plugged? But I haven't had that issue. Sorry |
#3714 |
Drives: Scion FRS
#3715 |
Drives: Scion FR-S
#3716 | |
If it's a new install you might want to double check the hoses are routed/installed the correct way. If none of that i would call Kraftwerks ASAP and go over it with them. |
#3717 |
If you are talking about the oil reservoir leaking, it is most likely over filled. I had the same problem... took it all apart, cleaned all the washers and fitting and its been fine since.
#3718 |
Drives: 2013 Subaru Brz Satin White Pearl
Just got my c30 kit installed looking and running good!
Sent from my SM-G900V using Tapatalk |
| The Following User Says Thank You to Jusjones For This Useful Post: | Freeman (02-02-2016) |
#3719 |
Drives: 2013 Raven Black FRS
Anyone here run Kraftwerks Blow-Off Valve?
Instagram: Kato1337
#3720 |
Yea it comes with the kit
#3721 |
Pretty sure the first page of this thread has a link to spare belts or you can just call KW and order one
#3722 | ||
Calling KW might be the easiest way but if you have the 100mm crank pulley and the 75mm SC pulley the part number is "Gates TP1200-8MGT-20 PowerGrip GT2 Twin Power Belts 9232-0041". You can find it on amazon for like $70. |
#3723 |
Yea I was more or less calling to get the for sure part number, yea I got the 128 95 set up
#3724 |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
