Old 09-21-2013, 01:28 PM   #1
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
My Modified Blox Racing FR-S Style Shifting Knob
Hello All,
I just wanted to share with you my modification of a Manual Transmission shifting knob made by Blox Racing.
Naturally, many companies forget about 'We" people who use an automatic transmission with manual override
and tap shifters. So I took it upon myself to modify one of these nice shifting knobs for myself.
A stock Blox Racing Shifting Knob for the manual transmission version of our cars that use a reverse lock-out
lever. Currently only available for the manual transmission.
The lathe cut insert that I designed to remedy the "Manual Transmission Only" dilemma that I most dislike.
The insert that I designed shown placed into the knob with epoxy after drilling out the M12x1.25 tap in the
knob with a 5/8" diameter drill. Remember, the tap in the insert is M10x1.25.
The stock Automatic Transmission shift knob shown with my custom Blox Racing shift knob now converted to
be used with an Automatic Transmission.
I hope you all like my ingenuity.
Regards.....
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
The Following 9 Users Say Thank You to NIKOLA For This Useful Post:
B L U E S L A T E (09-29-2013), Beyer Subaru (09-21-2013), dem00n (09-21-2013), finch1750 (09-24-2013), JR007 (01-29-2014), JustBoostin (10-13-2013), MrAmalto (09-30-2013), sprintertrueno86 (09-22-2013), xdudefromheaven (03-26-2014)
Old 09-21-2013, 04:45 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
what did this run you $$$ start to finish?
Old 09-21-2013, 07:41 PM   #3
NIKOLA
NIKOLA's Avatar
$40 for the shifter knob. $50 for a guy to turn the piece of Aluminum to my specifications on a lathe. So, $90 total. I already had the JB Weld Epoxy from 2 years ago. However, if you want to add that cost into the mix then it would be another $6-8. Then the cost would be a max of $98.
Considering the cost of some shifter knobs I got what I wanted at no more cost then those $100 plus shifter knobs.
Why? Do you want to get/make one?
Old 09-21-2013, 08:04 PM   #4
BlueDubbinTDI
Not at all a priority right now but a very cool idea man thanks
Old 09-22-2013, 12:35 AM   #5
NIKOLA
NIKOLA's Avatar
You are very welcome!
Old 09-22-2013, 03:43 PM   #6
NIKOLA
NIKOLA's Avatar
Just wanted to add the installed photos to the thread.
Old 09-22-2013, 07:26 PM   #7
infinite012
Drives: 13 DGM BRZ Ltd
Is the knob not threaded? I'm guessing this could have been accomplished by having external threads on the lathed part you had made instead of epoxying it into the shift knob.
infinite012 is offline   Reply With Quote
Old 09-22-2013, 09:01 PM   #8
NIKOLA
NIKOLA's Avatar
I could not just add an M12 outer thread to the insert part because I needed to put an M10 thread within it. Not much material left to serve as a wall between outer and inner threads. That's why I drilled out the knob and epoxied the insert into it.
The Following User Says Thank You to NIKOLA For This Useful Post:
infinite012 (09-22-2013)
Old 09-22-2013, 09:04 PM   #9
infinite012
I didn't realize the AT knob is also threaded on.
Old 09-27-2013, 06:58 PM   #10
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
so if i get an adapter to 12x1.25 to 10x1.25 and thread that into the knob then put that onto the shifter would it be the same thing? they go for like $4
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 09-27-2013, 06:59 PM   #11
ScionFR-S
ScionFR-S's Avatar
look at my post above sorry lol forgot to quote you
Old 09-28-2013, 12:37 PM   #12
NIKOLA
NIKOLA's Avatar
You'll be able to convert the thread, but you have nothing that will hook the boot.
Old 09-29-2013, 12:23 PM   #13
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
you should see if your guy can make a bunch of those adapter pieces and maybe lower the price a lil and ppl may buy them up to they can buy MT knobs and have them work on AT
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 09-29-2013, 02:34 PM   #14
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Would this be a cheaper solution for those interested? Just would have to get the right size
Its the 3 item on the page
http://www.twmshiftknobs.com/shiftknobs/knobinsert.php
Blox Racing FR-S Style Shift Knob! IN STOCK! Speed Element Interior Parts (Incl. Lighting) 41 10-09-2013 09:06 PM
**NEW** BLOX Racing FR-S/BRZ Specific Shift Knobs FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 15 07-19-2013 01:09 AM
Some photos from BLOX Racing Open House 2013 PMok FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 07-16-2013 04:07 PM
Perrin pulley, K&N filter, and Blox knob gabeg86 Engine, Exhaust, Transmission 0 09-23-2012 06:53 PM
