Old 02-28-2014, 08:22 PM   #463
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
@Td-d I reset the ECU today and took a few logs:
http://datazap.me/u/adriang/paramete...ata=2-3-4-5-25
http://datazap.me/u/adriang/paramete...=2-3-4-5-13-25
I might have gotten my logs mixed up, I'm not entirely sure. The OP2 had a couple old ones that i'd neglected to delete.
Is it good or bad that I'm seeing steady zero's?
I can do another log at some point in the next few days, to see what the car has learned.
AdrianG is offline   Reply With Quote
Old 02-28-2014, 09:04 PM   #464
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Well, seeing zeroed after a reset is a good thing - confirms that learned values are indeed being stored here. Many a couple more logs, and we can call it good - i.e. that these are the ranges.
Td-d is offline   Reply With Quote
Old 02-28-2014, 11:47 PM   #465
ztan
Drives: Toyota 86
Did some logging with my elm327 a while ago on IAT vs ambient air temp and in traffic mine can get 20 C or more above ambient and hold it for quite some time. Suppose having headers directly below intake is not good
I have actually covered my Intake and air box in heat reflective aluminum tape. This has reduced the difference between ambient and IAT by 50% ie I now rarely see over 9 C difference in traffic in summer and it recovers to 2 to 5 degrees quite quickly. Also removed the plastic piece on underside of bonnet on drivers side (couple of plastic clips) to let heat out at low speeds.
Will send the before/after data logs when I find them.
Thanks again.
Thanks mate.
Your IATs look similar to mine (QLD), I'm sure that much heat is not good if we can do without. How much foil did the airbox need and which plastic did you remove?
ztan is offline   Reply With Quote
Old 03-01-2014, 03:22 AM   #466
regal
Originally Posted by regal View Post
What is involved in updating a 2012 manual bas scion to the latest factory rom? Been too long (90's) to understand why I need to find the exact new factory rom.
Its explained well on page post #367.
Problem is I'm down to one car right now should probably wait until my backup car is road worthy.
Great thread and this board has gotten a lot better.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-01-2014, 06:38 PM   #467
steve99
Originally Posted by ztan View Post
Thanks mate.
Been trying ecuflash logging with mixed success
see attached files
It always produces the out file but most times no .csv log file.
occasionally/randomly it will produce log output.
Is their a trick to waiting a time after you plug in tactrix till you start car or waiting a period after car stops before unplugging.
even if I remove triggers it does not always work
on plug in get few flashes of red/blue then green flash ever second or so.
tried two different SD cards.
Old 03-02-2014, 01:05 AM   #468
steve99
Finally got it working, was bad connection between Tactrix op2 and obd port pins bit of electrical solvent and all good now.
Ran a log with @ztan parameters on G series (Australian/European) ROM.
Great to finally be able to log FLCK FBCK and IAM
Thanks @ztan and @AdrianG
log will take a few seconds to load
http://datazap.me/u/steve99/tactrix-...data=2-5-19-24
Old 03-03-2014, 07:48 AM   #469
AdrianG
@Td-d I did another datalog this morning for ~15 minutes, the values for the first 4 were static:
A: -1.24472
B: 0
C: -0.226659
D: 0
On this log for AF_Learning_Range_Current I see values between 0 and 800, in increments of 100 only. In my previous logs though I see increments of 20. Maybe the scalingrpn shouldn't be applied to current?
Old 03-04-2014, 10:15 AM   #470
Td-d
A: -1.24472
B: 0
C: -0.226659
D: 0
Yeah, I think it's back to the drawing board on these ones unfortunately...
Old 03-13-2014, 05:53 AM   #471
regal
Originally Posted by Td-d View Post
The romraider definitions are well defined, in fact the OFT guys are using them now. DSchultz also just managed to get his hands on an ecu, which will speed up the integration of (ODB) logging into the Romraider logger. As to when Ecuflash will move out of beta, not sure - but it is all usable as we speak.
Is romraider and ecuflash useable with the new factory B01C stock ROM. Its the first calib update endorsed by the OEM's for 2012 built cars so IMHO its kinda important.
Mods:
Old 03-13-2014, 07:06 AM   #472
Td-d
Yes, B00C is already defined, B01C will likely just have calibration changes. If someone get a rom to me, I'll define.
Old 03-13-2014, 07:24 AM   #473
regal
Thanks for your support. My last car efi tuning was hondata (years ago) but I work with controls at my job.
What scares me a little with RomRaider/ECuflash is there are so few cars out there. Just a an outsider I would lay odds of us finding a car with the latest calib for manuals B01C as pretty slim, few people bother to go to the dealer to get the update and a very very small percent have a tatrix cable to pull that latest flash.
I'm trying to decide which tuning platform to invest time into. It will be a while before I start tuning or buying tunes for now I just want to stay factory updated without leaving my driveway (dealer visit for something like this is 4-6 hrs,long drive dumb dealer.).
Thanks again for your help.
Mods:
Old 03-13-2014, 09:40 AM   #474
Td-d
You'd be surprised how quickly these roms surface! In any case, I suspect it will inherit the B00C template directly (ie same addresses, but maybe small calibration changes).
Sent from my iPad using Tapatalk HD
Old 03-13-2014, 10:29 AM   #475
FRS-AZ
Drives: Scion-FRS
Trip to dealership
Td-d,
The dealership just flashed my FRS with B01C. I will get you the ROM as soon as I can.
FRS-AZ is offline   Reply With Quote
Old 03-13-2014, 10:48 AM   #476
Td-d
Originally Posted by FRS-AZ View Post
Td-d,
Great, I'll PM you my email address.
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
