#1639 |
I'm running the stock transmission. If you meant clutch, I'm running a stock clutch as well. Normal shifting at WOT holds fine, but if you use the Ecutek feature for holding revs it slips, so I tend not to use the map with that feature on it so much.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1640 |
#1641 |
Drives: 1st RBv2 10 Series FRS
Making me jelous with all ur dyno numbers. I have no clue as of why mine are so low
![]() Sent from my iPhone using Tapatalk |
#1642 |
Drives: 2013 BRZ Premium Dark Gray Metallic
#1643 |
I have, they actually contacted me. Told me to give them some info on the car, and I also gave them some ecu logs. Hopefully they can figure it out soon. Cause driving this car isn't much fun now . It a really rough ride. Sent from my iPhone using Tapatalk |
#1644 |
Sorry to hear that man. All boost leak sources accounted for and zip tied or clamped?
#1645 |
Drives: frs
@zERoTu I am also on the kraftwerks tune, dyno today at 210HP.
did you guys change out the spark plugs to one step colder? anyone else on stock exhaust setup? my car sometime buckles and the shop recommended replacing the exhaust system and to switch to one step colder plugs. |
#1646 |
Kraftwerks Supercharger Owners Thread
#1647 | |
Drives: 2013 Ultramarine FR-S
#1648 |
#1649 |
Still don't know why everyone had a hard time with those. Just loop a zip tie around a line, push it to the back and tighten it down. You can use the hole between headers to pull the loop tight. I'm at 15psi I never had a blowout, makes no sense to go through all this trouble for the same outcome.
#1650 | |
That Guy
Drives: 2013 asphalt FRS MT
#1651 | |
I might give this badboy a try... or 50 bucks down the drain. http://www.powerhouseproducts.com/ph...ocket-5-8html/ |
#1652 | |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
