Old 06-24-2014, 09:54 PM   #1653
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Calum View Post
My ring finger is a size 14.5... My hands barely fit in the engine bay, let alone between the runner of the intake manifold.
You don't put your fingers in there. your fingers stay on top of the manifold.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
sw20kosh (06-24-2014)
Old 06-24-2014, 11:53 PM   #1654
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Does anyone knows the calibration for the denso 078900 5410 map sensor that came with the kraftwerks kit? We are trying to tune and can't find it anywhere is for Hondas..
Taino-BRZ is offline   Reply With Quote
Old 06-24-2014, 11:55 PM   #1655
Taino-BRZ
Taino-BRZ's Avatar
Size:  72.2 KB this one
Old 06-25-2014, 12:29 PM   #1656
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@nelsmar and @jamesm
Old 06-25-2014, 12:30 PM   #1657
FR-S Matt
I got an OMNI 3-Bar map sensor just the other day. I have no idea what it would be.
Old 06-25-2014, 01:08 PM   #1658
zERoTu
Drives: 1st RBv2 10 Series FRS
Originally Posted by SPCorBUST View Post
Still don't know why everyone had a hard time with those. Just loop a zip tie around a line, push it to the back and tighten it down. You can use the hole between headers to pull the loop tight. I'm at 15psi I never had a blowout, makes no sense to go through all this trouble for the same outcome.
which hoses are u referring to? i only did the ones under the intake manifold.
zERoTu is offline   Reply With Quote
Old 06-25-2014, 03:22 PM   #1659
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Originally Posted by zoth View Post
Sounds like you have the smooth pulley's?
no i have the toothed pulleys on.
does anybody know if the stock MAP sensor can also be rescaled so it can read about 1bar/15psi? stock it seems it can read up to 0.4bar
ST-A is offline   Reply With Quote
Old 06-25-2014, 03:30 PM   #1660
FR-S Matt
Doubtful. Everyone I know that has boosted has changed sensors due to the stock one being for N/A.
Old 06-25-2014, 05:57 PM   #1661
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Here you go @Taino-BRZ!
Pressure offset is -.045
Voltage is .367
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
Taino-BRZ (06-25-2014)
Old 06-25-2014, 06:20 PM   #1662
SPCorBUST
SPCorBUST's Avatar
Those are the ones I was referring to
zERoTu (06-25-2014)
Old 06-25-2014, 06:26 PM   #1663
Taino-BRZ
Taino-BRZ's Avatar
I want to point out the great customer service from @KraftWerks and @DeliciousTuning always a fast answer whenever you need something. Keep it up guys. I just received my cogged pulleys btw.
The Following 2 Users Say Thank You to Taino-BRZ For This Useful Post:
DeliciousTuning (06-25-2014), KraftWerks (06-25-2014)
Old 06-25-2014, 07:35 PM   #1664
KraftWerks
KraftWerks's Avatar
Thanks for the kind words @Taino-BRZ
We've got a few (6-7 depending on how many orders came in today) complete oil-cooler kits available right now. Contact us if you are in need of one. They retail for $579.99, you guys will get a discount of course.
The Following 2 Users Say Thank You to KraftWerks For This Useful Post:
D-VO (06-26-2014), Freeman (06-25-2014)
Old 06-25-2014, 07:40 PM   #1665
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Can you give us a preview of the install/install manual?
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
zERoTu (06-25-2014)
Old 06-25-2014, 07:49 PM   #1666
Freeman
Freeman's Avatar
15% off with proof of supercharger purchase right?
Freeman is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
