#113 |
Drives: 2014 GT86
Are higher boiling temps brake fluids more hygroscopic? Indeed, common trait. Do some raceteams (if they have means & budget) for high end racecars choose to flush after race because they intend to keep car in absolute top state, not even 1-2% worse? - probably. But that doesn't sound to me that fluid used became "unusable" or degraded past level most of us will consider as unusable "after single race". Also wet (degraded due absorbed moisture) temps of some brake fluids may still be high enough or higher then that of generic brake fluids. Due legal reasons (to keep street legal locally) i'm limited to stock brakes, pads/fluid is only thing i can upgrade, so that's what i do. From my experience, on my car, with my stock brakes, with my track use, cheaper aftermarket fluids like RBF600 needed more frequent flushing, while i used Pmu Gfour-355 for season. So "high end brake fluids must be flushed after every race, hence shouldn't be considered" imho is not exactly best conclusion to draw either. My limited (stock) brake thermal capacity means that with rest being same brakes vs BBK will run hotter and stay hot longer .. higher temp range pads & fluid seem to me as justified & needed in this scenario.
| The Following 2 Users Say Thank You to churchx For This Useful Post: | autoracer86 (05-26-2023), Captain Snooze (05-25-2023) |
#114 | |||
Drives: '23 BRZ
#115 | |
Drives: 2014 GT86
. As in my two very first trackdays ever, that were on stock primacies, stock alignment, stock fluid, stock brake pads .. imho brake fade experienced was more from overheated/glazed pads, not boiled fluid, though i might been wrong .. when started feeling braking degradation, just went for cool off lap and returned to pits .. while later i changed both pads & fluid, so hard to tell, which did hit limit first ..
| The Following User Says Thank You to churchx For This Useful Post: | ZDan (05-26-2023) |
#116 |
Arguing about people “wasting” $40/year on Castrol SRF for their >$15000 track car is silly.
#117 | |
Drives: '23 BRZ
I think it’s not a bad idea to let people know they have cheaper and easier-to-get options for trackworthy brake fluid, that will most likely last them for more events between bleeding flushing vs more expensive “racing” brake fluid. Just sharing my experience here… |
#118 | |
Drives: '23 BRZ
#119 | |
You don't want to risk the car or a loss to something small, when you're spending 6-7 figures a year to run the car, and the operation of the car is measured in double digit spend per kilometer. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Captain Snooze (05-26-2023), Ohio Enthusiast (05-26-2023) |
#120 |
Drives: 2016 Scion FRS Release Series 2#439
FYI All,
I messaged Torque yesterday asking for Canadian dealer info. Last night Michael Wachholz replied. Sadly he has no Canadian dealers at this time. But suggested ordering via their website and advised they are re-running their 4 for the price of 3 promo. Food for thought.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
#121 |
Any info/results for Motul RBF700?
I don’t see Torque RT700 on the CSG web store.
#122 |
Drives: 2013 WRB BRZ 6MT
If you're having trouble getting a hold of RT700, I'm just going to recommend Canadians source Castrol SRF React which is a similar class of fluid. A single flush of the stuff is completely fine for a full year of regular autocross and track days for me. It also has the benefit of not getting highly viscous in low temperatures like many other fluids given that my brake pedal feels exactly the same in -30c as it does at the end of 20 minute sessions on the race track and that's not something I can say the same about with any other fluid I've personally used.
I'll note that I've run the same fluid for over 2 years without even partial bleeds and it's handled it just fine and although my last track day was totally fine, the fluid that came out last weekend was quite cloudy/milky so I'm not recommending anyone else actually do this, I think it should still be flushed annually at least, but if you're in a pinch, it looks like you can stretch it out a bit. |
| The Following User Says Thank You to Lynxis For This Useful Post: | bhmax (07-04-2023) |
| CounterSpace Garage - Authorized Dealer - Torque RT700 Racing Brake Fluid | CounterSpace Garage | Announcements, Contests, Giveaways | 0 | 09-26-2013 08:33 PM |
| Brake fluid question | barabia | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-01-2013 12:08 AM |
| Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-14-2013 12:46 AM |
| Brake fluid leak.. | tintumz22 | Issues | Warranty | Recalls / TSB | 9 | 02-01-2013 04:20 PM |
| Racing brake fluid promo | MillersOilsUS | Brakes, Suspension, Chassis | 0 | 12-31-2012 12:29 PM |
