#1457 | |
Drives: GT86
Also you run too rich + LTFT is way off. |
| The Following User Says Thank You to Rezi For This Useful Post: | Teseo (02-04-2017) |
#1458 | |
+1 on what rezi said its running way rich 11.2 and below what sensor is calibrated too on oft tune, and ltft needs work. Basicly maf scaling will fix it, assuming you dont have any intake/exhaust leaks |
| The Following User Says Thank You to steve99 For This Useful Post: | Teseo (02-04-2017) |
#1459 |
Drives: frs
I checked for leaks, but seems everything is fine. I will try to get more pulls, you think the car can run more aggresive tune like ofh tune?
#1460 | |
Drives: GT86
Check your O2-sensor if they are tight. Otherwise if you are 100% sure there are no intake&exhaust leaks try a slightly leaner MAF-Scale. |
| The Following User Says Thank You to Rezi For This Useful Post: | Teseo (02-05-2017) |
#1461 |
Drives: frs
Ok. I will check on a muffler shop and do a leak test. Im using 93oct, if i use 91oct would give me different reads?
#1462 |
Drives: FRS
Hi Guys,
I am running on Toemi UEL, Milltek O/P and F/P, k&n drop in and OFT Stage 2 UEL. 91 gas. I recorded logs for the very first time today and saw that IAM is dropping to 0.88 sometimes. Is this something to worry about? I'm bringing this car to track from time to time but all previous track days were on stock car. I'm trying to understand is it safe to go on track with this config. Here's the log: http://datazap.me/u/svolo4/first-run?log=0&data=1 |
#1463 |
Drives: frs
#1464 |
Here's the first E85 pulls for the season. The two full throttle pulls are both in 3rd gear. Wayno's e85 tune. Tell me what you think and what can be improved on it. Would really like to fully optimize this car.
http://www.datazap.me/u/ivou158/e85-...&zoom=548-1014
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear god, protect my ride.
#1465 | |
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#1466 | |
hahah tbh, it's not too bad. I ran it until I couldn't take it anymore before winter and starting is a bit interesting. But the good thing is she loves the cold air haha. I've had the intake temps down to the negatives and damn does she pull harder than when temps are ~40. I'm just starting the season earlier so I can fine-tune the tune before race season
![]() Last edited by BXRCHTR; 03-06-2017 at 01:09 AM. Reason: Added quote. |
#1467 | |
Drives: Toyota 86 GTS
#1469 |
Drives: 2013 BRZ Limited
Can anyone decipher the issues i'm having here? my STFT is all over the place, LTFT is +-5%, and i'm not sure if the distance between my command AFR and AFR is safe, it varies quite a bit. Most of the issues seem to be while cruising, for example at one point i'm just coasting at 5% throttle and the STFT is all over. Any help would be greatly appreciated.
Mods include: Borla Header HKS Front pipe HKS catback OFT running stage 2 UEL tune, Stock intake http://www.datazap.me/u/jwiggins864/...0?log=0&data=1 http://www.datazap.me/u/jwiggins864/...2?log=0&data=1 |
#1470 | |
Diagnosis ---- you don't have a problem. STFT is supposed to vary widly in closed loop, and will be zero in open loop. The LTFT of =/- 5% or less is good. commanded afr and measured afr are close, maybe 3% rich top end but fine IAM=1 no knock flkc or fbkc all good |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
