#3053 | |
Professional Smartass
Drives: White Out FRS
If kraftwerks would have just told us what the belt tension needs to be instead of saying use a sonic tension meter to determine frequency which is pretty damn hard to find. I could buy a belt tensioner tool for less than $20. Waiting on hold with kraftwerks to see if they know the actual tension value. |
| The Following 2 Users Say Thank You to post_break For This Useful Post: | industrial (02-25-2015), SPCorBUST (02-25-2015) |
#3054 |
UPDATE
Have I got some news for you! So Kraftwerks says to tune the belt to 60.70hz and doing so is really difficult for the average Joe. The official machines that measure this are complicated and cost a fortune. Well not any more... So I posted this free android app and got a chance to play with it. It's amazing. It actually works... This is for gates belts for bicycles. Here is my first test... ![]() Way off. So I started to tighten the belt. ![]() After this I locked the tensioner, fired her up, and what do you know... That sound is gone. I can also drive the car around and it doesn't really do it when taking off. ![]() A far cry from the 21mm in the install. Here is a video of what the belt looked like at 21mm and 23hz. [ame]http://youtu.be/J3Z4frpBR_w[/ame] So after all of this I think this method of belt tension should be advised. |
| The Following 10 Users Say Thank You to post_break For This Useful Post: | Calum (03-16-2015), CSG David (02-25-2015), CSG Mike (02-25-2015), glamcem (03-16-2015), industrial (02-26-2015), SPCorBUST (02-25-2015), tnle (04-02-2015), vgi (03-22-2015), Xero-Limit (02-25-2015), zoth (02-26-2015) |
#3055 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | 86SPEED (02-26-2015) |
#3056 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
| The Following User Says Thank You to Xero-Limit For This Useful Post: | glamcem (03-16-2015) |
#3057 | |
Care to mention your impressions in the next vlog update?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#3058 | |
I need to get some logs to moto-mike now that I'm full of e-85 but his tune has been rock solid. If Kraftwerks did the math and came up with 60hz then the belt shouldn't break where it's set now. I trust this application since it's basic math to determine the sound wave. One thing that does bother me though, the tensioner system really sucks on my kit. I over tightened it accidentally and loosening it was a chore. I had to hammer the thing with a piece of wood very hard to make it move at all. I applied some grease to the tracks to see if that would help but it didn't seem to help. Maybe the tolerances are too tight when it's cold. |
#3059 |
Life to short to be slow!
Drives: Toyota GT86
I will be buying in a couple of months, do you guys have any problems? did it works better with a aftermarket header than stock? I have ultimate racing 3" exhaust with 3" overpipe.
#3060 | |
| The Following 2 Users Say Thank You to FirestormFRS For This Useful Post: | 86SPEED (02-26-2015), Xero-Limit (02-26-2015) |
#3061 |
Drives: 2015 frs
Header suggestions? My car literally blew the catalytic converter apart last night. Looking for something quiet, uel?
| The Following User Says Thank You to Derka For This Useful Post: | captain_jack (02-26-2015) |
#3062 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#3063 |
#3064 | |
Drives: 2013 Scion FRS
Quiet is pretty subjective I guess. I purchased open flash header #11 and had it on my car for two weeks before my wife asked that I change it back. I tried it with stock exhaust and with my Q300 and it was too loud for my suburbia neighborhood with ally garages. Was a great header and might be quieter than other cat-less headers but I think I'm stuck with the cats unfortunately
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#3065 | |
Drives: 2015 frs
#3066 | |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
