Old 06-08-2015, 11:48 PM   #3417
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
holy 6025hp !!!
Originally Posted by mit_peid View Post
I think if you superimpose the dynos from the normal pulley to the "high-boost" setup, most if not all the gains will be in the top-end, not down at 2000rpm. I recall the power above the stock pulley started around ~6000hp and peaked with a +25hp peak bump.
On a more serious note, do you guys hear a minor lug/chatter coming from a dead stop? Its a tough act trying to balance clutch wear and engine chatter.
This thread definitely needs a FAQ section. Maybe we can potentially PM FAQs to the OP so he can add it at the front page. Sometimes I feel bad asking questions because I feel like they could be potentially answered in other posts.
projek_01 is offline   Reply With Quote
Old 06-09-2015, 10:33 AM   #3418
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Any of u guys have an aftermarket crash bar with the kit?? What brand?
scionfr_s is offline   Reply With Quote
Old 06-09-2015, 10:41 AM   #3419
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
There's a guy in Instagram who uses a spencer fabrication crash bar with a larger intercooler. All custom work but if you contact Spencer Fabrication I bet he'll be able to help you out
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Rulin (06-09-2015)
Old 06-10-2015, 01:14 AM   #3420
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by projek_01 View Post
holy 6025hp !!!
yea, I get the chatter. When starting to accelerate from a dead stop it sounds like something it hitting something else under the engine. I realized it's actually belt slap. If you're hearing chatter my guess is the belt is too loose. The tighter I put the belt on the less chatter I heard. So I just tightened the belt to where I heard no chatter. The 21mm rule that they have in the manual didn't work for my second belt. It was wayyy too loose. I went by my friends "half a belt twist rule" and it worked fine. Just tightened a tad bit more and then all chatter disappeared. If I could remember, I believe I'm at 14 or 15mm from the bottom of the bolt head tensioner to the supercharger bracket. Hopefully this helps a few.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
projek_01 (06-11-2015)
Old 06-10-2015, 01:45 AM   #3421
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Would you all agree that with a built motor and a C38 comp that this kit has the highest hp potential out of the current offerings ?
killerkid08 is offline   Reply With Quote
Old 06-10-2015, 01:48 AM   #3422
beemer
Drives: '13 FRS
I can't necessarily agree, but it would be my choice for sure
Sent from my SM-N900P using Tapatalk
beemer is offline   Reply With Quote
Old 06-10-2015, 01:48 AM   #3423
Freeman
Freeman's Avatar
No. A turbo will trump it. But if you mean SC only then yeah with E85 and a built motor the C38 should kick ass.
Old 06-10-2015, 02:02 AM   #3424
Freeman
Freeman's Avatar
But there's a few SC kits that are worth keeping an eye on, Harrop Engineering, Edlebrock, and Jackson Racing C38.
Billion (06-10-2015)
Old 06-10-2015, 05:25 AM   #3425
Billion
Drives: 2013 Toyota 86
What about the Sprintex 335 kit? It looks pretty mental :P
Billion is offline   Reply With Quote
Old 06-10-2015, 10:11 AM   #3426
Freeman
Freeman's Avatar
I hear it's a bitch to tune properly.
Old 06-11-2015, 03:32 PM   #3427
Jcl
Drives: 2014 BRZ
Any difference from manual kits to auto? Thanks!
Jcl is offline   Reply With Quote
Old 06-11-2015, 04:18 PM   #3428
killerkid08
Cool Stuff
Drives: Cool Car
I probably should have added that I was limiting choices to supercharger offerings. I didn't know Jackson was working a c38 kit. I know belt reliability is iffy on these kits from KW, thanks to the lack of a auto tensioner ???
Anyone thinking its worth it to push it with a built block and c38 vs a larger turbo. The idea is a responsive FA20 with atleast 500whp, whi ch would place the PTW is GT3 RS category.
Old 06-11-2015, 04:21 PM   #3429
Freeman
Freeman's Avatar
No physical difference but when I went to get tuned (I have an auto) my tuner had to reschedule it with me because the tune files from manual to auto were too different to do it in the time he allotted. They may have changed tuners at KW and that's why.
Jcl (06-11-2015)
Old 06-12-2015, 07:20 PM   #3430
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Anyone using Perrin oil cooler with the kit??
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
