Old 08-21-2014, 12:32 AM   #1975
CSG David
CSG David's Avatar
Originally Posted by zoth View Post
Same here, my POS Borla UEL is leaking like a mofo. Getting a EL this time. Hoping to get more out of the EL.
It's weird how the header just crap on me out of the blue. Using all new gaskets.
Which EL?
The Following User Says Thank You to CSG David For This Useful Post:
zoth (08-21-2014)
Old 08-21-2014, 12:36 AM   #1976
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by CSG David View Post
Which EL?
Still Borla, if that is a POS as well I'll just ask for a refund and most likely get a Tomie EL. Million Mile Warranty $hit.
BTW: this will be the 3rd under warranty.
Your working late aren't you?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-21-2014, 12:59 AM   #1977
CSG David
CSG David's Avatar
Always working. Limited time and manpower to get data and information for the masses.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
Calum (08-21-2014), Freeman (08-21-2014), zoth (08-21-2014)
Old 08-21-2014, 01:37 AM   #1978
The work never ends when you're actually r&d'ing
Old 08-21-2014, 12:17 PM   #1979
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by post_break View Post
Hope you have a spare, they are kinda rare. I had to wait for mine to come in.
Gates TP1200-8MGT-20 Belt
I don't and I just learned it's backordered :/ which is really a bummer since I had some planned events this month and in September.
How did you install the replacement belt? I am thinking I can install it without removing the brackets or the Supercharger from the gap between pulleys and the engine
glamcem is offline   Reply With Quote
Old 08-21-2014, 12:23 PM   #1980
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
You have to pull the plate holding the supercharger off. I think it's impossible to install it without removing the plate. Get a friend to help. I'd send you my spare belt but it's been chewed up when the pulley came off. It's for emergencies only.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
glamcem (08-21-2014)
Old 08-21-2014, 12:40 PM   #1981
glamcem
glamcem's Avatar
How bad is that do you have a picture of it? And how did the pulley come off?
If its not too bad i wpuld gladly take it from you until i receive my replacement in case of emergency our cars wil work without the belt
Old 08-21-2014, 12:51 PM   #1982
post_break
post_break's Avatar
The crank pulley bolt started to come out. It's chewed up on the side, I wouldn't run it longer than I'd have to, and definitely not on the track. I keep it in my trunk should the one I have snap.
Old 08-21-2014, 12:54 PM   #1983
gmsii
gmsii's Avatar
as a general informational point....the pic of the belt and how it broke indicates a sudden change in load (ie missed downshift)
gmsii is offline   Reply With Quote
Old 08-21-2014, 12:55 PM   #1984
zoth
zoth's Avatar
Originally Posted by KraftWerks View Post
Thanks for the kind words @Taino-BRZ
We've got a few (6-7 depending on how many orders came in today) complete oil-cooler kits available right now. Contact us if you are in need of one. They retail for $579.99, you guys will get a discount of course.
@KraftWerks, Ready to buy, but the online store is not taking my coupon code.
Old 08-21-2014, 12:56 PM   #1985
glamcem
glamcem's Avatar
Got it if that's bad I wouldn't even bother try installing it since the car runs without the belt with no problem and it takes some effort to put it back in ..
Old 08-21-2014, 01:07 PM   #1986
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Check your PM! We'll get this sorted out for you!
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
Old 08-21-2014, 01:11 PM   #1987
You mean missing the gear and going into neutral? Because a money shift would have blown the engine.
Isn't a sudden change in load what happens every time you shift hard, whether it's a down or up shift?
Old 08-21-2014, 01:15 PM   #1988
glamcem
glamcem's Avatar
I think it was just a defective unit since I am really careful with my downshifts and really don't remember when was the last time I missed a downshift .. and I am a very unlucky guy if there is a 2% failure rate it almost guaranteed that I am always in that 2 percentile
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
