#3151 |
Drives: White scion frs
I can't do any logs as I found out this morning that I only brought along my dongle and not the cable. The cable is with all my stuff in route to Florida. I guess I will just have to try to stay out of boost as much as possible and no :burn rubber: for me.
#3152 | |
Professional Smartass
Drives: White Out FRS
| The Following User Says Thank You to post_break For This Useful Post: | Triumphrider (03-28-2015) |
#3153 |
Drives: 2013 Scion FRS in white out
Crank pulley is on, and hoses are all clamped, check valves are in..... Tomorrow morning starts the c38 install! So pumped I probably won't sleep tonite!
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
#3154 |
Drives: 2013 WRB BRZ Sport Tech
#3155 |
That actual install starts tomorrow, just wanted to get the tedious bits done today
#3156 |
Let me say though getting the lines under the intake manifold clamped are a big pia!
#3157 |
Drives: 2013 Ultramarine FR-S
Open to ideas on this, CSG if you're lurking feel free to chime in.
The other day I romped on it and the car felt sluggish. I looked over at my failsafe gauge and the PSI (which is normally ~11psi) was at ~8psi. I figured that since my perrin motor mounts had shaken my oil cooler fittings and bolts loose that they had struck again. I took the bumper off and tightened up all the clamps on the piping and which got the PSI up to ~9. The car feels closer to normal, but still a bit slower than it was. Any other ideas out there? Hoping the blower isn't shot, but it has gotten louder. |
#3158 |
Drives: 1st RBv2 10 Series FRS
quick question. i just installed the updated pulleys, and my new belt. anyone know if im suppose to set the tensioner space to the regular 21mm from the plate to the bolt for tension??? because at 20mm its pretty damn loose!.
waiting for your replies ![]() -edward |
#3159 |
So tomorrow I prime the oil system, obviously you can't let the reservoir run dry... How the heck do you know, you can't see in it?
#3160 |
ok, ive been using the gates carbon drive app on the iphone and android, I keep getting 43hz.
I got 43, 60, 59, 43, 43,43,43 that was me sequence. and im at 17mm from the plate and the bolt. don't know if I wanna go tighter or not
#3161 |
I used the gates app, got 61hz like 5 times in a row, good enough for me
#3162 |
#3163 |
I'm using what ever comes stock with the c38 kit. I'll check when I get home
#3164 |
Oh. Hmm I have the c30.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
