#435 | |
Drives: 14 Ultramarine FR-S
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#436 | |
Some fuel brands are also better than others For the track though on less than good 93 fuel i would probably do the mods for 91 octane tunes see the tune tweaks thread below http://www.ft86club.com/forums/showt...47#post2216047 |
#437 | |
Try logging flkc as well looking at the KCLearned curve it looks like your pretty knock free and iam is actually 1. for track use i would probably do the mods to the IAT and engine coolant temp compensation tables as i suggested to darksunrise a couple of posts back just for a bit of extra insurance but looks fine from what i can see afr ok long fuel trims fine |
#438 |
Drives: AT 2013 BRZ Limited
Hey I would be very grateful if someone could spare some time and look at two of my logs.
A while back I tried to scale my MAF for my fa20club CAI using Steve99's great guide. Thank you for all your work Steve. I updated the MAF a number of times until summer ended and the Temp changed too much to be consistent. Last scaling log before recently: http://www.datazap.me/u/ray7792/ver5r1?log=0&data=1-2-8 I thought the log looked pretty decent, LTFT could still be better but otherwise... I noticed the car was a little hesitant at some RPMs between 1700-2300 so I decided to revisit the scaling when the temperature rose back up recently. Rescaled it again couple weeks ago and I think it went a step backwards? Not sure =/ http://www.datazap.me/u/ray7792/ver6...0&data=1-2-6-8 Adv multi dropped from 1 for the first time with this latest scaling and I'm getting more knock as well as a bit worse LTFT, but the hesitation is definitely gone which I'm happy about. Not sure should I keep logging and scaling MAF or just go back to the previous scale? Any thoughts and comments? Any idea what could've been causing the hesitation in the first place? Example, very often I would give it a little throttle and I would see the RPMs go up like ~250-350 but I'm not accelerating then it'll drop back down and then the car would accelerate...strange. It isn't happening anymore after my most recent scaling. Thank you very much!
'13 BRZ (sold)
'17 STI |
#439 | |
then have a look in the tune tweaks link below suggest you lean out the OL fuel table as shiv suggests for low rpm hesitation also try making the di\pi adjustments for low rpm and idle hesitation per ztan suggestion |
#440 | |
Oh, the IAM drop was from another log with the same scaling my mistake. yeah, sounds like a good idea to go back to the previous scaling. I made the changes Shiv suggested, he tweaked it for those running E85, but I hope it shouldn't be an issue. I don't fully understand ztan's thing - enabling full DI at .2 g/rev but I'll try it since I trust you xD Maybe I'll post another log if it looks off to me. Thank you very much for your time!
'13 BRZ (sold)
'17 STI |
#441 |
Drives: 2013 Scion FR-S Raven
ray7792
The CAI you are running is quite difficult to scale, imho. My experience was if it ran perfect at WOT then driveability and partial throttle response suffered. Tuned for driveability, WOT had flat spots and surging. If it had a proper MAF sensor mount, with air straighteners, I'm sure it would flow better. Don't get me wrong, it's a beautiful looking air intake, but Mr Brown never took the time to engineer it properly. Hence I sold it.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#442 | |
@ray7792 easy solution would be put stock intake back on with drop in filter. |
| The Following User Says Thank You to steve99 For This Useful Post: | tonystewart (05-25-2015) |
#443 |
Drives: 2014 FR-S
@steve99
Thanks so much for answering a couple of my questions. I am beginning to understand the knock calculations a bit better. I just installed the Crawford BPB and loaded the Stage 2 UEL 91 BPB map. My first log showed IAM dropping to 0.63 then ending at 0.74. I tried to upload it but it was corrupt. This second log shows starting at 0.74 then going up to 0.93. Should I always be starting datalogging with that original map then making adjustments on a saved file a few times to see if I am always having the issues in the same area? I have tried looking at that knock correction tool, but it is beyond my skills at this point. I will probably just go the e-tuning route, but just wanted one of you guys to check this map and confirm that I have a few problems. My MAF seems ok to me, but not entirely sure...it was within the specs in that tune tweaks page. Mod list: Tomei UEL Header EVO 3 catback Ingen CAI Crawford BPB (OFT) Stage 2 UEL 91 BPB map http://www.datazap.me/u/p5yk0t1c/cra...&data=1-7-9-13 Thanks again to all of you for taking the time to help a fellow out! |
#444 | |
yes do a couple of logs to see where you consistenly get knock. however some guys have already done the work for you see the tune tweaks link their is a link in their to Knock Correction on Usa 91 fuel you could just copy those changes to base timing b table and intake air temp retard table. the pic below shows the changes not absolute values thanks to @JB86'd http://www.ft86club.com/forums/showt...47#post2216047 Last edited by steve99; 05-26-2015 at 02:52 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | P5yk0t1c (05-26-2015) |
#445 |
Drives: Toyota 86 GTS
The BPB changes shiv posted with all that extra timing will knock a LOT on poor fuel.
This is how much timing I pulled to keep IAM=1 for mine WITHOUT the extra timing added in KCA and WITHOUT the extra timing added in per cylinder timing. |
#446 |
A man
Drives: 14 BRZed
Hi there.. I'm trying to scale my MAF for an AEM airbox + HKS duct, and I'm getting something funky out of the YIKES spreadsheet. I'm still using the AEM in-line MAF module, which I think might be causing an issue, but thought I'd check here first.
When I go to publish new MAF scaling, I get an error 'MAF g/s Values must change at a positive rate'. All of the suggested cor % values are negative or 0. I'm on OFT v2.066 stage 1 91oct tune. Here's a recent datalog, FWIW (probably very little). http://datazap.me/u/bombino/oft-ots-...0?log=0&data=1 Thanks very much Last edited by bspec; 05-27-2015 at 10:58 PM. |
#447 |
Drives: 86
hey
i am looking for e85 tune for romraider . just for knowledge about e85 . on any code |
#448 | |
E85 economy increased, power same and Petrol tunes A01G/A01I @Wayno has made up some A01G A01I ie European/Australian/South Africia pre 2014 auto/man roms with most of these tweaks installed and some of his own here see below, his E85 tunes have been track tested http://www.ft86club.com/forums/showthread.php?t=83945 |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
