#1247 | |
Drives: '13 BRZ Ltd WRB
On another note, my P0351 (misfire cyl #1) code DID come back after going back to stock with 91 oct. Time for a new coilpack.
| The Following User Says Thank You to 2point0 For This Useful Post: | steve99 (03-01-2014) |
#1249 |
Drives: 2013 FRS
#1250 |
Drives: 2013 Scion FR-S Raven
Awesome, can hardly wait
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#1252 | |
| The Following User Says Thank You to steve99 For This Useful Post: | 2point0 (03-01-2014) |
#1253 |
Shiv, I'm getting lots of e85 cold start issues. Is this something that can be fixed? It's stalled on me every day since it started raining (~3 days ago) ambient temps 56 F according to Weather.com
I'm very confused since I figured in Cali I wouldn't have to deal with this |
#1254 | |
Drives: FR-S Whiteout
#1255 |
How about 11.25? Seems pretty low to me, but I'm far from an expert.
That's on 1.42 stage 1 tune, I flashed to 1.56b tonight and will grab a log from that tomorrow to see if it's much different. It was running a pretty horrible IAM (0.11-0.12 at the time of the log), would that effect AFR that much? It had learned up to about 0.6 before I flashed to 1.56b, so I don't think it was knock related? I also noticed that on the 1.42 tune it started off at 0 but on the 1.56b tune it started off at 1. Car is mostly stock, just a perrin 2.5" catted front pipe and 2.5" resonated exhaust. http://www.datazap.me/u/wparsons/mar...log=0&data=1-9
#1256 | |
Drives: BRZ Limited
| The Following User Says Thank You to fstlane For This Useful Post: | Sonolin (03-02-2014) |
#1257 | |
Pretty sure @Luckrider has done some mods to cranking enrichment tables that worked well. |
#1258 | |
I did see the cold start enrichment fix, but was hoping to get a response from @shiv@vishnu status with the OTS tune. I'd think it should handle rough starts better. I'd even love to see another tune like "stg 2 e85 el (winter)" or something. Anyway, I'll probably end up trying both solutions thanks guys and I'm glad I can edit this myself. Just might be something to consider for the OFT otb. |
| The Following User Says Thank You to Sonolin For This Useful Post: | fstlane (03-02-2014) |
#1259 |
Drives: 08 scion xb
I haven't had any cold start issues, but I'm getting some lag if I go WOT from a stop. Myabe just need more time for tune to adjust? Been running it since Thursday...
#1260 | |
Dismember
Drives: 2013 Red Scion FR-S
What brand of fuel do you buy? Propel? They seem to have a lot more ethanol than other brands. Did you have one good tank with no cold start problems then the second e85 tank had them? You'll need to enrich the cold cranking tables, especially the RPM cranking table, around 60 degrees F and below. I get great cold starts this way. PM me your email and I can send you a ROM that handles it.
Or you can do as suggested and just add a gallon or two of 91 to every tank. I don't want to do that because then the ethanol level fluctuates quite a bit. Quote:
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
