Old 09-17-2013, 11:04 AM   #57
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by solidONE View Post
You have not gone FI with your car, correct? Also the pressure dropping with the 0w-20 is under normal driving conditions and temps or were you wringing out the car/motor?
Correct, I am NA.
Both.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
solidONE (09-17-2013)
Old 09-17-2013, 02:03 PM   #58
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Correct, I am NA.
Both.
I'm assuming you only started taking measurments of oil temps and pressure after the oil cooler was installed. Also assuming that this pressure drop will also happen on a bone stock engine running 0w-20, and running you car like this on the track is probably not a good idea.
Intent > Content
Old 09-19-2013, 08:30 AM   #59
regal
Originally Posted by Sportsguy83 View Post
So I have the Innovate Oil Pressure/ Oil Temperature in one gauge. It has logging capabilities. Went ahead and did several logs from 2K RPMs to 5-7K Rpms.
Including WOT, full boost, partial throttle, very light throttle, cruising.
ALL of the time, the oil pressure graph NEVER drops one PSI while increasing RPM. It looks exactly as expected a line continuously going up. I will post up pics when I trim it as the whole log was 18 minutes.
Again, it might be true its variable drive, BUT it does not appear to be loosing pressure along any RPM range.
EDIT: I'm using Motul 8100 0w-30 Oil.
The guy on the AE86 forum didn't say oil pressure drops with rpm in the torque dip, he says the rate of increase isn't constant as the pump is geared to a variable acelleration with rpm unlike a conventional oil pump.
Maybe he is FOS but usually where there is smoke there is fire, been enough rod bearing failures with FI to look at the oil pump.
Actually dropping oil pressure at high rpm as reported by Dave is obviously a more serious issue, probably a warranty issue. Mine doesn't do this even with 0w20.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-19-2013, 08:33 AM   #60
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When you see a linear increase of oil pressure across the RPM band, the rate of increase is constant .
Old 09-19-2013, 10:00 AM   #61
regal
Agreed, but Dave's report really is important info. Its sounds like to get a linear increase we need to use a 30 weight ?
Mods:
Old 09-19-2013, 10:03 AM   #62
Sportsguy83
Drives: Limited BRZ
Might be entirely possible as I do run a 30 weight.
Old 09-19-2013, 10:06 AM   #63
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Yeah....30 weight sounds nice.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
utekineir (09-22-2013)
Old 09-22-2013, 01:17 AM   #64
solidONE
solidONE's Avatar
I believe @Dave-ROR only started to watch his oil pressures after he installed the oil cooler, so the pressure drop using 0w-20 may be due to extra oil passages from the added cooler assembly.
Intent > Content
Old 09-23-2013, 02:16 PM   #65
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
The oil pressure should not be linear or constant. It's designed to build pressure fast until it hits the pressure relief, and dumps excess oil to maintain the pressure set via the spring in the pressure relief valve.
So if the pressure relief is set to 80 psi it will say hit that by 3500 RPM and then the rest is bypassed until the flow of the oil pump cannot keep up at high RPM. If you see pressure drop, it means the oil pump cannot keep up with oil flow demands. Often people will shim the pressure relief but this will not fix a flow issue at high RPM.
Oil temperature and oil viscosity are the culprits here at high RPM pressure loss. A quick fix is a slightly higher viscosity oil or a more thermally stable oil.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Search this Thread:
Advanced Search
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 12:35 PM
WTB: Factory Boxer Engine cover Sportsguy83 Engine, Exhaust, Bolt-Ons 28 11-11-2013 02:04 AM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 06:18 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 06:04 PM
aFe Announces the Grand Opening of the aFe Power Factory Store aFePower_indika Announcements, Contests, Giveaways 3 10-22-2012 08:30 PM
