Northwest AK, ID, OR, WA
Old 10-10-2013, 03:48 AM   #71
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Hey @torqdork @speedy and @jblmr2 I've begun looking into tire options. Since you all were running on performance tires, I'd like to know if you kept with the stock tire size and a stickier compound, or went wider.
Decay107 is offline   Reply With Quote
Old 10-10-2013, 10:56 AM   #72
torqdork
torqdork's Avatar
Drives: RV-7
Slightly wider and taller 225/45-17 Bridgestone Potenza RE-11A's on stock wheels that together weigh 46 lbs. (+6 over OEM) and +2% effective increase (lower numeric) in final drive ratio so little changed speedo calibration but theoretically slows the car's acceleration, braking and turn-in response.
Excellent dry grip, turn-in, predictable, repeatable behavior >50°F, low noise and acceptable ride <32 psi cold. Can't comment on treadwear with <2K miles but they're rated 200.
Poor wet grip, expected for a designated "extreme performance summer" tire. I wouldn't even attempt snow.
I got them for their overall good ratings and recommendations from others using the 1st Gen RE-11's and for their asymmetric, non-directional pattern giving the ability to X-rotate side-to-side to equalize wear.
Good price, too. I traded in my OEM tires on Day 1 three months ago for a net cost of $220, well worth the upgrade.
Bottom line is that I'd tread lightly in low traction conditions but in moderate temps (haven't driven <50°F yet) and dry pavement they're outstanding.
torqdork is offline   Reply With Quote
The Following User Says Thank You to torqdork For This Useful Post:
Decay107 (10-10-2013)
Old 10-10-2013, 08:02 PM   #73
jblmr2
jblmr2's Avatar
Decay, I'm running Hanhook Ventus RS3's in the stock size. They are very sticky and supposedly good in the wet ( I have no personal experience with them in those conditions). On the street they are pretty harsh. Keep in mind that comes from an old man who has become less and less tolerant of a poor riding car. There's a Buick in my future!I run stock tires and wheels on street.
jblmr2 is offline   Reply With Quote
The Following User Says Thank You to jblmr2 For This Useful Post:
Old 10-10-2013, 09:52 PM   #74
speedy
speedy's Avatar
I got the Dunlop Direzza II 235/40-17 on a 17x8 Kosei K4R. I can't do tire-math in my head, but that's the size tirerack recommended. Tire+Wheel weight was about 1.4 pounds per corner less than stock.
I'll be happily putting my stock tires/wheels back on after the last track day (end of October). They're quieter and more comfortable (especially on the mile of gravel to get to my house).
speedy is offline   Reply With Quote
Old 10-10-2013, 10:19 PM   #75
Decay107
Decay107's Avatar
Thanks guys for the input, I've pretty much decided on getting lighter rims (RPF1 17 x 7.5 which should lose me about 5lb per corner) which will give me a choice of anywhere from 215s through 235s.
I think I'll start on a sticky 215s to preserve the weight savings, then go up if needed. Maybe I'll also try some Kunho or Toyo rubber for comparative purposes
Old 10-10-2013, 11:17 PM   #76
jblmr2
jblmr2's Avatar
I think the 7.5's are a good choice, but I'd start with a 225's. Speedy was the fastest of the 86's and he was on 235's. Don't forget your brakes. As you get faster your brakes will become a big factor in your ability to improve. During the off season that will be my priority.
Old 10-10-2013, 11:48 PM   #77
speedy
speedy's Avatar
Nice choice with the RPF1s. In hindsight I wish I'd gone that route.
Old 10-11-2013, 09:22 AM   #78
jblmr2
jblmr2's Avatar
Hey did you guys get Charles White's business card? If not he's a photographer who does a lot of automotive pics. Needless to say he was at the our event. Check out his website, cwhitephoto.zenfolio.com, there are a bunch of pics of all of us. I'm thinking about getting the one with Speedy, Torkdorq, and I at the end of the back straight.
speedy (10-13-2013)
Old 10-11-2013, 03:12 PM   #79
torqdork
torqdork's Avatar
Drives: RV-7
Missed that one, what page is it on?
Old 10-12-2013, 02:15 AM   #80
jblmr2
jblmr2's Avatar
Don't remember the page but the pic number is 515.
Old 10-12-2013, 08:24 PM   #81
torqdork
torqdork's Avatar
Drives: RV-7
Curious how much, if any, oil everyone used at track days? I noticed mine uses ½ qt. of Toyota branded 0W-20 synthetic per track day. Nothing that I'd call unusual at all, just wonder what other's experience is and what brand/weight of oil you're using? It doesn't use any during normal operation between changes and change oil and OEM filter after every track day.
Old 10-12-2013, 10:45 PM   #82
Decay107
Decay107's Avatar
I used Toyota 0W-20, and it doe not appear to have burned off very much at all (at least not perceptible on the dipstick)
Old 10-13-2013, 12:12 PM   #83
torqdork
torqdork's Avatar
Drives: RV-7
I suppose with <2K miles the rings are still seating.
I'm running a 200 mile TSD rally the long way around, up and down Mt. Hood on paved forest roads today. I'll check consumption tomorrow.
Old 10-13-2013, 12:32 PM   #84
jblmr2
jblmr2's Avatar
TD I'm running the same oil as you & bad 0 consumption.
Autocross Events for weekend of May 11-12 7thgear CANADA 23 05-15-2013 11:52 PM
First Autocross Weekend Reflections Purdue FR-S Tracking / Autocross / HPDE / Drifting 2 04-28-2013 11:15 PM
Toyota service centre open in Sydney on weekend? proficience AUSTRALIA 2 02-01-2013 09:20 PM
Drift/ Autocross or Open driving Events CharlieChaos New England 6 08-01-2012 12:33 AM
