Old 09-18-2013, 02:21 PM   #15
SSchifko
Owner and Operator
SSchifko's Avatar
Drives: FR-S, Yamaha R6, 1972 Camaro
I am going to see if this helps: http://mystarbrite.com/startron/
I put it in my motorcycles, for other reasons.
-Schifko
SSchifko is offline   Reply With Quote
Old 09-18-2013, 02:51 PM   #16
strat61caster
strat61caster's Avatar
Originally Posted by Terrapin77 View Post
At the ratio we are using, I doubt there will be any long term issues. Plus, during the winter, I doubt 2T will be needed.
Sent from my XT912 using Tapatalk 2
Hence my 95% statement, personal statistic I pulled out of my ass, I would not be surprised if a car goes 300k miles with no fuel issues with 2 stroke oil in every tank.
Could you elaborate about it "not being needed in the winter"?
ineedyourdiddly
Old 09-18-2013, 03:25 PM   #17
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
For me, the chirps were at their worst on hot days. Since it is colder in the winter, the chirps shouldn't be much of an issue. That has been my observation.
Terrapin77 is offline   Reply With Quote
Old 09-18-2013, 03:47 PM   #18
strat61caster
Funny, the first time I noticed my car was completely silent it was 110+ outside and I had just gotten done driving through the foothills in a spirited manner. I got the car in January, car got quieter as the months got warmer.
I have yet to see anything definitive, but even at it's loudest the noise was just an annoyance, wasn't going to do anything about it until confirmed failures were reported, so far none yet.
ineedyourdiddly
Old 09-18-2013, 04:22 PM   #19
Terrapin77
Terrapin77's Avatar
The chirp is just an annoyance. One that I got rid of. I have even gone down to a 1:1200 ratio on the 2T and I'm still chirp free.
Old 09-18-2013, 05:23 PM   #20
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Would adding this result in warranty denial?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-18-2013, 05:34 PM   #21
Tromatic
After the pump issues, I can't imagine them having the stones to do so. On the other hand.... I'd be more worried about it gumming up something else. Found this while googlin' around:
http://www.klotzlube.com/techsheet.asp?ID=51
Klotz Uplon Fuel Lube provides upper cylinder and fuel pump lubrication. Protects the induction and fuel delivery systems from dry, abrasive properties of methanol alcohol. Uplon Fuel Lube increases horsepower by reducing power robbing friction. Seal conditioners maintain constant fuel pressure and prevent lean-out conditions. Blends with gasoline, methanol alcohol and nitromethane.
Tromatic is offline   Reply With Quote
Old 09-18-2013, 05:50 PM   #22
leon78
leon78's Avatar
Drives: 13 Whiteout
I would love for my cars exhaust to smell like BeNol.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 09-18-2013, 05:53 PM   #23
Tromatic
The would be awesome.
The Following User Says Thank You to Tromatic For This Useful Post:
leon78 (09-18-2013)
Old 09-18-2013, 06:17 PM   #24
strat61caster
Yeah that phrase makes my bullshit meter go off.
Company seems a bit off their rockers, but hey whatever helps you sleep at night.
http://www.klotzlube.com/Klotz_Diet.pdf
ineedyourdiddly
Old 09-18-2013, 06:34 PM   #25
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Sounds like snake oil to me, I wouldn't expect more HP but if it fixes the crickets and it's safe to burn, more power to you. Either way, I'd rather deal with the crickets and wait for a fix than putting an unknown into my fuel system that's just going to cost money. Especially something that should be covered by the warranty when there's eventually a fix.
DoomsdayJesus is offline   Reply With Quote
Old 09-18-2013, 06:54 PM   #26
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I've been running this stuff for a while now. Lucas 2 stroke low ash. Using 1-2oz in a full tank. It's night and day between a tank with it and a tank without.
post_break is offline   Reply With Quote
Old 09-18-2013, 07:47 PM   #27
Tromatic
Don't care about the HP claims. And there does seem to be a new fuel pump on the way. When it does arrive, I'm going to wait and see.
Old 09-18-2013, 09:20 PM   #28
mike the snake
It might be snake oil, but if you looked at today's gasoline, especially California's gas, I'd call the gasoline snake oil before i called anything from Klotz snake oil.
Klotz, as far as I know, is one of THE best oil companies. I may be wrong, but I remember when mixing my own Nitro fuels for models, Klotz was the very best oil to add.
Today's gas formulations are just stupid, mixed more for emissions than performance, and the addition of ethanol just adds more problems into the mix.
A capfull of 2-stroke oil per tankfull will do absolutely nothing negative.
0W-20 full synthetic oil for $3.49 a quart terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 04-08-2014 05:51 PM
Is FR-S oil Synthetic or Conventional? EBMCS03 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 52 01-08-2013 11:37 PM
Whats your average MPG now in the winteRnHow far are you going on a full tank of gas? NickFRS Northwest 17 12-22-2012 12:59 AM
340 miles and one full tank later... gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 28 11-14-2012 10:32 PM
%100 Full Sythentic VS Fully Synthetic ProjectD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-05-2012 02:28 PM
