#449 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I took two more datalogs, same stretch of road, same map, just this time at night. Yesterday the car almost felt like it pulled timing going up a hill, tonight is the earliest I could check it.
Run 1: 4th gear, AC on. http://www.datazap.me/u/bobblehead94/run2?log=0&data=1 Run 2: 3rd gear, AC off. http://www.datazap.me/u/bobblehead94/run3?log=0&data=1 It seems like the engine is running a touch lean? 11.25AFR at WOT? |
#450 | |
2. If the AEM intake is the one that comes with that electronic device to fool maf sensor get rid of the electronic box and just scale maf without it. 3. use AFR for your measurements not Wideband AFR unless you have installed the correct wideband senso/controller in the second 02 position |
#451 | |
over about 6400 its pegged at 11.25 which is the rich limit of the 02 sensor scaling so its might be even richer than that. As per the OL Fuel table below should be around 11.7 over 6400. you could fix it with maf scaling but its not really going to hurt anything. low afr numbers = richer their is virtually no knock in either of those logs
| The Following User Says Thank You to steve99 For This Useful Post: | Bobblehead (05-28-2015) |
#452 |
Drives: '13 10 Series FRS #1203
Here is a log from last night. I apologize its about 15 minutes worth or so after I was done fixing an issue I was having with tactrix logging.
Its the OFT Stage 2 EL 93 tune. I think it may be a little rich at WOT and I only noticed a little knock correction at the start as I started driving. I think it looks decent otherwise? However I'm just finally getting familiar with looking at these things and understanding them. I think my ST/LT Fuel trims are okay too? That is what I was most interested in when I logged due to not being sure if I had a leak at my header or not. http://www.datazap.me/u/shady195/log-1432779782 |
#453 | |
Read links below on logging maf scaling and Knock correction You IAM is dropping due knock. Their is some knock shown in that log -1.3 flkc arround 6300 occurred a couple of times. But their was some knock before that log started that has dropped your IAM to 0.86. In that log IAM climbing back towards 1 where it should be. Try and catch the knock that dropping your IAM its probably around 2000-3500 rpm AFR looks ok , bit on the rich side higher rpm (needs Maf scaling to fix) LTFT look ok so you probably only need to do OL maf scaling. It ok and nothing is going to blow up. Maybe try some different brands of petrol some are better than others. |
#454 | |
All I have in the way of an intake is a K&N Panel filter, and a Blitz intake tube. Is that enough to make it run so rich? I thought that would lean it out a little. |
#455 |
My intake is stock and mine ran rich (well it used too) , on oft tune. Appears their are some differences in MAF sensors
#456 |
Okay, so it looks like MAF scaling is needed. Any tips and tricks or anything I should look out for/avoid?
#457 | |
A man
Drives: 14 BRZed
I was plugging data into both the VGI utility and yikes in parallel.. I'll dump the spreadsheet then. Thanks I did bypass the AEM in-line MAF thing, and unexpectedly, the ECM is no longer throwing a Po170/172 (rich fuel bank 1), which was the reason for trying to scale MAF. Car does feel a little sluggish though so it's likely still running rich at low RPM, with low air-speed. I'll ditch the Wideband AFR metric as well, thanks. |
#458 |
#459 | |
I thought the FLKC was the learning correction that kept the motor from actually applying the knock correction IE FBKC? |
#460 | |
or here http://www.ft86club.com/forums/showthread.php?t=61820 also have a look at romraider site http://www.romraider.com/forum/topic1840.html |
#461 |
Drives: 2014 FR-S
I have been reading a bit about the altitude where I am and there are a few people that say running the 93 maps on 91oct can be ok up here. So I decided to load up the Stage 2 UEL BPB 93 map and give it a shot. These are the first 3 logs that I have taken....after looking at these, I believe my car runs better than it did on the 91 map.
Can someone have a look at these and let me know if I am wrong? 1. http://www.datazap.me/u/p5yk0t1c/first-0?log=0&data=1 (IAM=1, FLKC=0, Knock corr.= 0) 2. http://www.datazap.me/u/p5yk0t1c/second-0?log=0&data=1 3. http://www.datazap.me/u/p5yk0t1c/dee...0?log=0&data=1 |
#462 |
Drives: 14 Ultramarine FR-S
I'm on Stage 2 91 UEL Tune. Before I started to modify tables & what not, I've seen my IAM go as low as ~.30 IAM that is how bad 91 octane is. I've seen that much knock just running the Stage 1 91 Tune (w/o headers) & similar numbers on the Stage 2 91 UEL Tune, unmodified.
For any SOCAL people, this is what I'm running. Run @JB86'd timing first but if you get more knock, this is pretty much where I ended up. Stage 2 91 UEL Tune, modified to the tables below. I've seen the least amount of knock with Chevron, Shell was a bit more knocky for me. I've logged alot on this revision & IAM doesn't drop much anymore, my last canyon run it went down to .95 climbed back to 1.0 pretty quickly. In hotter weather, you are gonna get more knock regardless.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
