#2353 |
Drives:
Couldn't have said it better myself
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#2354 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Maye i missed it but will kraftworks plan to offer a base map tune with its new header?
***nevermind found the answer
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#2355 | |
Drives: Kraftwerks BRZ
At some point we will look to having a Base Map surrounding the header. We're currently focused on securing the CARB certification and only developing tunes based around that configuration. |
#2356 | |
It's been an awfully long time. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | JDMChris (11-24-2014) |
#2357 | |
why are you so concerned with Kraftwerks CARB approval anyways?...somehow i doubt it is altruism that motivates you if you doubt KW will come out with CARB approval, just say it...but then again even you know that such statements are libelous. btw....hows that JR high boost pulley coming along?...sure seems like a long time to make something as simple as a smaller pulley...or maybe its not as simple as that....maybe there is something fundamentally flawed with the JR layout that prohibits a 'simple' high boost pulley change. even if they do figure it out, with their current layout, you can forget about ever running the c38. |
#2358 |
Drives: The silvertrooper 10 series
I have a dyno day coming up, cant wait to see what it puts down.. 408 was what another guy did here on E85 at 16psi, im on E85 at 18.3-18.8psi depending on how cold it is here. ONLY issue i have now really is my lack of fuel mileage. on this Delicious tune i am at 15mpg or so, and 11 if im out messing around.. there are some slight things here and there Bill is working on, but the car runs great and will spin the tires up in the top of 4th now no problem.. looking at moving from the 245/40 Toyo Proxes 1's to some 265/35 PPS to fix that problem
here is a screen shot of my AEM failsafe from my ride this morning ![]() -Thomas |
#2359 |
Man-ape
Drives: 2013 Buddy Club Scion FR-S
Kraftwerks please hurry I want my factory header back! Haha seriously though hurry up.
#2360 | |
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2361 | |
Go-Kart Enthusiast
FRS
#2362 | |
Or read the other threads. I give everyone the same pointed questions Why am I so concerned? Because Kraftwerks has a proven history of not delivering on CARB promises. Do you really want me to start digging up posts from other platforms, starting in 2008? I've also been pulled over for emissions testing in the shop car, and, well, if we had a Kraftwerks kit instead of a CARB legal option, it wouldn't have been pretty. Instead, we paid $8.75 for a certificate at the state ref, and went on our merry way. |
#2363 | |
Drives: 2013 Ultramarine FR-S
Sent from my SAMSUNG-SGH-I317 using Tapatalk |
#2364 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Kraftwerks Supercharger Owners Thread
As much as I find the pissing contest between gmsii and CSG Mike annoying a lot of the time, I really appreciate CSG Mike's constant poking at this CARB thing. I really love driving around with my KW kit (which I've basically had zero problems with after 8 months and 7500 miles), but I really want to know if I will ever get CARB approval.
| The Following User Says Thank You to mit_peid For This Useful Post: | mitosis (11-26-2014) |
#2365 |
Drives:
Here's a simple little change of subject... ;-)
After the install, is it safe to start the car with a standard NA tune simply to check for leaks/issues??
My STX build thread
#2366 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
...if it starts. Cranking is dependent on the MAP signal, and since your sensor won't be calibrated it very well may not start.
| The Following 2 Users Say Thank You to Xero-Limit For This Useful Post: | mitosis (11-26-2014), xDanger_208x (11-25-2014) |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
