86WORX
Old 06-23-2014, 07:34 PM   #1625
noob001
Drives: frs
Noob question. My First time going supercharger. Is there always an constant whine in the cabin from the supercharger?
noob001 is offline   Reply With Quote
The Following User Says Thank You to noob001 For This Useful Post:
Freeman (06-23-2014)
Old 06-23-2014, 07:36 PM   #1626
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Yes, more or less
Freeman is offline   Reply With Quote
Old 06-23-2014, 08:01 PM   #1627
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
With my cogged pulley's and playing with my belt tension. I was able to make it whine only in gear & pressing the gas pedal. Idling I have no more whine unlike the smooth pulley's.
zoth is offline   Reply With Quote
Old 06-23-2014, 08:53 PM   #1628
gmsii
gmsii's Avatar
FYI....the kit will always have some whine noise coming from the supercharger ...as quiet as rotrex units are, they are not silent
gmsii is offline   Reply With Quote
Old 06-23-2014, 11:27 PM   #1629
zoth
zoth's Avatar
Hmmmm mine sounds great with almost no whine while idling.
[ame="https://www.youtube.com/watch?v=88qB71iIzvc"]https://www.youtube.com/watch?v=88qB71iIzvc[/ame]
Old 06-24-2014, 12:35 AM   #1630
noob001
Drives: frs
what is your belt tensioner set at? I used an nickel to measure the distance from the plate to the bottom of the bolt head, approximately 21mm. i can still hear the high pitch with the hood closed standing 4 feet away from the car, or is it your exhaust in the video that's covering up the high pitch noise?
Old 06-24-2014, 12:48 AM   #1631
zoth
zoth's Avatar
Exhaust masking it could be, but I pay close attention to it and there is no whine. Your high pitch sound most likely coming from your high pressure fuel pump AKA "Crickets". See photo's as reference IMHO not all belts are created equal "borrowed from @KraftWerks"
The Following User Says Thank You to zoth For This Useful Post:
D-VO (06-24-2014)
Old 06-24-2014, 01:11 AM   #1632
noob001
Drives: frs
Originally Posted by D-VO View Post
@NCItaly and @noob001
Mine sounds exactly like that. I'm gonna loosen the belt tomorrow for the ride to work to see what happens.
Thank you for confirming
Originally Posted by Freeman View Post
Yes, more or less
Thank you for the answer
Thanks for taking the time to take the pictures with the coins
Old 06-24-2014, 02:17 PM   #1633
lucid215
who here is running the c38 unit? whats the power difference between the c30 and c38 with the base tune thats provided with the kit? im very interested in this kit but i want to run the c38 unit. thanks
lucid215 is offline   Reply With Quote
Old 06-24-2014, 02:20 PM   #1634
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I don't believe there is a KW base tune with the C38. You will need to get it tuned yourself if you get the C38.
The base tune is only for the C30 and should also work with a smaller pulley which should add ~+25whp to the top end.
mit_peid is offline   Reply With Quote
Old 06-24-2014, 04:24 PM   #1635
lucid215
ok cool thanks for the info
Old 06-24-2014, 05:12 PM   #1636
SPCorBUST
SPCorBUST's Avatar
I'm running the C38. 330 on e60 stock exhaust and headers, 265 pump 550cc injectors. Lots of room left I think. Dynojet would be something like 385ish. At the crank maybe over 400? on e83 it felt even stronger.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
lucid215 (06-24-2014)
Old 06-24-2014, 05:14 PM   #1637
Freeman
Freeman's Avatar
Nice, what transmission?
Old 06-24-2014, 05:37 PM   #1638
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
its up and running!
[ame]http://youtu.be/LXixN2ojYHw[/ame]
Now needs mapping, we are going to use the OFT so we will develop an OFT-KW map, hope all works out
ST-A is offline   Reply With Quote
The Following 2 Users Say Thank You to ST-A For This Useful Post:
D-VO (06-25-2014), Taino-BRZ (06-24-2014)
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
