Old 10-25-2015, 02:14 PM   #3627
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
With out a doubt I'd get a custom tune.
If I were to buy a KW system again I'd get the C38 with high boost pulley and have a custom charge pipe made. Then attach an electronic boost controller so you can get better low end response and have it blow off boost on the top end so you're not blowing your motor. This would also allow you to run multiple maps with different boost settings.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Rulin (10-25-2015)
Old 10-26-2015, 09:36 AM   #3628
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by mscamp02 View Post
I recently sold my 71 firebird so I could go FI on the frs. And have bounced all over the map on how I want to do it.
Originally I wanted the c38 kit but now I am leaning towards just the c30 because it's available for 4.45k with ecutek/canned tune from rickspecd.com. so I thought about taking the cash savings over the c38 to upgrade my exhaust completely from header back with a 2.5 in system (no idea on brand or combination but needs to be semi quiet).
I don't really want to stick with the canned tune and I Wil be doing the install myself so I am contemplating the flash n go or driving it on the canned tune to dynosty two hours away and having them tune it (i just don't like the idea of having to drive/haul two hours for issues). My goals are reliability and somewhere north of 250 or 270hp (reason why I'm not going with the c38).
Anyone have any ideas on tune or how I should go about it
Sent from my VS985 4G using Tapatalk
I'm very happy with moto-east. They send you a semi-custom tune for your car and you go back and forth with them sending them logs and Mike doing some fine tuning. I don't know if you have e85 in your area but that really makes the c30 kit come alive. You get more power everywhere and especially the midrange.
The c30 I feel is more than enough. I originally went back and forth with the c38 kit but with e85 and the c30 (~300whp), I break the rears loose rolling on the throttle in 3rd gear once I hit ~5000rpm. When I upgrade my tires (currently running 225/45/17 dunlop sport maxx/rs3), I might throw on the high boost pulley (~380whp) but I think that will just be ridiculous scary power. I've been running the c30/e85 kit all year and the power still is awesome when I get to use it.
industrial is offline   Reply With Quote
Old 10-26-2015, 10:02 AM   #3629
mscamp02
Drives: 2013 FRS
That's great to hear. I have e85 semi close to me, about 15 miles and definitely have that on future plans.
It's the moto east more custom than the flash n go from delicous.
mscamp02 is offline   Reply With Quote
Old 10-26-2015, 10:07 AM   #3630
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
I'm running the c30 with moto east tune and it's been great! He's still helping me when i have questions a year after my initial tune
Sent from my Nexus 6 using Tapatalk
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 10-26-2015, 12:02 PM   #3631
rj101592
Drives: 2013 scion frs
C30 kit, belt just went after 1000 miles
rj101592 is offline   Reply With Quote
The Following User Says Thank You to rj101592 For This Useful Post:
Freeman (10-26-2015)
Old 10-26-2015, 12:06 PM   #3632
Freeman
Freeman's Avatar
Tightened to 60-65 hertz using the Gates carbon drive app?
Old 10-26-2015, 12:33 PM   #3633
rj101592
Not sure, had a speed shop do the install. I installed the gates app on my iphone but everytime i tried measuring it gave me sporadic readings
Old 10-26-2015, 12:38 PM   #3634
Freeman
Freeman's Avatar
The belt system is really finicky on this kit. Set it to within that range and you should be OK. I did and my supercharger died before the belt had any issues. Call up Kraftwerks and order 2 belts just in case it happens again.
Old 10-26-2015, 01:26 PM   #3635
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Also, as the weather changes pretty rapidly in Texas, I like to check the belt frequency after big temperature swings. I've had to tweak it some times.
I've had this kit installed for 28k miles and broken only 2 belts. Once on a dyno and another after a long day of driving hard in the mountains. Both those times, I had forgot to check the tension before the runs (my negligence).
I do now have 2 backup belts for peace of mind though. Kraftwerks/CJ has been very good at getting the belts out to me quickly after I contacted them.
KW V3
Old 10-30-2015, 05:35 PM   #3636
rj101592
I tried measuring frequency with the gates carbon app on my iphone but it is super sporadic with the readings
Old 10-30-2015, 05:36 PM   #3637
Freeman
Freeman's Avatar
What range was it giving you?
Old 10-30-2015, 05:43 PM   #3638
rj101592
24 then 34 then like 125 lol
Old 10-30-2015, 06:13 PM   #3639
Freeman
Freeman's Avatar
Pluck it the same each time. You can easily cause that amount of variation just by the amount of force you use. The belt system is finicky and takes some diligence to stay on top of.
Old 10-30-2015, 06:47 PM   #3640
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
You sure it's not just too loose, I know when not tightened enough the gates app is either unable to give a reading or gives varying reading(as the loose causes the frequency to go all over the place)
fumanchu1 is offline   Reply With Quote
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
