#85 |
Pro Subie Engine Nerd
Drives: empty spot for an FR-S/BRZ
#86 |
Kuruma Otaku
Vanilla Ice's 5 point Oh didn't have overhead cams...
Because titanium. |
#87 |
#88 | |
Drives: '23 BRZ
Cam was by PatG, 222/230 .597", lobe separation 114 I think... We took it to the San Antonio drag strip when I was down to pick the car up , PO did a 11.69 @ 129.16mph ![]() Neither of us is a drag racer, and the car is a daily-driver/HPDE compromise, so highish ET for the mph... |
#89 | |
Douchebag
Drives: 2014 Mustang GT
Here - 2014 Mustang GT Track Package/Recaros - Koni Yellows, Boss 302 Springs, BMR SB041 Front Sway Bar, Boss 302 Rear Sway Bar, Boss 302 Wheels, GT500 Quad Tip Axleback, 2016 Legacy 2.5i Limited
Gone - 2010 RX350, 2006 GTO (2nd), 2007 RX350, 2008 IS250AWD, 2006 GTO, 2004 G35 6MT, 1992 SC400 |
#90 |
Drives: '06 AM V8V Coupe
Really? :P
People are quick to criticize the torque delivery of small displacement Japanese engines, but if you look at that torque curve, it's not exactly what you'd call good. You are seeing 75% peak torque at 2000rpm on a 5000rpm peak, which is rather pathetic. A 2GR-FSE has almost 100% torque at 2000rpm with a similar peak. People are complaining about a ~10% dip in the midrange on the FA20, whereas that LS2 never even hits 90% peak torque until over 4000. |
#91 |
Drives: '23 BRZ
Very one-dimensional view there, serialk11r...
Flat torque curve isn't as important as making as much torque/power as you can, wherever you can make it, while maintaining streetability (in this engine's case, anyway). Would it be "better" if it simply plateu'd at 2000rpm? According to you, I guess it would be. For me, NOT. Suffice it to say, there's plenty of oomph at all rpm... |
#92 |
What I'm getting at is peak torque is making the most power at a given engine speed. Sure, flatter torque curve isn't better if it's overall less torque, obviously, but specific torque on the LS2 isn't any better than said Japanese motors, so the Japanese motors are making better specific torque most of the time, despite having the big rev range disadvantage. That's what "torque delivery" is right? It's not about "enough power" or not, it's how much of the engine's potential is being extracted across the rev range. The LS2 is obviously much more powerful than a F20C, but if the car's size is matched so the peak acceleration is the same, the F20C will feel more consistent than the LS2.
Not to diss the LS motors, it's very admirable that GM understands that cost effective >>> bragging rights (I think Japanese companies sometimes need to get their priorities straight, Honda S2000 would be a good example, they want to use a 2L engine to get huge amounts of power, and then they toss the only advantage a small displacement engine has out the window by giving it gearing unsuitable for the street), funny saying that about the company that is staying afloat on taxpayer money. |
#93 |
Drives: NA8C, GDB, and R50
EJ2x all the way
See My Album: http://www.ft86club.com/forums/album.php?u=949
#94 | |
Kuruma Otaku
But GM is quick to point out that all that stuff is expensive and also bulky (ohv heads are surprisingly small). Always the damn compromises...
Because titanium. |
#95 | |||||||
Drives: '23 BRZ
(To be honest, I think the 517hp/473 lb-ft numbers are really closer to flywheel than actual rear-wheel) Quote:
![]() Quote:
Anyway, I'm a HUGE fan of GM's approach with the LS engines, vs. Ford's monstrously huge, heavy, and high-c.g. V8s. When I get around to doing a Factory5 Daytona Coupe, it's definitely going to be with an OHV 347 stroker, noy a DOHC/32-valve mod motor. |
#96 | |||
Drives: '23 BRZ
Like when F1 didn't suck and featured V8s vs. V10s vs. V12s. They all had their strengths and their weaknesses. |
#97 |
You think 2 liters is not a compromise ZDan?
![]() The only reason they made the F20C 2L was because Japan has displacement tax. If they wanted no compromise they would've given it a bigger bore from the start. Don't get me wrong, the S2000 is awesome, but it's definitely got a bit of a conflict in design philosophy. It's like a racecar on one hand with extremely short gears, fantastic performance, on the other hand it's massively handicapped by a displacement chosen for tax reasons. No replacement for displacement is sadly true. Rev range is a disadvantage for torque delivery, but not power, of course. The bigger the difference in engine speeds that you have to run at, the harder it is to optimize things. And no duh, the LS2 will feel great despite less than ideal torque characteristics because it's just got SO much power, and knowing how compact and light the engine is for its size, that's definitely something to brag about. Personally I think a street performance engine shouldn't go the brute force high displacement method, but it has very strong merits for sure. My personal engineering perspective preferences are ~8500-9000 rpm, light boost, low displacement, and moar gears in any transmission that lets me control the clutch. SCed 2ZZ with slightly tightened up 1-6 gears and a quiet and extremely efficient 7th
#98 |
Kuruma Otaku
32v ohv SBC??? Could they fit in 16 more pushrods? Or split the rocker arms to push 2 valves? Someone somewhere must have tried this...
Super compact large displacement with better filling, cam phasing be damned.
Because titanium. |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 02:08 PM |
| 4U-GSE: the new engine swap for old Toyotas | no_name | Engine Swaps | 17 | 12-19-2011 10:50 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| YOU MUST CHOOSE # 2 | Calais | Other Vehicles & General Automotive Discussions | 16 | 07-22-2010 01:30 AM |
