Old 08-07-2014, 10:52 AM   #1891
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by Freeman View Post
I lost none, the oil cooler I was taking about is the engine oil cooler. Now engine oil..... yeah I lost a lot.
Sorry if did not make my self clear. Did you loose some during relocating the blower oil cooler. I assume you need to add and cut the lines for the new placement.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
Freeman (08-07-2014)
Old 08-07-2014, 10:59 AM   #1892
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Ahh I gotcha. Yeah you have to relocate the blower oil cooler to the passenger side of the AC condenser area, and turn it on its side. So the fittings instead of being horizontal, they are now vertical(ive checked multiple times because that stuff is so expensive, and there has been no leaking of blower oil). You don't need to remove the lines to do this, but if you trim up the lines I would do it from the top end of the lines.
Freeman is offline   Reply With Quote
Old 08-07-2014, 03:28 PM   #1893
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by Sellout View Post
Only thing I can think of is maybe the hose that was shipped out isn't correct for the application and expands a little too much under pressure. Obviously the push-lok hose has to stay tight as hell to keep it from flying off those fittings under pressure.
Here's what Parker says in the push-lok manual
I'm sure you've got to try pretty hard to get that hose shoved into place properly...
Originally Posted by Poodles View Post
True push-lok (or loc) hose and fittings shouldn't have these issues...
Originally Posted by nlowell View Post
Both times the car was shut off instantly when the lines blew so I'm fairly confident that the car is fine. I'm now questioning the SC oil lines. What kind of pressure do those see? Are the spring clamps enough?
Btw, I'm loving the KW SC kit and the power! It's a shame this happened with the oil cooler because I'm really happy with the rest!
I'm so paranoid after the brake lines though that I keep thinking I hear other noises.
For instance, after a WOT run I hear a flutter at cruise speed. It shouldn't be the bypass because I'm only running 3k or so and not varying speed. The flutter increases with RPM. It's almost like a belt or pulley flutter noise but the belt is taught and the pulleys are spinning true. I'm going to have Mike at Infamous check everything over tomorrow just to be sure
Those are pretty
Hopefully there's no unseen long term damage from the oil lines popping off.
Proven otherwise - please revise your kit before sending more out. Not trying to be an ass I just don't want other to go through what we had to. Luckily no perm. damage was done.
Yeah, fixing the pictures hasn't been too high on my priority list. KW has the pictures. I can guarantee they aren't as juicy as people think.
While examining the installation of these instances and looking at what was received, both customers happened to receive product that we had yet to have the fittings installed prior to shipment. This leaves the installation completely up to the end-user thus a room for error without proper installations on how to install the fittings onto the hose which were not provided at the time of these two purchases.
Although we do not manufacture the fittings nor the hose, we stand by the manufacturer's information and advertising. Both the hose and fittings, once properly installed, will support 250 psi without the need for a clamp. The hose manufacture themselves specifically states, "Never needs a clamp."
In order to alleviate this in the future, we have connected and secured each of the items in stock so that any current or future order will leave assembled in terms of the fittings and hose.
We are also taking extra measure by pressure testing each hose and fitting ourselves to ensure the stated quality and fitment is there moving forward. We are currently up to 160 psi in our testing with absolutely no issues thus far and are continuing to push the bar higher.
Getting back to the 2 customers involved, both Freeman and nlowell have been in direct contact and we are working with each of them individually. We're striving to assure that both of them as well as their vehicles are sound after the issues and are negotiating compensation for both time and money lost thus far in a fashion that best suits their needs individually.
KraftWerks is offline   Reply With Quote
The Following 8 Users Say Thank You to KraftWerks For This Useful Post:
captain_jack (08-07-2014), D-VO (08-08-2014), Freeman (08-07-2014), nlowell (08-07-2014), Sellout (08-07-2014), SPCorBUST (08-07-2014), Xero-Limit (08-07-2014), YouLikeFresca (08-08-2014)
Old 08-08-2014, 05:41 PM   #1894
grostoine
Drives: Subaru BRZ
I'm looking to buy the upgrade pulley for 13psi. What will I need ? I'm currently on stock clutch, fuel injector and pump. Will i need to change all of that or it's possible to run those stock component.
I only do occasional spirited driving... Not extreme at all. Just looking to get the best out of my kit !
grostoine is offline   Reply With Quote
Old 08-08-2014, 06:56 PM   #1895
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I bought the pulley from KW but never installed. My understanding is that you can simply swap in the pulley and just use the existing KW tune. Maybe one day I'd be motivated enough to install. The dynos seem to suggest up to a 25whp increase on the top end.
mit_peid is offline   Reply With Quote
Old 08-08-2014, 07:06 PM   #1896
Jcl
Drives: 2014 BRZ
How much was the pulley?
Jcl is offline   Reply With Quote
Old 08-08-2014, 07:08 PM   #1897
Freeman
Freeman's Avatar
That was my understanding as well, but I don't really have the guts to do that. I have the Pulley at home on the shelf, not sure if I'll install it or jump to the C38 instead
Old 08-08-2014, 10:23 PM   #1898
mit_peid
Boosted Noob
mit_peid's Avatar
About $100
The Following User Says Thank You to mit_peid For This Useful Post:
Jcl (08-08-2014)
Old 08-08-2014, 11:39 PM   #1899
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I maxed out my stock injectors with the base C30 pulley at ~7k RPM. Injectors are now on my short-list.
nlowell is offline   Reply With Quote
Old 08-08-2014, 11:50 PM   #1900
SPCorBUST
SPCorBUST's Avatar
Completely forgot about the pulley. Now I know I for sure I could break 400whp.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 08-08-2014, 11:51 PM   #1901
Freeman
Freeman's Avatar
On which blower?
Old 08-08-2014, 11:55 PM   #1902
SPCorBUST
SPCorBUST's Avatar
C38. I hit 385 already stock motor. Perhaps 450 is doable with the pulley, headers, overpipe, downpipe, and an aggressive tune. Certainly plenty of room left in the injector size I went with.
The Following User Says Thank You to SPCorBUST For This Useful Post:
Freeman (08-09-2014)
Old 08-09-2014, 12:24 AM   #1903
Freeman
Freeman's Avatar
And you're on corn right?
Old 08-09-2014, 12:25 AM   #1904
SPCorBUST
SPCorBUST's Avatar
Yes. Wonder what else can be pulled out with motor work. If only it was as easy as that Racing Rivals game, lol.
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
