| Engine Swaps Discussion of engine swaps. |
#155 | |
Drives: 2014 Scion FR-S Monogram Series
Still, this kind of swap would be rather expensive because of the cost to build the motor and then have a drivetrain that can hold-up to that low-end torque.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit Future Planned Mods - Ace 350 Header & Tune. Oil cooler. Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg |
#156 | |
Only happy when it rains.
Drives: series.blue
#157 | |
Realistically, I love the FR-S the way it is and will only diddle with putting stickier tires on it and maybe a header / tune. Further exhaust modifications would only occur if the header / tune combo yielded and undesirable exhaust note that could be corrected with midpipe / catback mods.
#158 | |
Drives: Scion FR-S
FA20 trans fits the H6. In fact every subaru trans fits every subi engine (Iīve swapped a 2014 Forester Diesel 6 sp. box into my H6 Outback)For the FA20: The starter is on the other side, but this can be solved with a little grinding ![]() Flywheel and clutch from the FA20 fits. EZ30 Engine mounts fits, dropping a H6 in is like a 15min. job. EZ30 ecu plugs are the same as the FA20 ecu. Same DBW as the FA20. The main concern is the crank trigger wheel w.different pattern. It causes a disfunctional EPS, ABS and VSC, tach and some other stuff needing engine speed signal. Btw. the EZ30 and EZ36 have the same outside dimensions. The only difference is the bulkier front cover because of the twin AVCS on the EZ36. The 36 is even a tiny bit lighter than the 30.
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 02:08 PM |
| 4U-GSE: the new engine swap for old Toyotas | no_name | Engine Swaps | 17 | 12-19-2011 10:50 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| YOU MUST CHOOSE # 2 | Calais | Other Vehicles & General Automotive Discussions | 16 | 07-22-2010 01:30 AM |
