| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 |
Drives: SWP BRZ LTD
All Subaru's that require premium are like this. In the end it doesn't really matter IMO and never really affected my timing on the STI. It's a fine print thing that nobody really cares about, nobody who is running a stock map a tleast.
#58 |
Drives: BRZ(sold), STI
Nope. My manual specifically mentions that the engine is designed to run on 91. No references to 93 whatsoever. No idea what STI manual says. BRZ says 93, and 91 is acceptable with no drivability and reliability issues (read: with less performance).
#59 |
Drives: SWP BRZ LTD
My STI manual stated 93. I thought my old legacy manual stated the same.
#61 | |
Drives: Matte Black STI
Those lucky dogs! So Jealous! |
#62 |
Drives: SWP BRZ LTD
I take it you guys have some parts in development?
edit: I just realized that's the same car I sat in two days ago lol |
#63 |
Now why would we do that.....
![]() I see how some people complain about the power, but 160-ish is right were it should be. Also like some I see room for improvement, which is exciting to see. When is that AccessPORT going to be ready! |
#64 | |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
When you are 9:1 or less, we're generally talking potential cylinder wash territory -- well beyond what I think of as "pig rich". I bet it can be leaned out a bit safely, and make better torque, especially if run on 93 instead of 91. I'd like to see the damn thing on a dynojet already... load bearing dynos generally have too many fudge factors to know if it's reading "high" or "low". |
#65 |
Aaaaand, the video is now private. Hope they'll re-run it with 93
#66 |
Drives: Forester 2007, BRZ Limited '13
If you wonder about my comment earlier - here is a decent dyno:
same here Look at the rollers diameter and compare it with these 10 inch rollers used in this test. Its nothing like real life surface. You need larger rollers for accurate results (minus additional strain it takes to keep the car on these small ones). Really, that's a poormans_dyno test. |
#67 | |
Reap the BReeZe
Drives: 04 LandShark STi
I can't see the video, so I don't know what happened. I can only comment on the comments.
That looks like it says 190-some hp to me. Maybe it says 200. *shrug* The torque dip in the mid-range is where Subaru typically pulls back peak torque of the motor. This is the spot where you are most likely to see knock, so they back it off a bit there to keep everything happy for long life. IIRC, the dyno is indeed a Mustang AWD with mechanical linkage between the rollers. The mechanical linkage is much gentler on center differentials for AWD cars, and is preferred for most Subarus. Not really an advantage in this case, and Mustangs are known for heart breaker numbers anyway (vs internet numbers on other dynos). Wish I could have seen the AFRs before the video was pulled. |
#69 | ||
Reap the BReeZe
Inertial dynos are great for WOT pulls, but load bearing dynos are generally better for tuning out the rest of an EFI map. Drag cars and carbed motors don't really benefit from the extra expense of the load bearing dyno, so the old school hot rodders will usually say inertial is better. Quote:
#70 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
if you want to post dyno numbers on an MR2 forum i frequent, you had better post dynojet numbers, as they are apparently the most consistent from dyno location to dyno location. if you post dyno graphs from another dyno, people will look at the curve but disregard any numbers listed on it.
the horsepower number of ~160whp was pretty well within the range i was expecting to see. i was not, however, expecting 142wtq. what gear did they do the pull in?
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
| DFW: BRZ at Cobb Plano Re-Grand Opening | TheRipler | Southwest | 2 | 04-09-2012 05:14 PM |
| BRZ ordered - wanna pull it apart? | hyteck9 | BRZ First-Gen (2012+) -- General Topics | 26 | 03-27-2012 04:31 PM |
| Any publication strap this car on a dyno yet? | mspeed6 | Engine, Exhaust, Transmission | 69 | 02-02-2012 05:48 PM |
| Will FT-86 pull 1g on skidpad stock? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 04-15-2011 01:56 AM |
| 2007 STi... should I pull the trigger? | RRnold | Other Vehicles & General Automotive Discussions | 25 | 02-23-2010 10:37 PM |
