#1541 |
Drives: 2016 FR-S
My cal is F00C so I can't log IAM or MAFV. I would greatly appreciate it if someone could give me some feedback on my log. I'm trying to get a feel for this tuning thing before I throw on headers and step up to the stage 2.
I have a little over 200 miles on this tune, it's a stage 1 on 93 octane and my car is stock across the board. Thanks for your time. http://datazap.me/u/buffalorob/log-1...g=0&data=1-2-7 |
#1542 |
Drives: 2014 Scion FRS (Red)
Hey everyone,
Can someone give me some idea if this map is running well on my car? UEL 93 stage 2 OFT http://datazap.me/u/oppiee/log-15027...data=1-5-10-12 |
#1543 |
Drives: Scion FRS
HELP PLEASE!
Hi everyone , new to this page here. i hope someone can help. i am currently running Catless Skunk2 EL headers , stock over pipe , MXP catless front pipe , nameless axleback and stock intake but i did cut it to collect more air.
This is a 3rd gear pull i will upload, i am running rich as i pulled a code and if i am not mistaken i also have -5 on the FLKC. i might be crazy but on one of my uploads it also shows a -100 on the FLKC. i can up load that aswell if needed. If you have any advice on how to fix this please help and or if an thing looks wrong . i could be crazy .
#1544 | |
log the parameters below
#1545 | |
Drives: Scion FRS
#1546 | |
Drives: Scion FRS
okay if I am not mistaken I got everything. Here should be 3 different pulls all from 3rd gear. |
#1547 | |
are you on E85 ?? what is your rom clid it look like some parameters are not logging correctly like iam and flkc but looking at KC leaned it looks like no knock you running way rich and your long term fuel trim is high positive, do you have stock intake ? |
#1548 | |
Drives: Scion FRS
#1549 | |
strange the fuel trims are so positive, log a few minutes of normal driving as well |
#1550 |
Drives: Scion FRS
and when you ask about my "Rom clid" what is that? and the flkc always shows at -100 for some reason.
#1551 |
Drives: Scion FRS
#1552 | |
Drives: Scion FRS
ok so here are 3 more runs , 2 of them being 3rd gear pulls and should be 100% throttle . the other is normal driving . |
#1553 | |
ok the AFR is a little rich but ok but the long term fuel trims are way high timing looks correct for E85 something is not correct, you have stock injectors ? or injector scaling is wrong or DI pressure wrong causing the large fuel trims or massive exhaust leak, but the AFR is ok so it doesn't make a lot of sense looks like a tune problem with injectors what tune is it |
#1554 | |
Drives: Scion FRS
Last edited by Nobunnyhere.86; 08-23-2017 at 02:00 AM. Reason: left some info out |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
