86WORX
Old 10-31-2013, 07:30 PM   #547
3essess
Drives: frs
Question regarding - Stock MAF Sensor Scaling.
I downloaded my stock ECU tune via the OFT into TunerPro and when I looked at the MAF Sensor Scaling table it does not look anything like the ones provided for by the OFT ots tunes. The voltages and I presume g/sec are wacky. Does anyone know why the stock scaling is so way off?
Thanks.
3essess is offline   Reply With Quote
Old 10-31-2013, 11:45 PM   #548
ThisGuy919
Is anyone else experiencing tuner pro crashing every time you try to go to adjust the launch control values?
ThisGuy919 is offline   Reply With Quote
Old 10-31-2013, 11:47 PM   #549
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cnk View Post
@shiv@vishnu @Garrett@Vishnu - One thing I noticed after upgrading to FA20 version 1.03 is that Section 1. Reading Information is now in Spanish. I tried changing the languages, but it only changes the language in the highlighted box. The field names are still in Spanish.
It's actually Italian and yes, it's a known bug. Should be fixed by tomorrow. Everything else should work though
Shiv
Old 10-31-2013, 11:50 PM   #550
Shiv@Openflash
Drives: 2013 FRS
Thanks.
Looks like you had a stock ROM with an older cal ID (700C or 900C). This is why it does not translate properly when using the current XDF file which is only compatible with A00C and A01C ROMs. To view stock ROM data, don't view your original ROM but rather the "Stock Mapping" ROM that is included in the OTS map file that you downloaded off the site.
Cheers,
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
3essess (11-01-2013)
Old 10-31-2013, 11:54 PM   #551
Shiv@Openflash
Drives: 2013 FRS
Sounds like you are using an older version of Tuner Pro that doesn't translate 32 bit data properly. This was a bug that was fixed a few weeks back. But didn't get on our website (for download) until a couple weeks ago. Just uninstall the current version of Tuner Pro and re-install it using the download link HERE (same as on our website).
Also, make sure that you are only trying to adjust the launch/FFS settings on the Tuned ROM files, not your stock ROM file which does not have this feature.
Cheers,
shiv
Old 11-01-2013, 01:25 AM   #552
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I know this is getting to be a broken record but when will data logging be available?
I won't purchase until it does and I'm sure I'm not alone.
Also do you plan on supporting various headers or will it be a one size fits all. ?
Thanks,
Matt
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
elrod (11-01-2013)
Old 11-01-2013, 01:33 AM   #553
Shiv@Openflash
Drives: 2013 FRS
Thanks,
Matt
Datalogging/Dataviewing will be released when it is done. This most recent firmware update (and new OpenFlash Manager software) has to do with datalogging functionality (among other things). Hard to give an ETA on when it will be made active since there are more than one pan on the stove at this time. But the programming team is making good progress on everything.
We will support a many headers as we personally tune. But I expect many people to make maps for their own particular setup since dialing in headers isn't much more than just tweaking VVT mapping during the dip region. This can even be done off the dyno by just datalogging MAF. More on that later once datalogging is enabled.
Shiv
Old 11-01-2013, 02:47 PM   #554
Cross
It's the Mad Cow
Cross's Avatar
Shiv
This is why most people are getting ancie we want to make changes to our tunes however without datalogging it creates a hurdle that either has to be solved by trying to use outside programs or the inability to make changes.
I understand being busy but the problem is that when I personally have asked questions in this thread and I believe another I have been ignored. Busy or not when I am trying to promote your device at my shop and I can't even fully tune with it nor give an ETA to those locals waiting we have a problem and it causes further problems aka a snow ball effect.
I still would like answers to my questions regarding the lack of MAF changes between the AirRaid and Stock Box tunes since you removed the AirRaid option. Mainly because I noticed your new 2.0 tune is not only using the stock box but also has MAF Scaling changes which is something I expected to find on the AirRaid instead of just finding changes to the Fuel Table.
Since you are no longer supporting the AirRaid but many of us are running it without the ability to data log I would appreciate some feedback on what if any changes we should transfer over to continue using it.
I also would like an update on E85.
Here is an idea, in the main post put an ETA. The ETA can change things happen and your clients here completely understand that. Yes if you change it 4 or 5 times you might get some flack but what we are looking for is confirmation this is not going to be another Unichip promise that a year later nothing comes of it.
Not to mention there is a reason deadlines exist, they drive us. Sometimes they must be moved but they help to keep things on track, working at a software company we have deadlines for those very reasons.
Good luck with the what you are working on.
The Following User Says Thank You to Cross For This Useful Post:
elopez (11-01-2013)
Old 11-03-2013, 01:10 AM   #555
8686
8686's Avatar
Drives: 86
post # 464
Originally Posted by 8686 View Post
The same exactly happened to me and I also have a push-start buttin.
also waiting for @shiv@vishnu to work on my stock ROM file # ZA1J700K I sent yesterday
Sent from my iPhone using Tapatalk - now Free
post # 475
so should I expect my rom support today or next week?
Calibration # ZA1J700K
post # 476
Should be by the end of this week.
Post # 513
Hi Shiv
any new on international calibration ROM files.
Thank you for your support
Post # 514
Working on them now. Was hoping to have them done by Friday but it looks like I'll need the weekend to finish them off.
Post # 523
Sorry for being so demanding bur I so excited to get the tune.
Any update...
post # 524
Don't laugh but my dog knocked over my external HD which I use for website updates. Currently getting the data extracted and put on another HD which should be ready tomorrow. I'll be back from vacation tomorrow as well so expect to see OTS maps for some international roms up then. Sorry for the delay...
post # 553
I sent mine one week ago. still nothing yet.
post # 555
Tunes for those cal IDs should be ready tomorrow when I get back home. Ended up staying here in Maui 2 extra days. GF stepped on a sea urchin and her foot swelled up to the size of a grapefruit, hindering our travel back to the mainland :/
http://www.ft86club.com/forums/showp...&postcount=116
Can we will also expect the international calibration files to be uploaded today?
http://www.ft86club.com/forums/showp...&postcount=117
Yep. Will probably be late in the day/evening. Working through it now and each porting job is pretty time consuming.
and still nothing yet. I am disappointed.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8686 For This Useful Post:
akyp (11-03-2013), SloS14 (11-03-2013)
Old 11-03-2013, 03:12 AM   #556
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
post # 464
post # 553
post # 555
+1
This is exactly main Murphy's law -"Anything that can go wrong, will go wrong".
So we may be pretty sure that everything went wrong in our case (including that damned sea urchin).
I am trying to relax (difficult) and don't wait (easy, but can't stop useless daily checking the sites/forums for updates yet). And the tune will finally arrive, in one or another way
Everything is going wrong and pray our desperately expected OTS tunes will be at least correct...
Ondreiko is offline   Reply With Quote
The Following User Says Thank You to Ondreiko For This Useful Post:
8686 (11-03-2013)
Old 11-03-2013, 11:07 AM   #557
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Ondreiko View Post
+1
I'm pretty sure shiv and company are not going to leave us on a ledge. The data logging is out of their hands since another company is programming for it. Things will happen. It may not be as fast as we want but it will happen soon.
I rather things get handled correctly rather then rushed because we demand it. I want tunes that won't ruin my car. We already had enough of that on this forum.
Installed Mods:
Old 11-03-2013, 11:07 AM   #558
brn12345
brn12345's Avatar
Guys chill! Shiv is working full on these and the updates. I waited patiently for the international A01J rom stage 1 and got it yesterday. Flashed it today and all works fine. Did datalogs (other software) and happy with the results. The car absolutely screams from 7000rpm to 7650rpm. Those 200 extra rpm are awesome! Thanks Shiv@Vishnu
brn12345 is offline   Reply With Quote
Old 11-03-2013, 01:47 PM   #559
Shiv@Openflash
Drives: 2013 FRS
Hi guys,
Apologies to everyone who has been patiently waiting for international tuned ROM support. Looks like we are finally caught up with all pending requests. Which means that we now have tuned ROM support for the following markets:
Bahrain (J series ROM)
Saudi Arabia (K series ROM)
China (N series ROM)
Hong Kong (G series ROM)
These tuned ROMs files (Stage 1 and Stage 2) will be available upon email request to all OFT users.
If you have an OFT and still don't have ROM support, please email me your original ROM (as read by OFT) to shiv@vishnutuning.com and include the following info:
1) List of modifications
2) Fuel type
3) 6AT or 6MT
4) Domestic market (country)
Cheers,
Shiv
Old 11-03-2013, 02:31 PM   #560
brn12345
brn12345's Avatar
Shocking the amount of ROM's for these cars. There used to be a time when all there was was US, Europe, and Japan specific roms. I understand the need to have different ROMs for different regions but why different roms for countries that are only miles apart?! I wouldn't be surprised if there were different roms in the same country at this point! Case in point the Japanese market has I think 8 roms for 1 model year!!!!!
Hi guys,
Apologies to everyone who has been patiently waiting for international ROM support. Looks like we are finally caught up with all pending requests. Which means that we now have support for the following markets:
2) Fuel type
3) 6AT or 6MT
Cheers,
Shiv
cat overtemp
Search this Thread:
Advanced Search
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
