Old 12-29-2015, 06:05 PM   #841
steve99
Originally Posted by DocWalt View Post
True, but considering it was pretty lean at WOT (leaner than I am NA anyway) well before it got to 11.8...
true
if your on oft tune shiv rescales 02 sensor down o 11.25, and wayno tunes rescale it down to 10.2 from memory
shivs tunes tend to run on the rich side, especially lower rpm wot as the stage2 load limits are are to about 1.6 across the whole range. on usa roms C\D, but not on other roms like G
DocWalt (12-29-2015)
Old 01-05-2016, 04:19 PM   #842
Wepeel
Drives: '13 BRZ Ltd
Okay, here's something I've been noticing. Posted a thread on it but not many responses there. OFH, OFT 93 Stage 2, Berk catted FP, everything else stock. I notice that during highway cruise my car starts closed loop, commanded AFR/measured AFR starts creeping down and eventually everything goes open loop. You can see in the log where short term fuel trim flatlines at zero and commanded AFR jumps to 15.
http://www.datazap.me/u/wepeel/75-mp...a=1-4-7-8-9-14
Steady cruise at 74 mph. Any ideas?
Wepeel is offline   Reply With Quote
Old 01-05-2016, 06:47 PM   #843
steve99
Have you made any edits on the tune, that rearly weird behaviour
either the car has a hardware problem, or something rearly weird is going on like weird tune corruption.
I would try running a stock rom and see if it does same thing, you will get cel code p0420 ( you culd disable it in stock tune but no need for test) , car wont blow up with catless header on stock tune.
if stock tune is ok then that eliminated problem with car\sensors
the rear o2 sensor is used forcruise fueling adjustment i believe, maybe lg parameter "wideband 02" as that is rear sensor and see it looksok comaed to front sensor, it will be ddifferent as scaling isff but should show if sensor is stuffed.
Old 01-06-2016, 11:37 AM   #844
Wepeel
Drives: '13 BRZ Ltd
Thanks for the response. Yes, weird indeed. I haven't edited the tune in anyway, just the OTS OFT offering.
I will add 'wideband o2' to the log to see what that shows. I will give the stock tune a shot to see what it does. The strange thing is, if I pull over and stop/start the car, the AFR goes back to being normal.
Old 01-06-2016, 12:26 PM   #845
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Is it possible you have a faulty O2? Wasnt there a way to log the temperature from the O2 sensor? See if this is happening once the O2 gets heated beyond a certain temperature.
edit: I recall after changing my secondary post cat O2 to a NTK brand part I had more fluctuation in the commanded AFR vs the factory O2 (Denso?). Not sure why it does this exactly as I'd assume commanded AFR is controlled by load and rpm.
Intent > Content
Old 01-06-2016, 06:54 PM   #846
steve99
You can log cat temp with torque or tactrix if you have the ram address ,it uses o2 heater current\voltage to estimate temps think it uses primary o2 sensor though.
I believe the rear 02 is used to adjust cruise fueling , heard it a few times from moto mike and tdd etc, not sure of the excat amount or tables though.
solidONE (01-08-2016)
Old 01-08-2016, 12:26 AM   #847
solidONE
solidONE's Avatar
That would make sense. I asked the NGK tech at SEMA show about this issue I was having he looked at me like I was crazy... "I swear it has an effect on cruising AFR's"
Intent > Content
Old 01-08-2016, 11:59 AM   #848
Wepeel
Drives: '13 BRZ Ltd
I've monitored Cat temps in torque before, "CatB1S1". Dunno exactly what it was but I know it trended way lower going to a catless UEL from stock (couple hundred degreesF on average).
The Rear O2 going bad seems to make sense... I would think there would be some logic in the ECU that would cause it to 'safe' itself into open loop if it somehow determined an erratic or unreliable rear o2 signal. I will try and check it all out soon - I only take the car out about once a week in the winter. I will definitely report back with my findings.
Old 01-09-2016, 09:50 PM   #849
solidONE
solidONE's Avatar
Since there is nothing there to absorb and radiate heat next to the O2 sensor when you delete the cat, it should be quite normal that its picking up leass heat at the O2.
I was observing my commanded afr numbers just now, and yup it still jumps around at cruising speeds (NTK O2). With the stock post cat O2 the Commanded AFR values would hold steady under steady throttle and load IIRC. I would order a stock O2, but after looking at the price tag compared to the $50 some odd dollars I paid for the NTK part... nah. lol
Intent > Content
Old 01-10-2016, 02:26 AM   #850
Jonathanlim
Drives: 15' Frs
Hey guys i'm new to all this. I recently added e85 to my tank and was wondering if this log looked fine to you. Thanks.
http://datazap.me/u/jlim7/local-driv...1?log=0&data=1
http://datazap.me/u/jlim7/highway-cr...1?log=0&data=1
Jonathanlim is offline   Reply With Quote
Old 01-10-2016, 03:26 AM   #851
steve99
Looks ok,
Theirs a bit of knock in the highway log. It might just be due to residual petrol in tank if its your first tank of E85, its caused the IAM to drop a little
Old 01-10-2016, 06:55 AM   #852
steve99
Might sound like a noob question, but how can you tell if there is knock by looking at the chart?
Have a read of the "ECU Logging" link below
Knock Corr (is FBKC Knock Correction)
IAM is ignition advance mulriplier and should be 1, if its less than one you had some knock previously
you should also log FLKC - Fine Learning Knock correction in your logs maybe leave out Short Term fuel trim STFT
Old 01-10-2016, 06:26 PM   #853
Jonathanlim
Drives: 15' Frs
Just curious why would there be knock on the highway and not local? I logged one highway and got off the highway and did another log.
Old 01-11-2016, 01:43 AM   #854
solidONE
solidONE's Avatar
This engine is prone to knock at engine loads of .6~.8 during low RPM operation.
http://datazap.me/u/jlim7/highway-cr...2194-2390-2742
Look carefully at the data and you will start seeing patterns. Once you recognize these negative patterns you'll learn where you want to make adjustments to try to minimize them. You also want to log FLKC numbers for knock. You're probably getting much more knock correction than you realize since FLKC is not being logged here.
Intent > Content
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
