#3235 | |
Drives: 2013 Scion FRS
I have the same description rattle and it drives me bonkers. I'm convinced it's my stock header heat-shield though and not the pipe as I have used a rubber pipe coupler to insulate the pipe from rattling at most locations. If I pound (with the side of my fist) on the KW bracket above the AC I can hear what I believe to be my heatshield rattle. Not sure what to really do about it besides maybe some large worm clamps...
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
| The Following User Says Thank You to nlowell For This Useful Post: | Triumphrider (04-12-2015) |
#3236 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#3237 |
Drives: 2013 Scion FRS in white out
Lol I'm catless without shield
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
#3238 |
Drives: 1996 ST204, Series 10 FR-S
Tried the Carbon Drive App and it seems to be very inconsistent on my phone. I am guessing it is too noisy where my car is parked. I loosened it quite a bit after you guys mentioned it and now it seems quieter (still noticeable at idle). Now the belt vibrates (visually) where its a little slack. Is it too lose now?
Thanks! |
#3239 | |
Drives: GT86
Up for the question :-)
#3240 |
Drives: 2022 BRZ Limited
I've also posted this on Subaru BRZ's facebook page and wanted to share here too
![]() my BRZ w/ @KraftWerks SC next to my friend's NC3 Miata also w/ Kraftwerks (Supercharger kit has been recently installed), both cars are built for track use with similar mods and tuned by @moto-mike from Moto-East . ..throttle response on the MX-5 was really good and a bit smoother than the BRZ -as we thought it would be, most likely due to advantage of a smaller C30-84 Rotrex unit (vs C30-94 in the BRZ kit), or Miata engine's flatter torque advantage in the mid range (where we have a dip) or maybe combination of both factors I wonder what kind of numbers the Miata will put down on the dyno and how those will translate to lap times this season ![]() hood vents and the removable clear tray on the Miata also looks also really good and makes sense for combating the heat at the track , ![]() ![]() ![]() ![]()
#3241 | |
| The Following User Says Thank You to FirestormFRS For This Useful Post: | projek_01 (04-13-2015) |
#3242 |
Just so everyone knows, the belt will stretch a bit. I have 600 miles on my car since I installed the charger and set the belt tension to 61hz. Over the last few days the belt slap got more and more, today I had to snug it up again and is back to being nice and quiet again
#3243 |
Add lightness!
Drives: 17' WRX
I wish they just used a spring loaded tensioner. I've adjusted my belt almost everyday since I've installed my kit and started driving my car after winter hibernation. I'm tired of fussing with it.
| The Following User Says Thank You to industrial For This Useful Post: | CSG Mike (04-16-2015) |
#3244 |
@KraftWerks is it common for the belt to stretch a bit initially?
#3245 | |
Drives: The silvertrooper 10 series
-Thomas |
| The Following 2 Users Say Thank You to 86SPEED For This Useful Post: | CSG Mike (04-16-2015), Triumphrider (04-16-2015) |
#3246 |
Drives: 2013 WRB BRZ Sport Tech
is there any other option for the traction fluid then the "rotrex fluid"?? $100 is steep
installing KRAFTWERKS C38 FROM RICKSPECD MOTOEAST TUNE & SKUNK2 ULTRA RAD / SANDWICH PLATE / GRAMS 550cc
JDL UEL PERRIN EXHAUST 2.5" OP 3" CATTED F 3" CATBACK - PERRIN MOUNTS PERRIN PULLEY KIT WHITELINE BUSHINGS WILDWOOD BBK ACT CLUTCH & FLYWHEEL KW V3 MTEC KARTBOY SS SEIBON ROOF SPOILER & FRONT LIP 57XTREME 18x9.5 +40 W/ 255/55/R18 MICHELIN PSS |
#3248 |
I just took my car out and did some logging. A quick question for those more experienced... I had the traction control on when I was doing my logging. And to stay out of sight I was on an older bumpy road. If the traction control kicks in while doing a pull will that effect knock as the engine cuts in and out.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
