Old 06-22-2014, 07:00 PM   #1611
zERoTu
Drives: 1st RBv2 10 Series FRS
Just dynoed my car today. 182 whp on a mustang dyno. 214 whp corrected to dyno jet. Car is knocking kinda sad with these numbers.
zERoTu is offline   Reply With Quote
Old 06-22-2014, 07:15 PM   #1612
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
What tune & what fuel? Are you all stock aside from the SC kit?
zoth is offline   Reply With Quote
Old 06-22-2014, 07:15 PM   #1613
zERoTu
Kraftwerks Supercharger Owners Thread
Kraftwerks tune on 94 OCt. All stock except the sc and muffler
Old 06-22-2014, 07:23 PM   #1614
zoth
zoth's Avatar
Kraftwerks tune on 94 OCt. All stock except the sc and muffler delete
Send them a log, maybe they can get a more power to it. If not I would recommend @moto-mike of Moto-East a lot of peeps are also happy with Delicious Tuning. I myself have no dealings with them but I do with Mike and they have great customer service and good price point.
FYI: still tweaking my tune but got 275whp on 93 with full exhaust.
If I was only even just 10 hrs. away from Moto-East I easy would drive just to get dyno-tuned by them.
The Following 2 Users Say Thank You to zoth For This Useful Post:
glamcem (06-23-2014), zERoTu (06-22-2014)
Old 06-22-2014, 10:21 PM   #1615
gmsii
gmsii's Avatar
How can you confirm that it's knocking?....There must be something wrong with your car...something probably is not installed correctly ...first thing I would check is that your rotrex oil lines are not hooked up backwards....if they are, you will more than likely need a new charger
gmsii is offline   Reply With Quote
Old 06-22-2014, 11:17 PM   #1616
zERoTu
Lines are good. I'll have to speak to kraftwerks about my Issues and go from there. There are a few things I need to get worked out.
Old 06-23-2014, 12:28 AM   #1617
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I've been very happy with Mike's tune and customer service and completely agree with above comments
I have watched the video you posted and I cannot really tell what I am hearing ( if it's just the wind noise or some belt) . Can you post another video when the car idling?
Are you sure you don't have any sort of leaks? just a thought
glamcem is offline   Reply With Quote
Old 06-23-2014, 04:11 AM   #1618
zERoTu
First I would like to thank everyone on the forum for all their suggestions, and ideas. Great community.
At idle, the video of the gopro mount is normal. The supercharger noise, intake suction, belt noise WAS fine. But I will recheck for leaks again, but I'm boosting fine at 9psi unless the recirc valve isn't working properly.
Now the noise only comes on when I give it gas, with load. For example, If I'm going up hill, I leave the rpms at 3k, and I gas a little, not enough to be boosting, I can hear the noise and recreate it on demand pretty much. But once I give it more throttle and when it picks up speed, it's gone. If ur watching the video on ur phone, it's not gonna be as distinct as a real speaker. Just an FYI.
Now the belt noise is recent. Looks like after I posted my video, some others have followed and posted exact noise from what I've got. I'm running the smooth idler pulleys, and like I said, waiting for the cogged ones to be in stock from kraftwerks. I have remeasured the adjustable idler pulley to 21mm stated in the manual, but the noise is still there, it wines louder now cause i tightened it but now it almost sounds like there is a skip in the wine noise. Like a tick. Hard to explain.
After the dyno numbers from today, I wasn't pleased. They dyno guys says there is knocking / or bad detonation at 6k rpm, So I have to get this figured out soon, track day is coming up. I'll be getting it dyno tuned by someone local here and try to sort that out.
Another issue I have, and please chime in if others are having this issue. Going uphill on 1st gear if it's engaged under 2k rpm, are u guys able to let the rpms climb? Cause I can't. It studders and putts like a broken car. I would have to clutch in and hold the throttle above 2k rpms and the re-engage 1gear. It's pretty bad.
I'm am new to FI. As I'm stock, I will be getting future mods like headers, exhaust, proper tune.
I'm running kraftwerks c30 charger, with the kraftwerks base map, with a all stock car except a muffler delete, on 94 octane chevron gas up here in canada. Oil is 5-30 synthetic.
Thx again everyone.
-ed
Old 06-23-2014, 06:12 AM   #1619
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thx again everyone.
-ed
First off, try 93 octane gas. The 94 octane has been shown lacking more than once.
Secondly, that sound you posted and the description seems like something is hitting under load. Take a careful look at everything.
Finally, have you done any data logging? Something just seems way off with your tune . I'd confirm that you don't have the wrong tune, reload it if it is correct and data log some driving. Try to create the issues briefly. There are entry of guys here that can go through it and see what's up.
Oh, and gmsii is from Kraftwerks.
Old 06-23-2014, 06:57 AM   #1620
gmsii
gmsii's Avatar
Make sure you have the correct map sensor, correct map, and correct injectors.
BTW...none of the KW staff involved with the tuning side use this 'gmsii' general account.
Old 06-23-2014, 12:25 PM   #1621
glamcem
glamcem's Avatar
Thx again everyone.
-ed
I wouldn't take the car to a track day until everything is sorted out. I would recommend contacting with Mike from Moto-East if you are looking for a good solid tune and ask my questions directly to him.
Old 06-23-2014, 04:43 PM   #1622
zoth
zoth's Avatar
Good point, the base map from KraftWerks is for a 2.5 bar and not OEM sensor.
Old 06-23-2014, 05:18 PM   #1623
zERoTu
i was given another map sensor with the tune.
Old 06-23-2014, 05:44 PM   #1624
sw20kosh
Drives: 2013 Black FR-S
Your car should definitely not be knocking on 94 octane at ~210 whp power levels...
Something is majorly wrong with either the A. gas or B. the install/combo of parts
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
