Old 02-15-2014, 11:20 AM   #253
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
He did the delicious tune, although the whole thing was rather rushed. Hence why we're here and this morning Bill and I are nailing it down :P We want only the best for you guys.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
CSG Mike (02-15-2014)
Old 02-15-2014, 02:49 PM   #254
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Guys if I have headers, overpipe, exhaust and ecutek currently 186whp what can I get if I install the Kraftwerk's with delicious tune?
kombatlion is offline   Reply With Quote
Old 02-15-2014, 02:51 PM   #255
Zach3794
Depends on the dyno, and also depends on the individual car. Every car is different in other news, I am on the dyno with Bill @Delicious Tuning. So far we have made good power over the base map on the first pull! E85 to come later today.
Old 02-15-2014, 02:52 PM   #256
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
There is not an average WHP gains?
Old 02-15-2014, 02:54 PM   #257
Zach3794
Percentage gain would be much better to go off of. I don't have a baseline of my car on the same dyno as we are on so I can't give exact numbers, although most people seem to be getting 265-285 variable on dyno and header.
kombatlion (02-16-2014)
Old 02-15-2014, 09:07 PM   #258
Zach3794
At the end of the day I do have some news. Off of the base map that the majority of you have, we gained 15whp additional and smoothed everything out. We then added E85 to the mix and gained an additional 45whp. This is all done on a mustang, where my car base lined at 215whp. Percentage wise, the gains are very nice and the car pulls smooth, yet noticeably stronger than the base KW kit. On your average dynojet, what this all reads out to is ~275whp on 91, and ~332whp on E85.
Now for the inevitable news that no one wants to hear. We did start getting clutch slip on E85, and only at the last 1000rpm. I'm not qualified to say the second part but I'm guessing we're about at the limits of the stock port injectors at 332whp on E85 as well, and will probably need to upgrade those soon as well.
All in all I'm guessing that we won't be adding a smaller pulley (90mm) or header to the mix until I can upgrade the clutch and injectors, which should only be a few weeks to a month at most until I can do that. The car pulls ridiculously hard in my opinion, and is a blast to drive all around.
P.S. - Anyone have clutch recommendations? Thinking of the Exedy Stage 2 as I can get it at cost, just not sure if it'll hold.
The Following 2 Users Say Thank You to Zach3794 For This Useful Post:
Sonolin (02-15-2014), TrogDor the Burninator (02-16-2014)
Old 02-16-2014, 01:54 AM   #259
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm curious about the tune in that let's say I'm running 91 because that's all I get in Kansas City ... But at my NASA events I run 100 octane ... Will I see any additional benefit from the boost in octane in the new tune? Will their be additional maps provided?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 02-16-2014, 02:32 AM   #260
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Someone correct me if I'm wrong but I believe the ECU will detect the better gas and advance the timing and in turn get more power but a specific tune isn't necessary. But I'm not certain so as I said, someone correct me if I'm wrong.
digital_assassin is offline   Reply With Quote
The Following User Says Thank You to digital_assassin For This Useful Post:
Old 02-16-2014, 02:34 AM   #261
Zach3794
It should adjust to a certain extent. If you ask I'm sure bill would be able to make you a 100 octane map separate as well.
Old 02-16-2014, 02:52 AM   #262
jamesm
The ecu never adds timing beyond what's in the base and advance maps. It may take less away, which would have the same effect, but ideally rthe car shouldn't be pulling timing in the first place. Guys on 91 are more likely to see knock correction even on a mild tune, though in which case better gas would 'add timing' depending on how you look at it.
Old 02-16-2014, 09:04 AM   #263
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
I asked William about this very issue yesterday and he replied that the KW tune is 91 optimized and will not take advantage of higher octane.
I did not think to ask, but if I understand ecutek correctly, map switching on the fly is straight forward, so perhaps a 91/100 (or 91/93) option is possible?
Ralph Spoilsport is offline   Reply With Quote
Old 02-16-2014, 06:23 PM   #264
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
How does everyone get a hold of William? The struggle is real right now, I need a map lol.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
PRORICAN (02-16-2014)
Old 02-16-2014, 06:28 PM   #265
Zach3794
Well considering it's a Sunday, good luck. Bill, like most people, needs a life outside of work and Sunday is generally the day that someone will avoid for work if they have to pick one day out of the week. Aside from weekends, I believe he does have a ticket system available on his website, doesn't he? He's also quite busy strapping on an innovate kit on his personal car today :P
Old 02-16-2014, 06:31 PM   #266
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Submitted a request/purchase Friday night, he let me know that I'd have the map by today(morning).
Omar GC
Instagram: 2jzus
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
