86WORX
Old 07-14-2014, 07:26 PM   #1779
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by D K View Post
Has KW done any actual testing with the big blower?
Of course we did testing with the C38! The thread has moved pretty fast, but we shared some early dyno results probably 20-30 pages back, prior to releasing the kit to the public. We also run the C38 on our own personal shop car.
KraftWerks is offline   Reply With Quote
Old 07-15-2014, 12:46 AM   #1780
D K
Stig's dark passenger
Fantastic!
Ill try to find it.
D
D K is offline   Reply With Quote
Old 07-15-2014, 10:43 AM   #1781
Squishy
Drives: 2013 WRB BRZ
@digital_assassin I installed my kit July 7.
Tune by Delicious Tuning (93 and 91 octane maps with launch control and auto blip feature), stock header/exhaust, ROBISPEC radiator/oil cooler.
Perhaps there will be a header added later but staying stock on exhaust for now - I like the quiet.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 07-17-2014, 09:59 AM   #1782
FR-S Matt
Stock radiator fans sufficient with any of the aftermarket radiators? Just asking before I put mine on this weekend. Not sure I can justify getting aftermarket ones as I think the radiator itself will do the job. Once this goes on, it's supercharger time!
The Following User Says Thank You to FR-S Matt For This Useful Post:
Scottemad123 (07-17-2014)
Old 07-17-2014, 10:13 AM   #1783
captain_jack
captain_jack's Avatar
If day they are adequate, but having a bigger fans couldn't hurt, depending on the cost. I haven't priced them myself
Old 07-17-2014, 02:55 PM   #1784
In our testing, aftermarket fans on a stock radiator generally have proven to work better than stock fans on an aftermarket radiator.
Downside is the fans are louder.
FR-S Matt (07-17-2014)
Old 07-17-2014, 05:08 PM   #1785
FR-S Matt
Now I guess the question that could prevent me from installing the radiator from this weekend... fans easily doable with just intake removal or am I going to have to remove the entire front bumper and disassemble again? It's not crucial I have them right away, I just don't want to have to double back and disassemble something that I just put together like the SC kit, hence doing the radiator beforehand.
Old 07-17-2014, 05:12 PM   #1786
rickspecd
rickspecd's Avatar
Drives: 2013 Scion FRS
Hey crew, I have some kits in stock if your looking for a good price on one just let me know!
Rick
rickspecd is offline   Reply With Quote
Old 07-17-2014, 05:16 PM   #1787
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Which fans specifically and how were they mounted?
post_break is offline   Reply With Quote
Old 07-17-2014, 05:16 PM   #1788
Iirc, you have to unbolt the top of the bumper to get to the metal support that goes down behind the middle of the fans. Other than that, no other work on the front end itself.
You'll have an easier time taking the fans off with the radiator out of the car; I've personally never done fans without taking the rad off.
Old 07-17-2014, 09:15 PM   #1789
Calum
That Guy
Drives: 2013 asphalt FRS MT
Which radiator fans have you used? Are aftermarket fans with the stock radiator sufficient for your use? Do you feel they would be sufficient for spiritedly driving DD?
Old 07-17-2014, 09:16 PM   #1790
SPAL.
Even stock should be sufficient for spirited street driving.
Old 07-17-2014, 10:58 PM   #1791
noob001
Drives: frs
Does anyone know what size the banjo bolt washer is? i have a slow leak at the reservoir and can't seem to fix it by tightening down the nut or moving the banjo fitting around.or any ideas on what i can try beside replacing the banjo washer?
noob001 is offline   Reply With Quote
Old 07-18-2014, 12:45 AM   #1792
FR-S Matt
SPAL.
That's what I'll most likely be doing. I'll keep the stock fans and just monitor the temps.
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
