#1555 | |
open a petrol tune and the e85 tune in romraider check the injector port injector scaling BRZ parameters petrol should be 228 I think and e85 should be different by about 30% ie 168 or so im just going of memory |
#1556 |
Drives: Scion FRS
okay so I opened EL stage 2 93 and it shows 228.05 , and for the E85 it shows 171.10
#1557 |
Drives: Scion FRS
also quick question how bad would it be to check if I have a faulty MAF sensor by unplugging it while the car is on and at idle? would that be a no no?
#1558 |
#1559 |
Drives: Scion FRS
I'll try a friend's or get one off a Subaru Forrester it the price is better at a auto shop . Other then the MAF showing zero was there anything you would say is bad? Or could it all be caused by this pottentialy bad sensor?
#1560 | |
Drives: Scion FRS
P0113=IAT Sensor Circuit High Input P0102= MAF low voltage P2097=Post Catalyst Fuel Trim too rich (bank 1). Im guessing if it pulled a code for low voltage then there is voltage? correct me if i am wrong |
#1561 |
Drives: BRZ SWP Limited -6MT
any values detrimentally wrong with these logs?
are the most important readings knock correction, flkc, & afr? SHORT RUN - 3rd gear long uphill, single small knock event-> http://www.datazap.me/u/n8brz/tx-rr-...a=1-2-5-8-9-13 LONG RUN - varying engine loads, uphill & downhill, multiple knock events, http://www.datazap.me/u/n8brz/tx-rr-...=1&data=1-5-13 Thanks, |
#1562 | |
Drives: Toyota GT86
http://www.datazap.me/u/n8brz/tx-rr-...4&zoom=327-481 Knockwise, it's fine.
#1563 | |
Maf sensor is probably ok, if it showing zero it likey an oft logging issue Car would barly run and throw cel codes if maf voltage was zero all the time Forrester maf will likely be different , you would need to try one from a brz\86 as a test |
#1564 | |
Drives: Scion FRS
new logs. I'm not too good at reading them still learning . and thank you for the reply. i called Toyota today and they had told me they can warranty out the MAF sensor so i will have to run my e85 out and flash back to stock tune be for i go in. |
#1565 |
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...&data=1-3-8-11
Last one , this is a 1st to 4th gear norm driving |
#1566 | |
A lot of cars run that rich on oft tunes on e85 safe but costs a bit of power Also the oft tunes are done for about 70% ethanol so if your on e90 you will get high positive fuel trims So the only thing that concerning is the 16% fuel trims, now you couls have very high ethanol content e85 like 90%, can you test it ?? The test kits are only about $20 you just mix some e85 with water and you can work out the e% . Or google ethabol percent Your car may be fine. Might just be very high ethanol content You can test here if you have a 100 ml craduated container https://www.google.com.au/url?sa=t&r...6im9_2VMYtqppA I think you ok its just you high ethanol content e85 Were your fuel trims ok on petrol ?? |
#1567 | |
Drives: Scion FRS
#1568 | |
no stock intake with k&n, then perrin inlet tube. other than wasting a little gas, is running a bit rich terrible? from what ive read it seems running too lean (too little fuel) can be dangerous, while rich (too little air) just leaves a little power on the table. correct me if wrong, i may have those backwards. my car seems to run rich from prior feedback from Steve, Im trying to understand why and if tinkering with the maf scaling could correct it. Last edited by bababooey; 08-24-2017 at 02:05 PM. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
