#71 |
yep some cars run rich on the oft tunes, do the opeb loop maf scaling and get commanded and actual afr correct.
if you were running in low 11 on the e85 tune just getting the afr back to low 12 will net you quite a few hp |
#72 |
Drives: 2017 Toyota 86
Oft is horrible. You're not going to get real power from this tablet. On stage 2 on 91 i only pulled 171 on 3 pulls on the dyno. Think about it guys!! How is a little tablet going to give you increase of horse power even With bolt ons??? The tune lets your computer know you have after market parts and lets it run better without your check engine light on. With the wrong cat back youll end up losing low end torque, you lose the back pressure which gives u torque for low end daily. A buddy with legit bolt ons and e85 tune is only pulling 211 whp. I'm done with the bolt ones, the only way to get good power is forced induction. Don't believe all the oft garbage, they never pick up, they take forever to email back, and service is horrible. Messing with your ecu alone is very risky! Why do you think everyone is selling their OFT? Do yourself a favor, don't believe all the oft hype posted by the oft guys themselves. Go to a REAL TUNER.
Sent from my LG-H918 using Tapatalk |
#73 | |
Drives: 2014 Scion FR-S Monogram
First, the OFT is a flashing and logging tool. It IS the same thing as a ecutek dongle essentially. Do the of the shelf tunes make the same power as a custom dyno tune? No. Does it let you get a high percentage of the power for cheaper and easier? Yes. It is 100% possible to get a custom tune done on the OFT and it will perform the same a comparable tune done on ecutek. The main benefit of ecutek is it is used by most custom tuners for our car. Second, how do you think getting 211 whp with bolt ons and e85 is low? That is a ideal power increase from only simple bolt ons for a NA car. Of course FI will net you bigger power gains that has always been understood on any car ever. It will also cost you a shit ton of money. Third, the OFT is the best mod for the money on our cars and no amount of extra few HP made with a ecutek tune will change that. At nearly double the price it just simply isn't worth it to most people until you go with FI.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#74 | |
![]() Sent from my LG-H918 using Tapatalk |
#75 |
@2k17.86 a dyno sheet is only useful as a relative measure, not an absolute one. Your picture means nothing good or bad. Do you have something meaningful that we could help you with?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
| The Following User Says Thank You to phrosty For This Useful Post: | Detroiter (08-02-2017) |
#76 | |
#77 | |
Drives: UK GT86
However I can sympathize that he feels that the guys at OFT feel unresponsive, especially if they aren't actively involved in the forum. In fact if someone had just stumbled onto the OFT without being on here you'd probably be really unhappy with the customer service. As for the power chart, without a stock baseline power run it's of little use and the torque curve doens't look to bad.
.: Stealth 86 :.
#78 | |
#79 | |
The changes to the 2017 cars does not give a torque curve that looks like the chart you posted. The reason he said the torque curve doesn't bad is that it is relatively flat. There is normally a massive dip in the middle of the power band. Also OFT does not support 2017 officially as of right now. Probably why you're hearing about issues with it. Yes they take forever to respond, yes they do not have the best customer support. But the truth of the matter is if you have a 2013-2016 car using their tunes will do wonders for drivability and feel of the car.
#80 | |
#81 | |
Drives: UK GT86
Whether it's worth it is subjective. I had a tune on a stock car with a panel filter and made +10bhp. It made the car feel better to drive, not just at WOT. This was not an OFT tune, but I don't see why that's any different. You can customise a tune for the OFT, so the end results could be the same. Case in point, here are what Cosworth expect (1.0 - Stock+Tune, 1.1 - Catback, 1.3 - Manifold + Full Exhaust)
.: Stealth 86 :.
#82 |
I think he's less a troll, and more a non understanding individual.
Why would you only dyno the OFT tune and not a stock baseline? You're yelling that 171 is nothing, but we have no clue what the stock car would put down on that dyno. Dynos mean next to nothing without some sort of baseline.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
#83 | |
#84 | |
| Perrin Stage I tune review | brillo | Engine, Exhaust, Transmission | 18 | 12-10-2013 12:06 AM |
| Anyone choose zeta stage 1 over stage 2? | BlackyRose | Engine, Exhaust, Transmission | 2 | 07-06-2013 02:32 PM |
| >> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 133 | 05-21-2013 02:39 AM |
| Visconti Stage 1 NA Tune Pump & e85 Review | CBR600RR | Engine, Exhaust, Transmission | 22 | 04-26-2013 11:36 AM |
| P&L Motorsports Stage 1 Turbo Kit Review (In Progress) | Supermassive | Forced Induction | 66 | 02-07-2013 02:30 PM |
