#29 |
Drives: Raven FRS
I'm guessing this is a DD that will also see track time and not a dedicated track car.
#30 | ||
Drives: 86
i think u will have good hp nm with heads cnc works |
#31 | |
Drives: Raven FRS
You must have never owned anything 2j powered. extensive mods for 1000HP?? I made 960 with head studs, cams, HKS head gasket and pump e85 it doesnt take anything "extensive". |
#32 |
How about 865whp on a stock head gasket, studs, pistons etc. only a gtx42, e85 bigger injectors and pumps
#33 |
it doesn't really matter if the engine is built or not, you buy a turbo based on goals/needs. a big turbo will still lag on a built engine (actually more, since you'll probably lower the compression).
#34 |
Drives: Scion FR-S
Love to see more specs on the Par engineering drivetrain...
#35 |
Drives: 85 corolla gts
I would also recommend against the vipec unless they have a means of dealing with the direct injectors. May want to look into hydra or syvec (spelling) as well there are several turbos that would fit the bill. Launching on anti-lag will put the drive train through a lot of stress make sure that is looked into properly as well. If you are building everything in house you should be able to do the math to size the turbos properly and figure out the management requirement though. Good luck on the project.
| The Following User Says Thank You to Ross For This Useful Post: | SUB-ZERO (09-17-2013) |
#36 | |
Drives: GT86/GTR R35
my car will be done after 3 mouths from October and I will start updating everything I am doing stay tuned |
#37 | |
they are working on gtr r35 and boxers engine |
#38 |
#39 |
Drives: Silver BRZ
this thread scares me....
#40 |
Drives: 2013 Scion FR-S Firestorm Red
^^^ LMAO!!
#41 |
Drives: Attitude
Personally a big fan of Gallo engines, you may want to try the Gallo 12 or 24.
#42 |
I didn't know pizza places made motors....
| Tags |
| built motor, turbo |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 06:27 AM |
| Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned | Visconti | Forced Induction | 697 | 11-13-2013 07:18 PM |
| Crawford Limited Turbo BRZ - built motor | Mrqb22 | Forced Induction | 8 | 11-11-2013 02:34 PM |
| Anybody know where the Scion FR-S is built? | Fish Eagle | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 05-30-2013 12:44 AM |
| Will FR-S ever have a aftermarket turbo built? | docyzx | Forced Induction | 50 | 07-19-2012 01:20 AM |
