Old 05-11-2015, 01:16 PM   #141
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
2016 Viper...ACR
Oh. My. God.
I need this...
New 2016 Dodge Viper ACR – Fastest Street-legal Viper Track Car Ever
May 8, 2015
One of the most iconic high-performance vehicles of the last decade is returning to uphold its legacy as the ultimate street-legal race car. Hand-built in Detroit and certified for public roads, it’s the all-new 2016 Dodge Viper ACR.
The 2016 Dodge Viper ACR is engineered to wring every last hundredth of a second out of road course lap times and combines the latest in aerodynamic, braking and tire technology to carry on the ACR’s lap-time busting reputation that has made it a legend on race tracks around the world.
“The Viper has always been more of a street-legal race car than a track-capable street car, and the new 2016 Dodge Viper ACR is the fastest street-legal Viper track car ever,” said Tim Kuniskis, President and Chief Executive Officer – Dodge Brand and SRT® Brand, FCA – North America. “Our goal is to arm our enthusiasts with the ultimate Viper track car to dominate road courses around the world.”
The SRT engineering team that developed the 2016 Dodge Viper ACR is stocked with members who race their own cars and used lessons learned from the factory-based racing Viper GTS-R that competed in the American Le Mans Series and IMSA United SportsCar Championship from 2012-2014. For the new Viper ACR, the team focused its efforts on three areas: aerodynamics, chassis and tires to maximize grip, producing never-seen-before handling capabilities and unprecedented lap times.
The 2016 Dodge Viper ACR is designed to provide the ultimate in aerodynamic performance, and when equipped with the new Extreme Aero Package, the ACR produces the highest aerodynamic downforce of any production car. During on-track testing, SRT engineers have experienced nearly 1 ton (approximately 1,800 lbs.) of downforce at top speed of 177 mph.
The Extreme Aero Package includes a huge (1,876 mm wide) adjustable dual-element rear wing, rear carbon fiber diffuser, unique SRT hood with removable louvers, detachable extension for the front splitter and four dive planes. The Extreme Aero rear wing, specifically designed for air flow around the Viper’s body, stands taller, sits further rearward and features unique end-plates and gurney lip to produce maximum downforce while minimizing straight line drag. For comparison, the Extreme Aero package delivers more than three times the downforce produced by the Viper TA (Time Attack) 2.0 package.
The rear carbon fiber diffuser extends forward of the rear axle and includes six removable strake extensions designed to rub against the track surface for increased straight-line stability and optimized downforce. Removable hood louvers over the front tires reduce air pressure in the front wheel wells, and the detachable front splitter extension and dive planes work with the rear aero treatment to provide outstanding grip and balanced performance on the track.
Track duty can punish the brakes, so the 2016 Dodge Viper ACR features new Brembo® Carbon Ceramic Matrix brakes that provide optimum braking performance with unprecedented brake fade resistance. Designed to provide greater handling capability with less un-sprung weight, the system uses 390-millimeter (15.4-inch) two-piece front rotors and 360-millimeter (14.2-inch) two-piece rear rotors. Six-piston Brembo calipers provide the stopping power up front, while the rear binders feature four-piston calipers.
The new Carbon Ceramic Matrix brakes provide the largest brake pad area ever offered on Viper and work in conjunction with the specially-tuned ABS and ESC to account for the extra grip provided by the increased downforce and specifically designed Kumho® tires. Detachable front brake ducts provide additional cooling to the brake calipers for optimum track performance.
Keeping the 2016 Dodge Viper glued to the road are four Kumho® Ecsta V720 high-performance tires designed specifically for the vehicle. Featuring a unique tread pattern and a unique raised ACR logo, the new tires have produce laps times that are 1.5 seconds faster than competition race tires. The low-profile front tires measure 295/25/19 and are mounted on wider 11-inch wheels, and when combined with the 355/30/19 rear tires, provide the largest combined tire patch available on any production car.
Aluminum bodied, double-adjustable coil-over Bilstein race shocks designed specifically for the Viper ACR work in conjunction with ride height adjustment for optimal control of weight transfer and handling performance. Each shock provides independent 10-way rebound and compression adjustability, and the suspension package also provides more than three inches of ride height adjustment.
Front springs are rated at 600 lbs./in. and rear springs at 1,300 lbs./in., more than double the suspension stiffness of the Viper TA model. With unique race alignment and 1.4 degrees more negative camber than the entry SRT model, the 2016 Dodge Viper ACR is capable of sustaining more than 1.5g on high-speed turns due to the combined chassis and aerodynamic improvements.
“This car is not a 1-3 lap track special. You can run the car at the track all day, and the performance doesn’t fall off,” added Kuniskis.
The heart of the 2016 Viper ACR is the awesome, all-aluminum 8.4-liter V-10 overhead-valve engine, rated at 645 horsepower 600 lb.-ft. of torque – the most torque of any naturally aspirated sports-car engine in the world. Unique exhaust tips have been added to the side-mounted exhaust pipes to provide reduced exhaust pressure, and all Vipers are engineered to withstand severe track duty in ambient temperatures of 100 degrees Fahrenheit. Power reaches the pavement through the standard Tremec TR6060 six-speed manual transmission.
The Viper ACR features a host of exclusive appointments to its race-inspired interior, starting with the Alcantara-wrapped instrument panel cluster hood, lower instrument panel and door armrest panels. A new, ACR-exclusive Alcantara wrapped high-grip steering wheel with color racing stripe and unique badging sets the ACR apart from other production models. New high-grip seats also carry the Alcantara inserts, while the unique dash plaque is finished in carbon fiber.
Old 05-11-2015, 01:26 PM   #142
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
That wing is so huge that there may be more carbon fiber used in it than in the entire tub of a 4c.
funwheeldrive (05-11-2015)
Old 05-11-2015, 02:21 PM   #143
mark0006
Drives: wrx
2016 Viper ACR in live photos
I like the color combo they went with.
From the article:
Dodge has released a nice live photo gallery with the brand new 2016 Dodge Viper ACR programmed to enter production in Q3 2015.
9 pictures and full article
mark0006 is offline   Reply With Quote
Old 05-11-2015, 02:29 PM   #144
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Khumo v720s?
really? Am I the only one thats like "WTF?"
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
NyC Zn6 (05-11-2015)
Old 05-11-2015, 03:38 PM   #145
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Originally Posted by tahdizzle View Post
Khumo v720s?
No.
53Driver is offline   Reply With Quote
The Following User Says Thank You to 53Driver For This Useful Post:
tahdizzle (05-11-2015)
Old 05-11-2015, 03:55 PM   #146
vividracing
vividracing's Avatar
That's definitely a nice Viper, but I think I'd more want this...
The $2.4 million Aston Martin Vulcan
Looking at that back end and that diffuser, all I thought was...
vividracing is offline   Reply With Quote
The Following 2 Users Say Thank You to vividracing For This Useful Post:
SirBrass (05-11-2015), tahdizzle (05-11-2015)
Old 05-11-2015, 04:08 PM   #147
MokSpeed (05-11-2015), SirBrass (05-11-2015)
Old 05-11-2015, 04:28 PM   #148
TylerLieberman
TylerLieberman's Avatar
Drives: '20 Hakone 86
Seems like a lot of car for some Kuhmo's...
I would think they would fit it with something more aggressive like the Michelin Cup tires like the new Z06.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 05-11-2015, 04:34 PM   #149
serialk11r
Drives: '06 AM V8V Coupe
That Aston is...so beautiful T_T
Old 05-11-2015, 04:49 PM   #150
vividracing
And the interior of the Vulcan. You can have it in any color, as long as it's Carbon Fiber...
And a front diffuser so big you can split time and space.
Old 05-11-2015, 05:31 PM   #151
ScoobsMcGee
Drives: 15 BRZ
I also find the car gorgeous, but this may be the first interior which is more "STAY ON YOUR SIDE, PLEB!" to the passenger than an S2000.
Old 05-11-2015, 06:13 PM   #152
vividracing
The Vulcan is a track specific car, having a passenger is just a courtesy to a driver that wants to take their friend for a ride. It's actually more an optical illusion looking from the top, that piece going to the middle goes down to the floor.
Old 05-11-2015, 06:16 PM   #153
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I hope those lights are inside an actual housing on the real model.
MokSpeed is offline   Reply With Quote
Old 05-11-2015, 06:29 PM   #154
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Beautiful car. The previous Viper ACR help the Nurburgring record for quite awhile if Im not mistaken. I wonder how this one will do...
boooooooooooooooooost
Ammonia is offline   Reply With Quote
The New Dodge Hornet spcmafia Other Vehicles & General Automotive Discussions 24 06-19-2023 11:45 AM
2013 Viper GTS looks kinda like... kappaknight Scion FR-S / Toyota 86 GT86 General Forum 13 06-27-2012 07:49 AM
Dodge Dart First Test. Asterisked Accolade Other Vehicles & General Automotive Discussions 12 06-07-2012 08:46 PM
vs 2013 Dodge Dart Snoopyalien24 FR-S / BRZ vs.... 66 05-24-2012 08:58 PM
2013 Dodge Dart first real life photos and accessories/engines/transmission list Aeghtysix Other Vehicles & General Automotive Discussions 1 01-09-2012 11:12 AM
