Old 05-18-2015, 10:12 AM   #3347
Model Citizen
Lacking brains
Drives: frz
i'd love to try the smaller pulley or a c38,
pretty sure it will result in broken bits sooner though wether it be clutch, axles or whatever else since the car only gets driven for autox/track atm it currently sees nothing but abuse.
most of the time it still seems like the extra power wouldn't really be able to utilized fully, the c30 and stock pulley (93 oct) goes very well (for my uses) when you dig hard on it (wot in 2nd a lot for autox, wot 3rd-5th a lot on track). With 265 re71-r traction isn't a huge issue, but its far from impossible to lose it either.
ended up parked next to a worked over elise with a c38 among other mods this weekend at a test and tune using a very short configuration to the local autox venue.
he claimed to be in the low 2000lbs range and over 400 hp, far greter power to weight than the c30 and frs, let alone he was a solid 100 lbs less than my fat ass.
still put about 2 seconds on him on a 40 second course.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 05-18-2015, 02:18 PM   #3348
CSG David
CSG David's Avatar
That just means you can drive better than him.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
Billion (05-18-2015), glamcem (05-29-2015), JDMChris (05-18-2015), SPCorBUST (05-18-2015)
Old 05-18-2015, 04:10 PM   #3349
Model Citizen
Lacking brains
Drives: frz
I agree.
Brain fog rambling about the c30 and base pulley being not bad i guess.
the car looked to be set up very very well, it lacked nothing and its power to weight was silly. Generally around here an elise that well setup isnt being driven by a terrible driver.
The Following User Says Thank You to Model Citizen For This Useful Post:
CSG Mike (05-18-2015)
Old 05-18-2015, 05:18 PM   #3350
Kojiro
Drives: 2014 Black BRZ Limited
Originally Posted by scionfr_s View Post
Is there anyway to make the BOV make the phhh noise louder?
I disconnected the hose going from the bov to the intake and plugged up the intake hole with a plug.
You're actually really close by to me if you want to check
It out.
Kojiro is offline   Reply With Quote
Old 05-18-2015, 10:12 PM   #3351
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Annoying Noise Developed
Guys, I need your opinion. I tried my best to find this annoying noise with no luck. Sent blower and idler pulley's to @KraftWerks already. They did replace the idler's, but they can only do visual inspection on the blower. They said it will void warranty if they open it up, which is fine.
No boost leak or loosed hose, those where the first thing I checked. 3 freaking weekends already I wasted i trying to find the source of the noise. Removed bumper 3x already.
It's the back ground noise that goes up and down with the RPM. It's like our cricket's but much, much louder.
I attached the link for the sound clip. Noise BTW is gone when the belt broke the 2nd time. Noise is also present from 60 HZ all the way down to where I already have a belt slap.
Opnions will be highly appreciated. Thanks in advance.
https://drive.google.com/file/d/0B75...ew?usp=sharing
Now that you guys heared it, it's really freaking annoying driving around with that noise, specially when on stop light. It's also the last sound you hear after turning of the car.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 05-19-2015, 08:02 AM   #3352
FirestormFRS
If you take the blower belt off the noise goes away? Then it's either the blower or the idlers. The idlers have been checked so that leaves the blower.
How's your oil level for the blower?
Is there an oil line kinked somewhere between the blower/cooler/oil reservoir that's not letting it flow?
Somewhere way back in this thread someone put belt dressing on the blower belt for a similar noise. May wanna try that.
FirestormFRS is offline   Reply With Quote
Old 05-19-2015, 08:19 AM   #3353
Model Citizen
Lacking brains
Drives: frz
Stethoscope ?
Old 05-19-2015, 10:15 AM   #3354
zoth
zoth's Avatar
All oil line are routed in a neatly with no kink. That was me who used the belt dressing. This one is completely different animal all together. Fluid level is perfect and still blue.
That's what I figured that all source of noise where all eliminated and the only thing left is the blower. But @KraftWerks are trying but they all keep on saying they hardly hear the noise.
Do you clearly hear it?
Old 05-19-2015, 10:15 AM   #3355
zoth
zoth's Avatar
Stethoscope ?
Old 05-19-2015, 11:17 AM   #3356
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I hear a high pitched whine. Like a bearing is grinding or something isn't lubed.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
zoth (05-19-2015)
Old 05-19-2015, 12:36 PM   #3357
zoth
zoth's Avatar
Video clip
On this link you can hear the noise from inside my house going into my garage. Freaking nasty noise is killing me :-(
Old 05-19-2015, 01:01 PM   #3358
SPCorBUST
SPCorBUST's Avatar
Someone else's blower might be on the way out, I think it was @Freeman, maybe ask him (or whoever it was) if they had a similar sound before sending it in.
Maybe search for "strange/weird Rotrex sound" or "broken Rotrex?" on YouTube there might be some comparison clips.
@KraftWerks could also say something like "As one of the top distributors of Rotrex, we know when one is failing and it does/doesn't sound like that."
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
zoth (05-19-2015)
Old 05-19-2015, 02:36 PM   #3359
Scracho
Drives: 2018 Subaru BRZ
BOOM! Finally installed!
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following 6 Users Say Thank You to Scracho For This Useful Post:
BRZZZZZZZZZZ (05-19-2015), DAN_BRZ (05-19-2015), Freeman (05-26-2015), JonAvalon (05-19-2015), Rulin (05-19-2015), Triumphrider (05-19-2015)
Old 05-19-2015, 03:35 PM   #3360
zoth
zoth's Avatar
Funny thing is, it seems like none from @KraftWerks hear, what you guys confirmed to hear like I do. Freaking bummer :-(
I also don't want to blow 100 plus for a fluid change, knowing that it will just be back. Plus my fluid is still blue.
@CSG Mike your very familiar with the Rotrex , what do you think?
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
