Old 12-25-2014, 01:42 PM   #141
YEAHdams
Drives: 2013 frs 10series
fule
So my gas light is on and i'm going to try some fuels around my way. Is it worth filling up say 1/8th of a tank or so, do a log after 20mi, then when it gets low again try a different gas station. I've noticed you recommend possibly running different fuel if you have problems.
Would it be a mute point as gas stations have to fill up at some point also? I'm probably thinking too much into this haha.
YEAHdams is offline   Reply With Quote
Old 01-06-2015, 08:40 PM   #142
YEAHdams
newest log
After some random driving with a 3rd gear on ramp pull to redline in the beginning.
http://datazap.me/u/sc10n1814/1-5-15...4&mark=187-188
my Flkc looks off no?
Old 01-06-2015, 08:59 PM   #143
steve99
all looks ok except for the knock at lower rpm 2000 to 3000, looks fine mid and higher rpm and you can see the flkc is positive as the ecu returns timing it pulled prevoiusly.
nothing rearly bad, but should be better if your on 93 fuel, unless its a bad blend or you had 91 left in your tank.
the obly difference between 91 and 93 maps is timing advanced over 5000 rpm by about 1.5 degrees on 93 maps.
just looks like fuel issue to me, try some different brands, not falilair with all the brands in usa\canada maybe ask in forum or ask shiv at openflash
YEAHdams (01-06-2015)
Old 01-06-2015, 09:13 PM   #144
YEAHdams
Thanks again Steve! I'll switch to the 93 map and compare/contrast with the same tank of 93.
I try to always get 93 but read that the 93 tune might be a bit aggressive if the 93 isn't spot on and so we may have better luck with the 91 tune..
Old 01-17-2015, 07:53 PM   #145
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Running stg1 tune on 91 octane.
Can anyone tell me how this looks, just did one 3rd gear pull.
http://datazap.me/u/phantobe/3rdgear...0-1-2-3-4-9-11
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-17-2015, 11:28 PM   #146
Stumpygt86
Drives: Toyota GT86. N/A for life
Can someone have a look at my log please.
K&N Panel Filter and perrin intake tube
UEL Catless headers with over pipe & muffler delete
Power Blocks
OFT stg2 91oct tune with power block modification
50/50 mix of BP Ultimate 98 and Power Plus 108 octane fuel (Australian Fuels)
M/T
light weight flywheel and crank pully
http://http://www.datazap.me/u/stumpygt86/stumpys-3rd-gear-pull?log=0&data=1-2-4-5-6-7-8-9-13-14
Was a 3rd gear, WOT pull on a slight incline. I can run another log later today after I complete my oil change. Just want to make sure I am capturing the correct info.
Stumpygt86 is offline   Reply With Quote
Old 01-17-2015, 11:56 PM   #147
phrosty
Originally Posted by Stumpygt86 View Post
Can someone have a look at my log please...Just want to make sure I am capturing the correct info.
Looks good, slightly rich. You should log Commanded AFR as well.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Stumpygt86 (01-18-2015)
Old 01-18-2015, 12:38 AM   #148
Stumpygt86
I will do another one later today as it is currently about 36 Celsius outside.
I might gain a bit extra if I am running a bit rich, just got to book some dyno time and have them tweek a few things. I just want to have minimal/no knock and good AFR/
Old 01-18-2015, 09:18 AM   #149
Stumpygt86
That log looks good.
no knock
although your LTFT is zero all the time (usually expect a few % variation) , not sure if thats a logging glitch.
was that first log straight after a re-flash or fueling up with better quality fuel ??
Usefull things to log are
LTFT
STFT
FLKC
FBKC (Knock Correction)
KC Learned
Ignition Advance
Throttle position
AFR
Commanded AFR
Advance Multiplier IAM
Engine speed RPM
Engine load
Intake Air Temp
Coolant temp
Oil Temp
Maf Voltage
Have a read of the logging thread link below
Hey Steve99, out of the above, what 2 could I drop when I run my next log? As I can only have 14 points of reference.
Cheers,
Jeff
Old 01-18-2015, 04:29 PM   #150
phrosty
Cheers,
Jeff
MAF Voltage and Coolant Temp would be my choices, if you're only logging to ensure things are running safe.
The Following 2 Users Say Thank You to phrosty For This Useful Post:
steve99 (01-18-2015), Stumpygt86 (01-18-2015)
Old 01-18-2015, 11:26 PM   #151
Phantobe
Phantobe's Avatar
Nooby question, but how do you change what you want to log? I was just messing around in the diagnostics on the tablet & didn't see anything.
Old 01-18-2015, 11:39 PM   #152
steve99
have a read of the oft tips link below their is a youtube how to in there
Old 01-19-2015, 12:58 AM   #153
Phantobe
Phantobe's Avatar
DOH!... I missed the down arrow.
Gracias, gonna start logging once my mount comes in for the tablet.
Old 01-22-2015, 01:41 AM   #154
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Would appreciate some feedback on my latest log. Added a catless UEL header since the last update: http://datazap.me/u/fizz/del69ofhlog...&data=5&solo=6
Would an AFR reading of 11.7 at 7000rpm WOT be considered acceptable/safe?
By the way, does adding a free flowing exhaust system generally make the car run richer or leaner?
Fizz is offline   Reply With Quote
Search this Thread:
Advanced Search
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
