#3095 |
Lacking brains
Drives: frz
i have an sti oil sandwich plate into t fittings in my radiator hoses.
last year at track days in new england summer weather it was helpful but a bit lacking, in a 15-20 minute session i could eventually get the temps into the mid 250s. Running heat on full out the windows did make a difference in taking advantage of the coolant oil cooler. a bit of backing off would quickly get them into the 230-240 range, maybe a better radiator would help? maybe not. Keep in mind new england is also not exactly a hot climate, however at autox i felt the coolant sandwich plate was perfect since it would allow for cooling down after runs in the grid while stationary and the oil getting to temp faster at the start of a session. i was running Pennzoil platinum 5-30 last year, had no issues, may run it again this year, may not. |
#3096 | |
Drives: 2013 Subaru BRZ
What fitting are you planning to use on the top port for the oil cooler? I got my ultra radiator and test fitted it a couple of days ago. This thing is massive. Its going to be a really tight fit for the top oil hose. Do you know what sort of threads the ports in the radiator has? I eyeballed it to 1/2" NPT, but I am not sure. Skunk2 did not provide any info at all, so this will be a DIY. I am hoping that I will be able to use a non thermostatic mocal sandwich adapter I already have. I will have to install it with the fittings pointed against the back, with 90deg fittings. Hopefully it will be room for it. My motor is out for a rebuild, so I wont know before I get it back together. ![]() ![]()
| The Following User Says Thank You to Andreas83 For This Useful Post: | DAN_BRZ (03-05-2015) |
#3097 |
Drives: 2013 Ultramarine FR-S
this might be helpful for those of you with the ultra rad
http://www.spencerfabrication.square...relocation-kit it tilts the rad forward some to help with clearances. |
| The Following User Says Thank You to Freeman For This Useful Post: | Andreas83 (03-05-2015) |
#3098 | |
#3099 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
What's the deal with the c38 blower? Some dude is offer ing a hardly used kit for super cheap. Is the c38 a bit on the fence for a stock motor? I can't understand why his kit has not sold
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#3100 | |
Drives: The silvertrooper 10 series
As far as the Ultra Radiator is concerned, when the customer is ready, we are taking it down to hose specialty shop here in vegas and having them make up custom hoses, the guy claims he will have a fitting to fit in there without cutting.. There is not a lot of room but he said he has a fitting that will work.. when we get it done, we will for sure post up what is used -Thomas |
#3101 |
Drives: 2013 Scion FRS in white out
So in a couple weeks I'm installing a c38 with stock fuelling on my auto transmission. So with the stock pulley what psi should I expect the blower to push? I'm going with moto East tune with a 4 bar map sensor. The only reason I ask is it seems everyone is showing different boost levels with the same set up.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
![]() Last edited by Triumphrider; 03-06-2015 at 04:43 PM. |
#3102 | |
That Guy
Drives: 2013 asphalt FRS MT
Do you know what the cooler consists of? |
#3103 |
Drives: 1996 ST204, Series 10 FR-S
@Boofneenee
From what I gathered, the C38 blower will make less boost in the low RPM range compared to the C30 (maybe look at dyno charts). Up top, the C38 will pull much faster. C38 will also require bigger injectors and maybe a bigger fuel pump. |
| The Following User Says Thank You to projek_01 For This Useful Post: | Boofneenee (03-06-2015) |
#3104 | |
#3105 | |
That quote is from Nov 25 last year, which is 3 1/2 months ago, the process having been started long before that and silent since. Regardless, some folks were told it was approved. Buuuuuuut, it wasn't... ![]() If they get it soon though, great! Took long enough. |
#3106 | |
#3107 | |
Bumped on February 4th. Bumped on March 1st. Finally decided that I'd waited for CARB long enough. 9 months goes by fast... Last edited by SPCorBUST; 03-06-2015 at 08:30 PM. |
#3108 |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
