#2199 | |
Drives: Kraftwerks BRZ
#2200 |
Professional Smartass
Drives: White Out FRS
Painted the custom grill we made.
[ame="https://www.youtube.com/watch?v=0huMlzzP-Vs"]Vlog 20 Custom grill - YouTube[/ame] |
#2201 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Not sure if the owner is on here, but this is a c38 kit with stock fueling, remotely tuned breaking 300 whp on pump gas!
![]() Dyno charts courtesy of Hux Racing in Alabama, hit them up if you are looking for a competent installer.
| The Following 17 Users Say Thank You to Xero-Limit For This Useful Post: | 86SPEED (10-20-2014), Calum (10-19-2014), Chad86 (01-16-2015), djdnz (10-19-2014), Dream20b (10-21-2014), DriftinFRS (10-19-2014), Freeman (10-18-2014), Gixxersixxerman (10-19-2014), glamcem (10-21-2014), gmsii (10-20-2014), John92 (10-19-2014), JonAvalon (10-23-2014), KraftWerks (10-22-2014), myd_lyf_crysys (10-19-2014), Mykii (12-21-2021), syrs_finest_frs (10-19-2014), zoth (10-19-2014) |
#2202 | |
Y u do dis?
do you know about any additional mods?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#2203 |
Drives: Mr2 Turbo
| The Following 4 Users Say Thank You to N.O.B For This Useful Post: |
#2204 |
Drives: 2013 Ultramarine FR-S
#2205 |
Drives: Mr2 Turbo
#2206 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Just a update on my car and kit.
So after a few thousand miles running the 70mm SC pulley and the belt having some slap on the lower mount it finally gave out.. I already knew the belt wouldn't last, KW let me know that Gates stated after approving the belt, and testing they came back with not advising using the smaller 70mm pulley. Being a Gates dealer and getting the belts cheap I still went this route. The automatics just need that little more oomph so I wanted a higher boost pressure. I changed the belt and we also did a video on how to change the belt without removing the SC as it seems to be a common myth that this charger has to come off to change belts.. So new belt and all car was running good, it does have some start up issues sometimes, not really sure what it is, but some times it sputters and dies like it's really really rich.. Other times it fires right up. Last week I talked to Joe at KW and he let me know the new pulley kits are out, so I ordered three up.. These are bigger pulleys so not to cause belt problems on the smaller pulley for the high boost setup.. I'm running a 128mm I think and a 85mm instead of the 90mm for even more boost. At 7400 before I was at 12.5 at the ~3k elevation and now I'm at 15.9. We are also going to run up to 8k on the flex fuel running E85.. Finally today my car seemed fast.. I've driven the other 2 kits (C30 and a C38 on high boost) and my car always seemed lacking.. Finally since owning I wished I got the manual.. But the ride home changed all that.. First always spun the tires at the top end, but now second does as well, and it even chirped 2nd.. The car just came alive.. I didn't get on it to much as it's not mapped for the extra couple lbs, but AFR never went above 11.7 so I felt a little safe taking it up until I finally hit redline.. I won't be taking pump gas to 8k as I don't think the engine will handle that.. 15.9lbs. at 7400 so it will be well over 17lbs. at 8k and that's alot to ask of 91 pump.. Just wanted to share my progress, good or bad I don't mind posting up.. Being a dealer for the kit I still don't mind pointing out negatives, but so far the only negative I've had was Church almost/did ruin my motor.. Otherwise no complaints about the kit that I wasn't already warned about.. |
| The Following 9 Users Say Thank You to Gixxersixxerman For This Useful Post: | Calum (10-23-2014), digital_assassin (10-27-2014), Dream20b (10-24-2014), Freeman (10-23-2014), kbogarto (10-23-2014), myd_lyf_crysys (10-26-2014), Sellout (10-23-2014), SPCorBUST (10-23-2014), vgi (10-25-2014) |
#2207 |
Drives: 2013 Subaru BRZ Sport-Tech
what are you guys running for aftermarket headers and exhausts for your setup? does skunk2 have an offering yet, presumably ideal for the KWSC kit?
#2208 |
WRX -> BRZ. (TX)
Drives: 2015 Series.Blue WRB
I have a Ark GRiP with the catless test pipe and it feels and sounds great. Haven't put the car on the dyno yet, but the power is great so far with the c30-94 kit
Sent from my Nexus 5 using NASIOC mobile app
KraftWerks c3094 SC Kit ARK GRiP w/ test pipe KW V3 OEM Audio + Reference 400CF |
| The Following User Says Thank You to Rulin For This Useful Post: | wahsaihin (10-27-2014) |
#2209 |
Drives: 2013 FR-S Matte Orange
This would be good content to add to the first post. Can you please drop a link to the video so I can add it.
#2210 |
Yes.. Video should be ready by the end of the week.. He is doing the editing and all between his job and his YT channel stuff.. I'll post up once it's ready
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | digital_assassin (10-27-2014) |
#2211 | |
Their header is coming is what I was told. Don't remember if there was an ETA or not. My current exhaust set up is: JDL autodesign UEL Nameless Performance 3 inch carted and resonated OP/DP Perrin Performance 3 inch resonated catback |
#2212 |
Car is running great in this cooler weather. Can't wait for Delicious new revisions and flex fuel tunes to drop.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
