86WORX
Old 01-06-2015, 08:47 PM   #2703
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Originally Posted by SPCorBUST View Post
That's interesting, considering those are completely normal numbers when adjusted to a dynojet - I made essentially the exact same numbers with a standard KW belt, lower boost and only 550cc. With 4 more pounds of boost from the high boost pulley and 350 extra cc that's disappointing.
We are also at 2200 ft elevation.. down in LA the car is even more intense. The fuel injector size shouldn't matter unless your running out of injector. Also the RPM on his Dyno showed 7340, and my car, EcuTek both show 7750 and thats when its at the 19 psi (18.7 to be exact).. According to the AEM fail safe, i honestly don't how accurate it is, if I'm having the Auto trans slip or not at 7300 RPM its just over 16lbs due to what Church said was a spike right around the 7300-7400 rpm mark, he said it is either the ecu telling the trans to shift or its slipping, on the street i do not notice it.
And the last issue, my car is not as easy to tune as others, the car runs great on the tunes, but all but Moto-East had start up issues, and its always had them before the E85. now that its cold i really havent had a issue with it, but thats why we assumed it may be a fuel pump issue. I do have a Map from Bill that is a little leaner, but it had more start up problems then the one i have now. We have chalked it up to the ECU swap that Toyota did, as i saw personally the same tune work on another car with the exact same set up, but wont run for crap on mine.. Kit wise no issues, but the tune has been a nightmare with my car. It may or may not have anything to do with power, but Church said there was more power in it for the lack of timing and as rich as it was.. right now im happy with it.
-Thomas
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
SPCorBUST (01-06-2015)
Old 01-06-2015, 08:54 PM   #2704
SPCorBUST
SPCorBUST's Avatar
Definitely seems like a lot of factors to be considered. Don't think (could be wrong) elevation is an issue since psi is the same everywhere, like pounds. (By poundsI mean weight) I believe it's only an issue with NA cars really, but someone else is (most likely) more knowledgeable about this than me, and like I said I could be dead wrong about that. Either way I'm sure it is in beast mode with more left on the table, especially after how you've explained it. Good luck with the tuning, looking forward to those maxed out numbers!
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
86SPEED (01-06-2015)
Old 01-06-2015, 09:07 PM   #2705
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
So need opinions here. Who has the c38 with a header that is running a delicious flash n go, or the moto East tune.. Opinion on drivability and any numbers on power? Trying to decide on which tune for my spring install. I'm keeping my stock injectors as well.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 01-06-2015, 09:31 PM   #2706
86SPEED
86SPEED's Avatar
I have been told, but havent verified it, as when i was down in LA my AEM shows AFR instead of boost and i didnt bring the laptop to swap it over, but ive been told that a turbo does not make a different, a 8Lb wastegate will open at 8lbs, but a super charger does make a different, there was a guy here with a Vortech and lived in denver, there he was around 8lbs i believe even though he had the same 11lb pulley that everyone else was running around 11psi, when he went down in altitude he did pick up another pound but said he never got down to sea level. Ill try and find his thread on here. id assume its the same as when its colder compared to hotter, the air is more dense so we make more Lbs when its colder..
-Thomas
Old 01-06-2015, 09:37 PM   #2707
86SPEED
86SPEED's Avatar
Ill say you cant go wrong with either, Both my tunes have been good, and ive been in cars with both and they both feel good. I have to see them in person, or spend a ton of time back and forth to fix my minor issues that are more the car then the tune. The customer service from both have been great, bill always emails me back as soon as he can, Mike always picks up his phone when i call. We deal with both regularly, so its hard to point to just one as they both are great to work with. I may point a bit towards Moto-East due to them using a bit more direct injector and with bill i had to up my port injectors, but that's because of my levels and E85, I'm sure bill could've got me covered if i was on the regular pulley and pump gas.
What i would do is call them each or reach out and see which one gels better with you. they both make good tunes with good power. See which one clicks better, It's never a bad thing to have a good relationship with your tuner
-Thomas
The Following 3 Users Say Thank You to 86SPEED For This Useful Post:
CSG Mike (01-07-2015), doberman8u (01-06-2015), Triumphrider (01-07-2015)
Old 01-06-2015, 11:38 PM   #2708
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
-Thomas
moto east for sure
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
Rulin (01-06-2015)
Old 01-07-2015, 09:51 AM   #2709
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by vgi View Post
"I believe" - so was it Airboy or you're not sure? Is it ecutek tune or raw bin file tune done with ecuedit or romraider (or oft)?
I am not sure, that's why I tagged Airboy in it to see what he says.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-07-2015, 09:58 AM   #2710
Derka
Drives: 2015 frs
Today starts my install, any last minute pointers?
Derka is offline   Reply With Quote
The Following User Says Thank You to Derka For This Useful Post:
Old 01-08-2015, 06:13 PM   #2711
Derka
Drives: 2015 frs
Any tricks on bleeding? Followed the instructions but no fluid out of the "out" port yet. Haven't started the car yet either
Old 01-09-2015, 01:55 PM   #2712
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I honestly don't know how you guys with the C38 do it. I've got the C30, low boost pulley, and with E85 I'm spinning most of 2nd gear. 1st gear is scary unless I can get it to hook up. And when it does hook up, I'm getting tunnel vision from how fast I'm approaching warp speed.
That said Moto Mike has really dialed in my car. Even on pump gas it feels so much faster than the other 3 tuners have tried on my car.
Next up is the skunk 2 radiator and mishimoto thermostat and I'm ready for the summer heat.
post_break is offline   Reply With Quote
Old 01-09-2015, 02:10 PM   #2713
doberman8u
Drives: 2013 FR-S, 2004 Z06
As a potential buyer, you just hit on the reason I would not consider the c38. If I get this kit, it would be the c30 with high boost pulley at most based on feedback from guys like you, @Taino-BRZ, and several others. I realize the power gains of the c38 but as a middle of the road, bump in power buyer I cannot come to terms with the idea that more power than what Taino-BRZ is putting down would require so many other upgrades that go far beyond just clutch and injectors to stick it to the road reliably.
He states he expects to get low 12's or maybe even high 11's out of his setup and I cannot expect the car to hold up very well much past that and I wouldn't think that most people that bought the car could realistically expect to gain much more than that without huge expenses...and at that point you are in a whole different tier of cars that you could/should have bought if you expect reliability.
The kw c30 is at the top of my list.
doberman8u is offline   Reply With Quote
The Following 2 Users Say Thank You to doberman8u For This Useful Post:
Chad86 (01-16-2015), Triumphrider (01-09-2015)
Old 01-09-2015, 02:18 PM   #2714
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Originally Posted by doberman8u View Post
As a potential buyer, you just hit on the reason I would not consider the c38. If I get this kit, it would be the c30 with high boost pulley at most based on feedback from guys like you, Taino-BRZ, and several others. I realize the power gains of the c38 but as a middle of the road, bump in power buyer I cannot come to terms with the idea that more power than what Taino-BRZ is putting down would require so many other upgrades that go far beyond just clutch and injectors to stick it to the road reliably.
He states he expects to get low 12's or maybe even high 11's out of his setup and I cannot expect the car to hold up very well much past that and I wouldn't think that most people that bought the car could realistically expect to gain much more than that without huge expenses...and at that point you are in a whole different tier of cars that you could/should have bought of you expect reliability.
@post_break what made you choose the Kraftworks kit over Jackson Racing?
Chad86 is offline   Reply With Quote
Old 01-09-2015, 02:27 PM   #2715
post_break
post_break's Avatar
I don't like their belt setup. And I got the kraftwerks kit at a discount.
Old 01-09-2015, 04:48 PM   #2716
86SPEED
86SPEED's Avatar
I have a Auto, with over 400hp it spins in 1st.. in fact its useless lol, it spins in second around 4k-4500, in 3rd around 5-6k and depending on the road here in Vegas it will spin 4th above 7k. this is with the 245 toyo proxes 1, not the best tire but still suppose to be a good one, my next set up will be 265 Michelin PSS, i hear they are sticky and have decent mileage. Im also going to get some camber taken out of the back to put more rubber on the road.
until then
I cant imagine what 500+ turbo cars do.. people say this is how the car shouldve come and i disagree. People are putting them in ditches and curbs with 160 hp at the wheel, they dont need 300+ lol. A great tuner here in the 86 world, said 250hp at the wheels is perfect for this car, 300hp is the limit, anything more is just a "manhood" measuring contest. and as much as i spin the tires, and hunt for traction i kinda believe him..
-Thomas
DAN_BRZ (01-11-2015), Rulin (01-09-2015), Scracho (01-09-2015)
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
