#393 |
Drives: 2013 BRZ 6MT
No, it should have been almost an hour. Now that I look at it I'm wondering wtf happened because I hit save after I got done. Looks like I'm going to have to go re-log it. What values should I have selected so everything is there since I have to redo anyway?
#394 |
Drives: 2015 Subaru BRZ
Can someone please take a look at these ecytek data logs and give some feedback??
Any responses will be added to a comprehensive review of a certain etune vendor. There is a long ass one with a check engine light at the end with full power loss. The smaller one is some driving with two pulls. |
#395 | |
What looks suspect is Knock Corrections up to -5 degrees in longer log and advance multiplier dropping to 0.35 indicating regular and quite large knock events are you running correct octane fuel for your tune ? read the DTC code for the cel light that does not show up in logs. |
| The Following User Says Thank You to steve99 For This Useful Post: | IBill4You (05-01-2015) |
#396 | |
Symptoms = bogging under WOT, RPM increase when clutch pedal depressed unless selector moved out of gear bogging below 3k rpm CEL code resulted in loss of acceleration until car shut off. Would start and run poorly. Then would not start then would start and run okay. I'm thinking either faulty MAP or bad tuning? Do the fuel trims appear okay? |
#397 | |
http://engine-codes.com/p0068.html could be a heap of things bad MAP sensor settings in tune if your running aftermarket MAP sensor faulty maf or map intake leak boost leak ect. did you clamp off hoses under intake manifold one might have blown off under boost. around 3000 rpm is where your getting the knock up yo -5 degrees correction will cause some hesitation as ecu pulls timing and this is with Advance multiplier at 0.3 (it should be one) so ecu has already removed quite a bit of timing. The Stock 02 sensor scaling does not read AFR richer than about 11.25, so without a wideband you cannot tell the actual afr your running. Boosted cars will run richer than 11.25, but stock sensor will not measure that. you need to talk to your tuner about those issues. all that stuff could be rersult of faulty sensor or air/boost leak |
#398 | |
Thank you again Steve99
#399 |
IAM, FLKC, FBKC, LTFT, AFR, AFR Commanded, Load, RPM, Throttle.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#400 | |
http://www.datazap.me/u/wolvenhaven/...2?log=0&data=1 |
#401 | |
I've never seen OFT Stage 2 have a solid 12.0 Commanded AFR through WOT. Perhaps someone will know what's going on there.
#402 |
Anyone up and care to give some feedback on a data log?
![]() http://www.datazap.me/u/darksunrise/...s?log=0&data=1 Looks like my LTFT's are generally -6.25% at idle, and +4ish % above 6k RPM at full throttle. Mods are: - OFT stage 2 - JDL UEL catless header + OP - Berk catted FP - Perrin 2.5" resonated CBE I confirmed there are no exhaust leaks (all gaskets are spotless), other than the header flanges which I just re-tightened but haven't checked the gaskets on.
2022 BRZ Build 2013 FR-S Build |
#403 | |
Drives: '22 BRZ
Thanks for the reminder, I need to check my header flanges too. I retorqued everything else and forgot those. |
| The Following User Says Thank You to DocWalt For This Useful Post: | DarkSunrise (05-09-2015) |
#404 | |
I went a bit overboard with the header flanges to be safe (sick of chasing exhaust leaks!) and torqued them down to 30 lbs-ft. You can get a torque wrench in there with an extension and 14mm crow foot.
#405 |
Drives: Toyota 86 GTS
E85
Stg2 petrol MAF scale MAF scale modified above 3V Some primary open loop fueling removed above 7000 http://datazap.me/u/wayne/v49-11?log...zoom=1111-1242 Hoping it's not too rich up top |
#406 |
Drives: 14 BRZED
E85+OFT+OFH+Dry Flow & Shivtastic Modified Snorkel.
3rd & Part of 4th gear pull. http://www.datazap.me/u/joneze93tsi/...1-2-6-10-11-14 Interesting going from factory header to OFH in that you don't feel the need to rev it out as much around town, has much more grunt down low. It almost fools you into thinking that it doesn't pull as hard up top as you don't hear the angry VVTI changes anymore around 4k. Just very linear. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
