Old 09-27-2021, 10:13 AM   #2059
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by tomm.brz View Post
either reduce timing there in table B base timing, or reduce PI%
Usually changing PI% require a small adjustment to Afr
Thanks - typically richer or leaner?
Compelica is offline   Reply With Quote
Old 09-27-2021, 06:15 PM   #2060
steve99
Agree with tom.brz
timing seems pretty aggressive if your on petrol, you would need high quality petrol to run 29 degrees full throttle.
Compelica (09-28-2021)
Old 09-28-2021, 01:51 AM   #2061
Compelica
Compelica's Avatar
Drives: 86 GT
Agree with tom.brz
Was trying around to find the ceiling - given that this is RON97 and I'm seeing about 2.5 degs FLKC on average the fuel quality must be rather OK, I was expecting it to knock more at this point.
Thanks!
The Following User Says Thank You to Compelica For This Useful Post:
steve99 (09-28-2021)
Old 09-30-2021, 09:03 AM   #2062
realestateagent
Drives: 2018 Subaru BRZ tS
Hey all,
First time poster after bolting on a set of Tomei UEL and Q300 to my BRZ MY18. Automatic transmisson
Was wondering if anyone can take a look at my logs, pretty confused if anything looks out of order, as I'm just going off Wayne's website, with his 89/98 default tune Stg2 UEL. Cheers all
https://datazap.me/u/c14c14/log-1633...g=1&data=1-7-9
Using Garb aussie P98, stock air box, car has done 300kms since flash
realestateagent is offline   Reply With Quote
Old 09-30-2021, 12:26 PM   #2063
tomm.brz
Drives: brz 2017 hksv2
could be better but not so bad for a OTS tune
try maybe his rich +2% tune maybe you ll have a better open loop
Old 09-30-2021, 06:52 PM   #2064
realestateagent
Thanks for the insight mate, I'll see if flashing his rich tune helps a bit. Is there a min period I must wait before logging (another 300km?)
Is the FLKC in these logs fuel quality related? Gets up to -1.48 at times. Am i overthinking?
Old 09-30-2021, 07:51 PM   #2065
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by realestateagent View Post
Hey all,
Needs more km. Specifically more light throttle 2800-4800. 6AT doesn't really encourage that out of the box.
Old 10-01-2021, 12:32 AM   #2066
LancePower
Drives: 2020 BRZ tS
I've got a 2020 manual trans running your v160 Stg1 91 Lean-4%.
I see that you're up to v167. What does that get me?
Should I start back at the v167 Default?
LancePower is offline   Reply With Quote
Old 10-01-2021, 01:23 AM   #2067
realestateagent
Thanks for the prompt reply Wayno. I'll stick with the defult tune and put some more kms on it, what do you recommend I do with the AT light throttle, just not gun it at lights at much
Old 10-03-2021, 03:01 AM   #2068
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Yetti View Post
What is your airflow?
Went from a completely stock FRS to adding an intake, EL header, overpipe and catback. After dialing in the MAF scaling (now within a few % at idle, cruise and WOT) and while making other adjustments to the calibration I noticed that the airflow during WOT only gets up to ~140 g/sec. This seems odd to me as that is exactly the same amount of airflow as the FRS did when it was completely stock. Throttle is opening all the way. What are others getting for airflow with standard intake and exhaust modifications?
Yes I am sorry I haven't setup datazap yet.
I'm getting 150 g/sec with a STI air filter, a bored factory throttle body, +'17 factory upgraded header and the STI performance (axleback) exhaust. Everything else is standard. MAF is scaled within a few % at idle, cruise and WOT.
Old 10-03-2021, 07:24 AM   #2069
tomm.brz
Not a valuable reference, it also depends on lambda scaling, sensors tolerance and quite a few of engine load compensations against temperature and pressure
Any NA will reach between 140 and 155 g/sec of maf, doesn t mean that the higher one is the most powerfull one, and power then also depends on fuel and octane
Those kinds of comparations have a sense for your personal car only, and you still need identical ambient values for it to have a sense.. to see if there is an improvement with mods you Did, but you can t compare to other cars
Old 10-03-2021, 08:38 AM   #2070
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In my personal experience the tune started with ~140g/sec and after adding different parts noticed the ECU to add constantly fuel in high rev ranges. Meaning that there was more air available and the ECU was adjusting fuel to keep the AFR in same ratio. After a MAF re-scaling the mass airflow parameter reached 150g/sec (under similar ambient conditions) and ECU fuel correction went back to normal. I agree that overall power output depends on other parameters too like AFR, total ignition timing and other engine tolerances as you said. However, I believe that you can have an approximate picture just with logging parameters. Otherwise, we would not be able to have remote tuning and we would need to tune always using a dyno
Old 10-03-2021, 08:54 AM   #2071
tomm.brz
i didn't say that logging parameters aren't valuable
but that you can't really compare them from car to car because there are many variables
Old 10-12-2021, 02:50 PM   #2072
jackass
Drives: 2013 GT86 North America
Hi there folks. Would any of you know why I get such a strange data logs, please?
https://datazap.me/u/jacksonracingpl...k?log=0&data=9
Any help would be much appreciated.
jackass is offline   Reply With Quote
Search this Thread:
Advanced Search
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
