#309 | |
Dismember
Drives: 2013 Red Scion FR-S
Which hex editor do you suggest?
#310 | |
Drives: SSM LT MT BRZ
I will at your suggestion sir edit: PM SENT Last edited by SkullWorks; 12-06-2013 at 08:09 PM. Reason: didnt want to double post, like i should, prefer granny posting |
#311 |
Drives: 2013 GBS BRZ Limited
Wow, you guys are freaking me out!
I must be completely confused about how these Roms work... In my experience, the Checksum is a value that the target processor reads back to the originator (usually over a serial interface) after performing a copy to verify that the destination file matches the source file. So the way I understand it is that you need to have a final ROM.bin file, calculate the Checksum, transmit the file to the target, target calculates local checksum, if the two checksums (Xmt/Rcv) match, Copy complete & error free. What am I missing? You cant mess with the digital data in a file and expect the checksum to be the same.
#312 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
stugray - that is basically the way - and both RR and Ecuflash recalculate the checksum (there are 7 in total if I'm not mistaken). Another, less elegant way was to actually disable the checksum checking routine in the rom (RR used to do this).
I think the issue is that the OFT probably has an additional step in the OFT manager somewhere. But I assume, we would need that verified by Vishnu tuning. |
#313 | |
Drives: Toyota 86
RR date stamp gets inserted at 0x13F5CC |
#314 |
Drives: frs
http://www.openecu.org/index.php?tit...ksum_Algorithm
sample checksum table, 17 blocks, last 5 have checksum disabled: start_addr end_addr cksum_val 00008000 0013F4FF 176EBB28 000FAE00 000FB8FF D9F0DD89 000FB900 000FC3FF 2423D83B 000FC400 000FCEFF F0CA38E8 000FCF00 000FD9FF 1299921B 000FDA00 000FE4FF 5AA5A81A 000FE500 000FEFFF 5AA5A81A 0013C300 0013CCFF 9CA358D7 0013CD00 0013D6FF E509C9A9 0013D700 0013E0FF 720C6238 0013E100 0013EAFF 5AA5A7DA 0013EB00 0013F4FF 5AA5A7DA 00000000 00000000 5AA5A55A 00000000 00000000 5AA5A55A 00000000 00000000 5AA5A55A 00000000 00000000 5AA5A55A 00000000 00000000 5AA5A55A the version is block 0x0013F5CC-0x0013F5CF which is yymmddnn where nn is the number of rom saved for the date. just replace that with FFFFFFFF Update: the BRZ/FRZ rom has another checksum table with 2 extra checksum blocks. The checksum fix has been made to RR but hasn't been released yet (check this update date) so you should use EcuFlash for checksum correction. Last edited by vgi; 12-20-2013 at 05:00 PM. |
| The Following 2 Users Say Thank You to vgi For This Useful Post: | bfrank1972 (12-08-2013), EAGLE5 (12-07-2013) |
#315 | |
And, we have logging!
| The Following 4 Users Say Thank You to Td-d For This Useful Post: |
#316 |
yay! back to my happy place (romraider).
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (12-10-2013) |
#317 |
Drives: Toyota 86
Fantastic.
Now looking for RAM addresses for IAM, FBKC, FLKC, Knock Sums, Accel Pos, Target AFR... Last edited by ztan; 12-10-2013 at 04:20 AM. |
#318 |
Drives: 2013 LTD BRZ
YAY! So to be clear logging is running but only via standalone on the OP2.0, the work hasnt been ported to the RR logger definitions? I guess it makes sense since hes the dev for ECUflash not RR. Once all the memory locations are found it shouldnt take too much extra effort to get this over to the RR logger.
#319 |
I have a good deal of the logger addresses already defined - I'm going to be out of town for a week plus, so I'm not going to have time to code them up, but I can post up the raw addresses for people to use.
| The Following User Says Thank You to Td-d For This Useful Post: | calispec (12-10-2013) |
#320 |
These are for A00C and A01C:
Code:
E_AF_Correction_1_2byteExtExt_E82 FFF89B48 E_AF_Correction_1_4byteExt_E81 FFF8A5D8 E_AF_Learning_1_2byteExtExt_E83 FFF89B4C E_AF_Learning_1_4byteExt_E48 FFF8A760 E_AF_Sensor_1_2byteExtExt_E92 FFF89B38 E_AF_Sensor_1_4byteExt_E91 FFF8932C E_Closed_Loop_Fueling_Target_2byteExt_E122 FFF89B4A E_Closed_Loop_Fueling_Target_4byteExt_E121 FFF8A6BC E_Engine_Load_1byteExtExt_E86 FFF89B5D E_Engine_Load_4ByteExt_E32 FFF89148 E_Engine_Speed_Delta_E157 FFF893FC E_Feedback_Knock_Correction_1byteExtExt_E94 FFF89B65 E_Feedback_Knock_Correction_4byteExt_E39 FFF8B0B0 E_Final_Fueling_Base_2byteExt_E124 FFF89B44 E_Final_Fueling_Base_4byteExt_E123 FFF8A008 E_Fine_Learning_Knock_Correction_1byteExtExt_E95 FFF89B68 E_Fine_Learning_Knock_Correction_4byteExt_E41 FFF8B14C E_Fine_Learning_Table_OffsetExt_E58 FFF8B16B E_Fuel_Injector_1_Latency_4byteExt_E50 FFF8A048 E_Fuel_Injector_1_Pulse_Width_2byteExtExt_E99 FFF89B40 E_Fuel_Injector_1_Pulse_Width_4byteExt_E60 FFF887C8 E_Gear_CalculatedExt_E59 FFF895DA E_IAM_1byteExtExt_E96 FFF89B67 E_IAM_4byteExt_E31 FFF816F4 E_Idle_Speed_Map_SelectionExt_E49 FFF8B734 E_Ignition_Base_TimingExt_E53 FFF8AE74 E_Knock_Correction_Advance_4byteExt_E43 FFF8B0AC E_Knock_Correction_Advance_IAM_onlyExt_E40 FFF8B120 E_Knock_Correction_Advance_Max_PrimaryExt_E118 FFF8B118 E_Manifold_Relative_Pressure_4byteExt_E113 FFF88F78 E_Manifold_Relative_Sea_Level_Pressure_2byteExtExt_E89 FFF89B30 E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52 FFF88F74 E_Primary_Open_Loop_Map_Enrichment_2byteExtExt_E85 FFF89B52 E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84 FFF8A974 E_Requested_TorqueExt_E56 FFF8B490 E_Target_Throttle_Plate_PositionExt_E57 FFF8B578 E_Throttle_Plate_Opening_Angle_2byteExtExt_E93 FFF89B32 E_Throttle_Plate_Opening_Angle_4byteExt_E38 FFF89030 E_Tipin_ThrottleExt_E54 FFF89038 Ram_AFR_Sensor_Heater_Protection_Result FFF88480 Ram_AFR_Sensor_Heating_Limit_Result FFF88478 Ram_AF_Correction_3_32bit_ECU FFF8A8EC Ram_AF_Learning_3 FFF81644 Ram_AF_Sensor_1_Current FFF89328 Ram_AF_Sensor_1_Resistance FFF89340 Ram_AF_Sensor_1_Resistance_0 FFF8A624 Ram_Accelerator_Pedal_Angle FFF8922C Ram_Alternator_Duty FFF884A4 Ram_Atmospheric_Pressure_1 FFF89B88 Ram_Base_Pulse_Width FFF89738 Ram_Base_Pulse_Width_times_100_0.84 FFF89CB4 Ram_Battery_Voltage FFF87C6C Ram_CFP_Delta FFF89048 Ram_CPC_Valve_Duty_Ratio FFF89CC4 Ram_CPC_Valve_Duty_Ratio_0 FFF8BD14 Ram_Calculated_Base_Pulse_Width_ FFF8A044 Ram_CoolantTemperature FFF890A4 Ram_Coolant_Temperature??? FFF87C74 Ram_ECT??? FFF89FC6 Ram_Engine_Speed FFF89564 Ram_Fuel_Injector_1_Pulse_Width FFF887D8 Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0 Ram_Fuel_Injector_2_Pulse_Width FFF887DC Ram_Fuel_Injector_Pulse_Width? FFF88810 Ram_Fuel_Injector_Pulse_Width??? FFF887C4 Ram_Fuel_Pressure_MPa FFF8936C Ram_Fuel_Pump_Duty FFF8B1A0 Ram_Fuel_Pump_Duty_0 FFF8BD24 Ram_Gear FFF895D9 Ram_High_Low_Load_0_L_1_H FFF8A0E4 Ram_Idle_Switch FFF8B5B2 Ram_Idling FFF89FBE Ram_Ignition_Total_Timing FFF8ADF8 Ram_Injector_Pulse_Width??? FFF8884C Ram_Intake_Air_Temperature FFF87C64 Ram_Intake_OCV_Current_Left FFF891B4 Ram_Intake_OCV_Current_Right FFF891A8 Ram_Intake_OCV_Duty_Left FFF8C1F8 Ram_Intake_Temp FFF890B4 Ram_Map_Delta? FFF8A220 Ram_Mass_Airflow FFF89114 Ram_Minimum_CFP_Delta_for_Transient_Retard FFF8B004 Ram_Port_Temp FFF8A0F4 Ram_Roughness_Monitor_Cylinder_1 FFF8CEC5 Ram_Roughness_Monitor_Cylinder_2 FFF8CEC6 Ram_Roughness_Monitor_Cylinder_3 FFF8CEC7 Ram_Roughness_Monitor_Cylinder_4 FFF8CEC8 Ram_SI_Drive_Mode_I3_S1_SSharp2_ FFF88999 Ram_TEST_byte_FFF8B064 FFF8B064 Ram_Transient_Threshold_Testunk_FFF8923C FFF8923C Ram_Vehicle_Speed_0 FFF893C4 |
#321 |
Drives: Toyota 86
Again, Td-d, many thanks.
I'll port to A01G |
#322 |
ok, so how do i copy from brzedit into romraider?
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 09:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 03:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 02:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 10:40 AM |
