#1303 | |
Drives: 2013 FRS
#1304 |
Hi @shiv@vishnu
With the new logging noticed a slight amount of knock in 2000-3000 rpm range looks like on intial throttle application. knocks my IAM to 0.9 for a short period. can see it in this log http://datazap.me/u/steve99/mountain...7-8-9-10-11-12 is it worth pulling a bit of timing in this area say 0.25 or so degrees. What would be best table to pull it from Thanks |
#1305 |
Drives: WRB BRZ, Monte Carlo SS
I finally got the realtime display working again
![]() With the new data logging features will it record more than 12 channels because I know only 12 can be viewed on the realtime display. @shiv@vishnu |
#1306 | |
Drives: 2013 FRS
#1307 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Cross (03-06-2014) |
#1308 |
Drives: 2013 Firestorm FRS
I need help with flat foot shifting and launch control. I currently have both setup right now, but there are two issues that keep coming up.
The first, is launch control. I currently have it set at 4k rpm, and set to disable at 10mph. If I am stopped in the car, with the car in neutral (not pushing on the clutch) and I step on the gas (wot), it goes straight to 4k and sits there...which is what it should do, however, it does this whether or not I am stepping on the clutch-I though LC should only be enabled when full throttle AND stepping on the clutch. The only potential issue here (I think) is that I can't be cool and rev to 7k while in neutral. Pretty minor issue. However, when I'm cruising on the highway (going, say 60pmh) and I step on the clutch and floor it, the rpm's go to 5k(which it should, since the way launch control is configured in the computer by redline (minus) XXXX)-but, I'm going over 10mph, so why did it engage?. Again, while on the highway If I dont step on the clutch, and I floor it, the car will rev to 7k. SOOO...Isn't this supposed to be the way the car/rpm's respond when I'm stopped-and not on the highway? When I'm stopped or below 10mph, it should allow me to rev to 7k, unless I am stepping on the clutch, and then it should go to whatever my preset launch rpm is, and if I'm going over 10mph, it shouldn't engage at all. The second issue is bigger for me (but I think it has to do with launch control). I have flat foot shift/wot shift/no lift shift enabled, and there are two things that affect me. The first, is when going wot and shifting. If I'm approaching 7k rpms, and I upshift to the next gear, there is a pause in power (which it should), but then a .5 second delay or so before power comes back on. Great, thats what it should do. HOWEVER, during this time the car drops to 5k...which brings me back to my launch control issue. Because launch control doesn't seem to be disabled over 10mph, when I flat foot shift, the car thinks it should be in "launch mode"(because it see's full throttle and depressed clutch) and brings the rpms to 5k (and yes, I understand my rpms will drop while shifting lol) but it makes the engine go from 7k rpms, to 5k rpms to whatever rpm based on my gear and speed. This makes for a pretty jerky wot shift. I also run into this issue when downshifting before a turn. For example, I'll be in 3rd gear full throttle, and as I approach the corner, brake, clutch, blip the gas and downshift to 2nd, release the clutch and go back to wot. Once I got wot in 2nd, there is a .5 or so second delay before power is delivered-leading me to think its an issue with flat foot shift enabled, or the launch control issue I touched on before. This is an issue because the power gets applied at a different time than I expect, and will occasionally upset the balance of the car. Sorry for a long post/semi confusing questions, but hopefully someone can help me out on this topic. I realize this might be confusing, but its a weird glitch/issue and I dont know how else to explain it. @shiv@vishnu, @Rombinhood@OpenFlash |
#1309 | |
I'm going to challenge Shive a little here. Tax return coming and want to buy the OFT but I've been in contact with most all the best tuners and only a few have fixed this, I personally think its the achille's heal of the FA20 EFI/DI. Buying this I would really want the tip in knock significantly reduced.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#1310 | |
Drives: 2013 FRS
#1311 |
I am interested in what size pulley you were using when you were tuning the vortech test car. And if openflash will support smaller pulleys. I am asking because @nelsmar is switching the pulley he has on now with the factory one. Which brings another question if you support smaller pulleys eventually you will max out the MAF. I would think speed density would fix this issue.
@shiv@vishnu @jamesm |
#1312 | |
So if I end up with a Tippy you can support from CA (I'm in PA.)
#1313 | |
Drives: 2013 FRS
#1314 |
Drives: 2013 FRS
#1315 | |
#1316 | |
Drives: 2013 FRS
Curious... do the Vortech cars running on E85 have upgraded injectors/fuel pump? |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
