#99 |
Drives: Subaru impreza STI, subaru BRZ
#100 |
Drives: SWP Subaru BRZ Sport-Tech 6AT
Datalog for 2013 BRZ AT
Hey Guys,
First datalog posted. Can someone check it out and ensure everything's good? http://www.datazap.me/u/01s0uljah/20...data=0-1-2-3-4 2013 BRZ AT UEL 1 gear pull and then 2nd gear pull Thanks |
#101 |
Drives: 2003 Camry Blue | 2013 FR-S White
I didn't do a complete pull since I was going to work, but I would like to have some people's opinion on what this data log actually means. I wanted to know also if i'm destroying anything...
http://www.datazap.me/u/camryds/firs...1-2-9-10-11-12 Here are my Engine/Exhaust Mods: TRD USA Intake FT86 SF UEL Catted header TRD USA Cat Back exhaust Perrin Light Weight Pulley OFT Stg 2 UEL 91 map 2.06 just loaded today I'm a total noob to this so any advice would be awesome or any information that can help build my knowledge about this is awesome! |
#102 | |
might be some knock but you need to log FLKC and Knock Correction FBKC have a read of the links below and you will be sorted |
#103 | |
as far as IAM, I think that was at 1 the entire time. I'm reading your article, full of info =) thanks for informing me, I will also be getting a perma tune from shiv sometime in december =) |
#104 |
here is a recent log i took after flashing the new 2.06 rom and did a maf scaling. OFT stage 2 uel 93, takeda intake, OFH, invidia over/front pipe, JDM TRD axle back
http://www.datazap.me/u/lucid215/3rd...ta=1-2-7-11-12 |
#105 |
Drives: Toyota 86 GTS
First day of using the OFT. I just installed my UEL headers and decided to see how it all goes.
I had previously logged my car standard on the standard tune to try to get the MAF scaled and have added that scaling into the 2.06 OTS tunes. I am not 100% convinced just yet and I think I am going to be a little wary for a while for no other reason than being scared of what it has the potential to do. Here is my log anyhow - in the log you can see I did 2 back to back 3rd gear 2k-7k WOT runs to see how it looks. Let me know what you think. http://www.datazap.me/u/galrath/stag...4?log=0&data=1 Dave |
#106 | |
looks like you need to pull another 1 degree out of the base timing b advance from about 5000 to redline loads over 1.0 as that knock is pretty consistent. then probably tweekk up the iat vs timing retard to cut in above 86F. |
#107 |
Wow. Shows how very little I know about all this. That is all double Dutch to me lol.
Gonna have to do some more reading lol |
#108 |
Drives: 2013 Asphalt FRS
@steve99 thank you for letting me know about the link in your signature, Its lots of information and has learn a lot but still more to learn. However, i did my 2nd log IAM look steady at 1 but FLKC is -2.09? Should i be worry?
http://datazap.me/u/benlaz88/2nd-log...-6-7-8-9-10-12 |
#109 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
I read in another post(Can find it if I have to) that the MAF scaling in OFT E85 maps shouldn't be fiddled with. What's the truth? Can I scale it or not? I do not like running 93 after being on E85. lol I'm getting long-term fuel trims of -10% in some parts of the map. KC learned is also hitting 6% consistently in random areas but always while accelerating 5-7k. Pulls nicely regardless and I otherwise wouldn't think anything was wrong.
link to datalog: http://www.datazap.me/u/tuner1b/9-27?log=0&data=1 My setup: FA20club CAI Billet Power Blocks Perrin lightweight crank pulley Borla UEL headers, Catless frontpipe and Nvidia Q300 catback. OFT Stg 2 E85 UEL Last edited by BuBlake; 09-27-2014 at 03:25 PM. |
#110 |
Drives: subaru brz-limited
Hi everyone, i switched over to the new OFT maps about a week ago and did a 3rd gear pull. Can someone take a look at the log for me?
from what i can see i'm running a bit rich and some knock from 5400-6800? Mods: drop in filter, cat back exhaust, oil cooler. http://datazap.me/u/zeppy/oct-26-stg...=0&data=1-9-14 |
#111 | |
But yea, looks a bit lean. Next time you do a WOT pull, include Commanded AFR in your logs -- it'll let you easily see what AFR it wants you to be at.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#112 | |
I was also thinking of switching it to a 91 oct map and running 93 gas, my main reason for tune is safety, not power. I do 4-5hpde events each year and figure extra oct rating would be beneficial? |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
